    Printer locked up
    150
    • tomasro
      tomasro last edited by
      Printer was working just fine, and then while running g32, xy drivers started skipping and running backward. I emergency stopped the printer and now I can't home, and the console is reporting "Warning: high temperature reported by driver(s) 1 2".
      M308 s2
      "Sensor 2 (DRIVERS) type Stepper driver temperature warnings, reading 0.0, last error: success".
      m308 s3
      "Sensor 3 (MCU) type Microcontroller embedded temperature sensor, reading 22.7, last error: success".
      Endstops for X&Y drivers reporter homed, but the printhead is in the middle of the printer.
      Machine spec:
      CoreXY
      Duetwifi v1.01 & duex5 v0.10
      Quad Z motors
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.4 on Fri Oct 22 2021 23:28:40 GMT-0700 (Pacific Daylight Time)
      G90                                                    ; send absolute coordinates...
      M83                                                    ; ...but relative extruder moves
      M550 P"R2D Cube"                                       ; set printer name
      M669 K1                                                ; select CoreXY mode
      M912 P0 S-8.2					;calibrate MCU temperature
      M552 S1                                                ; enable network
      M586 P0 S1                                             ; enable HTTP
      M586 P1 S0                                             ; disable FTP
      M586 P2 S0                                             ; disable Telnet
      M569 P0 S0                                             ; physical drive 0 goes backwards
      M569 P1 S0                                             ; physical drive 1 goes backwards
      M569 P3 S1                                             ; physical drive 3 goes forwards
      M569 P5 S0
      M569 P6 S0
      M569 P7 S0
      M569 P8 S0
      M584 X0 Y1 Z5:6:7:8 E3                                       ; set drive mapping
      M671 X-40:515:-40:515 Y37:37:430:430 S5 ; leadscrews at left front, right front, left rear, right rear
      M350 X16 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z808.00 E402.00                      ; set steps per mm
      M566 X900.00 Y900.00 Z100.00 E120.00                    ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z6000 E1200.00                ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z250 E250.00                    ; set accelerations (mm/s^2)
      M906 X900 Y900 Z800 E800 I1                            ; set motor currents (mA) and motor idle factor in per cent
      M84 S10                                                ; Set idle timeout
      M208 X0:455 Y0:405 Z0:420
      M591 P2 C"!duex.e2stop" S1   D0 			       ; filament monitor connected to E0 endstop
      M574 X1 S1 P"!duex.e3stop"                                   ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !xstop
      M574 Y1 S1 P"!duex.e4stop"                                   ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !ystop
      M574 Z1 S2                                             ; configure Z-probe endstop for low end on Z
      M950 S0 C"duex.pwm1"                                  ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H10 F600 T10000                   ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X35 Y35 Z1.7                                   ; set Z probe trigger value, offset and trigger height
      M557 X72:490 Y35:440 S100                              ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950         ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 R0.221 C451.3 D2.62 S1.00             ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                ; map heated bed to heater 0
      M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
      ;M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
      M307 H1 B0 R2.107 C262.7:238.2 D6.31 S1.00 V24.6
      M143 H1 S280                                           ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1.0 H1 T45                                     ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                       ; define tool 0
      G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
      G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
      ;Temp Sensor trigger
      M308 S2 Y"drivers" A"DRIVERS"  ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
      M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as on-chip MCU temperature sensor
      M950 F2 C"fan2" Q100 ; create fan 2 on pin fan2 and set its frequency
      ;M106 P2 H2:3 L0.15 X1 B0.3 T30:70 ; set fan 2 value
      M106 P2 H2:3 S1 T20
      Any help would be appreciated. Thanks!
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @tomasro last edited by
        @tomasro sounds like you need to check your wiring on whatever is connected to drivers 1 and 2 (usually Y and Z)
        tomasro 1 Reply Last reply Reply Quote 0
        • tomasro
          tomasro @jay_s_uk last edited by
          @jay_s_uk Driver 2 is completely empty. I've got 4 z motors on drivers 5, 6, 7 and 8 on the duex board
          • jay_s_uk
            @tomasro that doesn't sound good then. When and where did you buy your duet?
            • tomasro
              @jay_s_uk Filastruder. I've had it for a couple years now. It's never had this problem until I added the Duex5 board and redid the wiring. I've got active cooling on the back of the boards. Would heatsinks on the back or front help?
              • tomasro
                tomasro @tomasro last edited by
                @tomasro I turned the machine off overnight and now the driver are working, but they still don't return a temperature from the sensor.
                • jay_s_uk
                  @tomasro drivers only report 0, 100 and 130 degrees
                  • tomasro
                    @jay_s_uk So why would it report drivers over temp when it shows 0?
                      Phaedrux Moderator @tomasro last edited by
                      @tomasro said in Printer locked up:
                      possibly because by the time you sent the command to check they had cooled below the warning temp.
