    Duet2+Duex5 3.4beta5: exploding leadscrews.
    Beta Firmware
    324
    • H2B
      H2B last edited by H2B
      Hey all,
      Oddest occurrence today: after completing a print successfully on my Jubilee toolchanger, I removed the print as usual, and then clicked the "Print Again" option on DWC. Lo and behold, my G28 ran the Y and then X homing sequence, and then started the Z homing sequence.
      The carriage failed to move to the center of the bed, as defined in my homez.g, and as such, the bed kept raising and seeking the endstop (conveniently located nowhere near where its supposed to be) until the anti-backlash nuts popped right off. I did get a single message stating "Error: G1/G2/G3: intermediate position outside machine limits" but I'm unsure when in the cycle this appeared.
      Picture for posterity's sake:
      Machine had no tools loaded (I had just completed a print), and here's the relevant sections of my gcode file in the start and end portions that would be relevant to what the machine was trying to operate.
      Only thing that I think could have happened is somehow my homeu.g failed to complete, but in that case, why didn't the machine move in X or Y, but continued to move in Z?
      I can easily add some conditional gcode to handle checking if axes are homed, but I really think this might be some overlooked area of the codebase that triggered this odd (and potentially machine-destroying) condition..
      Start of gcode file:
      M104 S235 T2 ; set temperature
      ;TYPE:Custom
      ; babystepping (PLA 0.11; PETG -0.03)
      M290 S-0.01 R0
      M190 S55 R55
      T0 P0
      T1 P0
      T2 P0
      T-1 P0
      ; BEGIN: start custom g-code
      G91 G1 Z5 ; drop bed slightly
      G90 ; absolute positioning
      G28 ; home all axes    <---- this is where it failed.
      M558 F400 S0.01
      G32 ; tram bed
      G32
      G32
      M558 F400 S0.01
      G29
      End of gcode file:
      G1 X148.409 Y155.848 E-0.01371
      ;WIPE_END
      G1 E-0.03 F3600
      ; stop printing object cable_clinger_v0.stl id:0 copy 0
      M107
      ;TYPE:Custom
      ; Filament-specific end gcode
      ;END gcode for filament
      M104 S0 ; turn off temperature for tool
      T-1 ; unload tool
      ;G91 G1 Z10 G90
      M0 ; call stop routine
      M84     ; disable motors
      stop.g simply calls cancel.g, which is here:
      ; cancel.g
      ; called when a print is cancelled after a pause.
      T-1                     ; park any active tool
      M400
      G91 G1 Z5 G90
      G0 X-20 Y-20 F42000      ; return all motions to home
      M140 S0                 ; turn off the bed heater.
      M84 S600                ; disable motors after 10 mins of inactivity
      homeall.g:
      ; homeall.g
      ; called to home all axes X Y Z and Toolchanger lock
      G91 G1 Z5 F800 H2           ; Lift z so we don't crash
      M98 P"homey.g"
      M98 P"homex.g"
      M98 P"homeu.g"
      M98 P"homez.g"
      homey.g:
      ; homey.g
      ; called to home the Y axis
      ; make sure everything has stopped before we make changes
      M400
      ; Set relative mode
      G91
      G1 Y-400 F6000 H1       ; Big negative move to search for endstop
      G1 Y4 F600              ; Back off the endstop
      G1 Y-10 F600 H1         ; Find endstop again slowly
      ; set absolute mode
      G90
      homex.g:
      ; homex.g
      ; called to home the X axis
      M400                  	; make sure everything has stopped before we make changes
      G91                     ; Set relative mode
      G1 X-400 F6000 H1       ; Big negative move to search for endstop
      G1 X4 F600              ; Back off the endstop
      G1 X-10 F600 H1         ; Find endstop again slowly
      G90                     ; Set absolute mode
      homeu.g (toolchanger lock axis):
      ; Home U Axis
      G1 U-100 F6000 H1       ; Big negative move to search for endstop
      G1 U6 F600              ; Back off the endstop
      G1 U-10 F600 H1         ; Find endstop again slowly
      and finally, homez.g:
      ; Home Z Axis
      ; Set acceleration for travel moves
      M204 T10000
      G91 G1 Z10 F800 H2 G90
      ; Move to the center of the bed
      G1 X155 Y155 F42000
       ; Set the probing speed
      M558 F500
      ; run probe 1
      G30
      ; Set a slower probing speed
      M558 F100
      ; run probe 2
      G30
      relevent entry from log file:
      2021-11-02 20:20:31 [warn] Started printing file 0:/gcodes/cable_clinger_v0.gcode
      2021-11-02 20:21:10 [warn] Leadscrew adjustments made: -0.072 -0.063 -0.030, points used 4, (mean, deviation) before (-0.056, 0.112) after (0.000, 0.111)
      2021-11-02 20:21:29 [warn] Leadscrew adjustments made: -0.055 -0.051 -0.052, points used 4, (mean, deviation) before (-0.053, 0.114) after (0.000, 0.114)
      2021-11-02 20:21:49 [warn] Leadscrew adjustments made: -0.052 -0.058 -0.056, points used 4, (mean, deviation) before (-0.056, 0.110) after (0.000, 0.110)
      2021-11-02 20:23:12 [warn] 25 points probed, min error -0.155, max error 0.081, mean -0.017, deviation 0.060
