    Testing M291 "result"
    • fcwilt
      fcwilt last edited by
      When using the form of M291 where it shows an OK and CANCEL button is there any way in the code that follows the M291 to determine which button was pressed?
      If the CANCEL button was pressed I would like to stop executing the macro.
      Thanks.
      gloomyandy 1 Reply Last reply Reply Quote 0
      • gloomyandy
        gloomyandy @fcwilt last edited by gloomyandy
        @fcwilt Have you tried testing the "result" "named constant" that tends to return information on the previous gcode command: https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Named_constants
        Should say I've not tried it following the M291 command!
        fcwilt 1 Reply Last reply Reply Quote 0
        • fcwilt
          fcwilt @gloomyandy last edited by
          @gloomyandy said in Testing M291 "result":
          No I have not - I had not read about it - thanks for the suggestion.
