    M955 fails on 3.4.0beta5
    Beta Firmware
    288
    • j3d
      j3d last edited by j3d
      I'm in the process of attaching an accelerometer to my Duet 3 Mini 5+ on IO_4. It seemed to connect just fine with 3.3, but after upgrading to 3.4.0beta5, I now get the following error when issuing this M955 command:
      M955 P0 C"io4.out+io4.in" I60
      Error: M955: Pin 'io4.out' is not free
      I am aware that io4.out is shared with pson, but I don't see any way to disable that function? This seemed to work just fine with 3.3, so I'm wondering if this is a regression?
      j3d 1 Reply Last reply Reply Quote 0
      • j3d
        j3d @j3d last edited by j3d
        My full config is as follows:
        ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Mar 07 2021 13:03:50 GMT-0500 (EST)
        G90                                         ; send absolute coordinates...
        M83                                         ; ...but relative extruder moves
        M550 P"Dremel 3D20"                         ; set printer name
        M552 P0.0.0.0 S1                            ; enable network and acquire dynamic address via DHCP
        M586 P0 S1                                  ; enable HTTP
        M586 P1 S0                                  ; disable FTP
        M586 P2 S0                                  ; disable Telnet
        M569 P0.0 S1 V40                            ; physical drive 0.0 goes forwards
        M569 P0.1 S1 V40                            ; physical drive 0.1 goes forwards
        M569 P0.2 S1 V20                            ; physical drive 0.2 goes forwards
        M569 P0.3 S1 V40                            ; physical drive 0.3 goes forwards
        M584 X0.0 Y0.1 Z0.2 E0.3                    ; set drive mapping
        M350 X16 Y16 Z16 E16 I1                     ; configure microstepping with interpolation
        M92 X88.89 Y88.89 Z400.00 E96.00            ; set steps per mm
        M566 X900.00 Y900.00 Z12.00 E120.00         ; set maximum instantaneous speed changes (mm/min)
        M203 X12000.00 Y12000.00 Z720.00 E1200.00   ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z50.00 E250.00         ; set accelerations (mm/s^2)
        M906 X680 Y680 Z320 E680 I30                ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                     ; Set idle timeout
        M208 X-80 Y0 Z0 S1                          ; set axis minima
        M208 X275 Y150 Z150 S0                      ; set axis maxima
        M574 X2 S1 P"!io0.in"                       ; configure active-high endstop for high end on X via pin !io0.in
        M574 Y2 S1 P"!io1.in"                       ; configure active-high endstop for high end on Y via pin !io1.in
        M574 Z1 S2                                  ; configure Z-probe endstop for low end on Z
        M558 P8 C"^io3.in" H1 F240 T9000 A5         ; set Z probe type to switch and the dive height + speeds
        G31 P500 X3 Y-33 Z2.485                     ; set Z probe trigger value, offset and trigger height
        M557 X20:200 Y20:130 S30                    ; define mesh grid
        M140 H-1                                    ; disable heated bed (overrides default heater mapping)
        M308 S0 P"spi.cs1" Y"thermocouple-max31856" F60 ; configure sensor 0 as thermocouple via CS pin spi.cs1
        M950 H0 C"out1" T0                          ; create nozzle heater output on out1 and map it to sensor 0
        M307 H0 R1.823 C263.1:216.5 D7.84 S1.00 V23.9
        M143 H0 S280                                ; set temperature limit for heater 0 to 280C
        M950 F0 C"out3" Q500                        ; create fan 0 on pin out3 and set its frequency
        M106 P0 C"EXTFAN" S0 H0 T45                 ; set fan 0 name and value. Thermostatic control is turned on
        M950 F1 C"out4" Q500                        ; create fan 1 on pin out4 and set its frequency
        M106 P1 C"DUETFAN" S1 H-1                   ; set fan 1 name and value. Thermostatic control is turned off
        M950 F2 C"out5" Q200                        ; create fan 2 on pin out5 and set its frequency
        M106 P2 C"PARTFAN" S0 H-1                   ; set fan 2 name and value. Thermostatic control is turned off
        M950 F3 C"out6" Q500                        ; create fan 3 on pin out6 and set its frequency
        M106 P3 C"REARFAN" S0 H-1                   ; set fan 3 name and value. Thermostatic control is turned off
        ; Lights
        M950 P0 C"io2.out" Q5000                    ; create led strip on io2.out - pwm frequency is 5000 Hz
        M42 P0 S0.25                                ; set strip to 25% brightness
        M563 P0 D0 H0 F0:2                          ; define tool 0
        G10 P0 X0 Y0 Z0                             ; set tool 0 axis offsets
        G10 P0 R0 S0                                ; set initial tool 0 active and standby temperatures to 0C
        ; Custom settings
        M671 X65:165:116 Y10:10:150                 ; set positions of bed levelling screws
        M207 S0.6 F3600 T2400                       ; set retraction to 0.6mm at 60mm/s / 40mm/s. Z-hop set in slicer
        M572 D0 S0.025                              ; set pressure advance
        ;M955 P0 C"io4.out+io4.in" I60               ; enable accelerometer
        T0                                          ; select first tool
        • j3d
          I noticed the following in the change log for 3.4.0beta4. I wonder if these changes caused the issue?
          state.atxPower is no longer flagged 'live'. It is present if at least one M80 or M81 command has been executed and the PS_ON port is valid.
          M80 now has an optional C parameter allowing the PS_ON port and polarity to be changed
          Though, as you can see, there is no M80 or M81 command in my config.
          T3P3Tony dc42 2 Replies Last reply Reply Quote 0
          • T3P3Tony
            T3P3Tony administrators @j3d last edited by
            @j3d you chan check if you have a pin assigned to the ATX power port by looking at the state.atxPowerPort in the object model:
            echo state.atxPowerPort
            null
            will report null if no pin is assigned which is what i have on my mini 5+ running the latest beta firmware as i also have no M80 commands
            after sending M80 with no commands it switches to the default
            (io4.out,pson)
            So if you have that defined then maybe M80 is somewhere else in a macro? As you say its not in the config.g that you shared ot its a regression in 3.4b5 that is fixed in 3.4b5+1
            www.duet3d.com
              dc42 administrators @j3d last edited by
              @j3d I assume you are not using the PS_ON output. Try using command M80 C"nil" before the M955 command.
              • j3d
                j3d @dc42 last edited by
                Running the following resulted in null:
                null
                However entering M80 C"nil" before the M955 command seems to have worked.
                • T3P3Tony
                  @j3d thanks for that confirmation.
                  www.duet3d.com
                    @j3d thanks for reporting that. I'm changing things in 3.4.0beta6 so that a power pin will not be assigned by default, and so io4.out will be free.