      Height map saved to file 0:/sys/heightmap.csv
      2021-11-02 20:36:20 [warn] Finished printing file 0:/gcodes/cable_clinger_v0.gcode, print time was 0h 15m
      2021-11-02 20:41:28 [warn] Started printing file 0:/gcodes/cable_clinger_v0.gcode
      2021-11-02 20:41:50 [warn] Error: G1/G2/G3: intermediate position outside machine limits
      2021-11-02 20:42:10 [warn] Cancelled printing file 0:/gcodes/cable_clinger_v0.gcode, print time was 0h 0m
      2021-11-02 20:42:10 [info] Event logging stopped
      config file attached for reference: config.g
      o_lampe T3P3Tony 2 Replies Last reply Reply Quote 0
      • o_lampe
        o_lampe @H2B last edited by
        @h2b said in Duet2+Duex5 3.4beta5: exploding leadscrews.:
        There are many invalid z-lifts in your files (without H2). I'm sure they are ignored by RRF.
        This quoted one looks better, but I'd put the G90 in a separate line and add M400 afterwards. Just to make sure, the printer is in absolute mode when you move X,Y.
        That's how I interpret the error message "Error: G1/G2/G3: intermediate position outside machine limits"
        H2B 1 Reply Last reply Reply Quote 0
        • H2B
          H2B @o_lampe last edited by
          @o_lampe this config has been working for over 6 months without a hitch. Its just yesterday with the failed U axis home that I had the error, and the Z homing failed.
          Also, why would I need H2 on Z-lifts? I'm using a 3xZ configuration and I'm moving the bed normally. What's your thinking behind this suggestion?
          • T3P3Tony
            T3P3Tony administrators @H2B last edited by
            so the question is why this did not happen this time. has anything changed in config/firmware etc recently?
            www.duet3d.com
              dc42 administrators @H2B last edited by
              H2 is needed when doing a Z lift in a situation in which Z may not have been homed yet, for example in the scripts to home X and Y.
              • H2B
                H2B @T3P3Tony last edited by
                @t3p3tony yes, that's the question. nothing for the firmware, config, etc. had changed.
                The only thing that I can be sure happened during this whole event was that my U axis (for my tool lock) failed to home, and that threw off the Z homing macro's first couple of steps to move the carriage to the middle of the build plate.
                That's about as far as I can tell. So the question would now be: Why was the error thrown and why did the macro fail to move the print head (I'm assuming the error is from line 9 of the homez.g: G1 X155 Y155 F42000
                • T3P3Tony
                  any idea why?
                  If you U is un homed, do X and Y move normally with your config? They should do as far as I can see but worth a test to understand if that could be the cause.
                  I assume its too late to check if X and Y say there moved to the middle (and did not) or they report that they never moved (i.e. the position is still where they were before homez was called.
                  www.duet3d.com
                  • H2B
                    H2B @T3P3Tony last edited by H2B
                    @t3p3tony
                    U Axis failed to home due to a physical problem with the physical state of the U stepper (to skip over the details: it completely failed to home).
                    I have non-homed axes movement allowed in my config, so it shouldn't have impacted the movement of X and Y in the homez.g macro. I feel like it may have something to do with how macros are called when an error is triggered. For example, G1 error thrown in homeu.g, sent to console for display, but in the background the next macro is called and the first G1 command is skipped due to the error from the previous step. This may have been the case, but I'm not certain.
                    Also X and Y were at their endstops, so they definitely didn't move at all. You're right, its too late to check (and I'm not ready to try and recreate this event!) if DWC reported different coordinates for those axes..
                    • T3P3Tony
                      Obviously we don't want any more dramatic leadscrew disassembly events, but it might be worth seeing if you can recreate this under controlled conditions:
                      1. Cause the U axis to not home in the same manner
                      2. see if the homeZ still fails to move X and Y.
                      3. be ready to hit the trigger manually to stop Z before any issues happen.
                      While this may have been a very fluky one off it would be nice to understand what happened, if we can.
                      www.duet3d.com
                      • H2B
                        @t3p3tony I've tried recreating it by removing the endstop connection, stalling the stepper during homing, etc. etc. but I can't seem to recreate the same error message I've had, and the printer still runs the Z home macro flawlessly. I'm honestly quite perplexed and chalking this one up to RRF beta gremlins 😉
                        Thanks for the help in all cases!
