    DWC/DSF plugins remain "partially started" after restart
    Duet Web Control
    • peterwilliundefined
      peterwilli
      Hey there,
      A while ago I asked help for developing a plugin, and I managed to do that. It runs on the printer and is based on the following plugin: https://github.com/Kriechi/duet-plugin-filament-load-cell
      The problem we're facing now is that when the printer (the raspberry pi) is restarted, the plugins are listed as "partially started", with no errors in journalctl. When manually stopping/starting said plugins it works fine.
      I wonder if this is a common problem? We tried both the filament load cell plugin (We based our plugin on this source, but found no other plugin with Python to test out) and our own.
      We're currently on DWC 3.3.0. Thanks a lot!
        jay_s_uk @peterwilli
        @peterwilli I think plugin handling has been improved in the 3.4 betas.
        It may be better to update to those and test it as i doubt there will be another 3.3.X release
        peterwilliundefined 1 Reply Last reply Reply Quote 0
          peterwilli @jay_s_uk
          @jay_s_uk Thank you, we tried it and it works. We'll wait for the "real" release coming out and upgrade to this version!
          • jhalewoodundefined jhalewood referenced this topic
