    Duet not connecting correctly, please help
    • Lance 0
      Lance 0 last edited by
      Hey all,
      I have a ooznest workbee running duet and for some reason on the last update the duet web portal connects and disconnects rapidly. All of my wifi settings are good, fully connected, I can only gain access when I usb into the duet directly but the portal rapid connects and interrupts the connections like someone is hitting a on off switch rapidly. Any help would be greatly appreciated as I have been tryin to fix this for a couple of days now.
      Cheers,
      • T3P3Tony
        T3P3Tony administrators @Lance 0 last edited by
        @lance-0 what firmware versions are you running on the duet and the WiFi server?
        Send M122 which will tell you both. Also if you can connect on the web interface for.long enough to see what version of DWC you are running that would be good.
        www.duet3d.com
