    M569 Default T parameter?
    946
    • Kulitorum
      Kulitorum last edited by
      My Servo driver for my extruder in my concrete printer is missing steps. What is the default T parameter for the M569 command?
      Kulitorum
      • Kulitorum
        Scope gave the answer - T0.15, right?
        Kulitorum
        • Kulitorum
          So I was trying to figure out why my servo did not get the signal, and I noticed the voltage of the step/direction signals are only 0.3v. What can explain that?
          Kulitorum
          • Kulitorum
            My bad, the probe was set at x10.
            Still, I am getting 3.3v, can I get 5v?
            Kulitorum
              You can't get 5V directly because the signal levels on the Duet are 3.3V. However, most external stepper drivers will work with 3.3V signals.
              External stepper drivers typically need a 1 to 2 us pulse, which you should configure in the M569 commands for the driver numbers concerned.
              • Kulitorum
                Cool, but what is the default T value for the M569 command?
                • Kulitorum
                  I just ordered some breakout boards, I think they should solve the problem.
                    The default step pulse width is guaranteed to be long enough for the on-board drivers but is otherwise not defined and likely to change between firmware versions.
                    • T3P3Tony
                      Michael, the data sheet of the servo driver should have a minimum pulse width, best to use something slightly longer in M569
                      Duet Hardware Designer
                      www.duet3d.com
