PanelDue Firmware 3.4.0-rc1 released
Hey,
we are heading to the next stable PanelDue 3.4.0 release. On that way here comes the first release candidate. Things looks stable and quite some improvements.
Please test and leave some feedback about your experience.
And big thanks to the helping hands reporting bugs, testing and bringing new ideas. This really helps to build better software.
Have a nice weekend!
Release Notes 3.4.0-rc1
This release requires RepRapFirmware 3.4 or later.
Version 2 (after August 2016) and Version 3 PanelDue are supported.
- add cross-platform headless builds based on cmake
- cleaned up dim/screensaver handling
- removed compiler warnings
- enabled Russian localization by default
- enabled Ukrainian localization by default
- improved list-locales tool for translation debugging
- fixed displaying of M291 S2 and S3 if followed by M292
- fixed displaying macro buttons in control tab
- fixed setting of serial baud rate after reboot
- cleaned up English
- cleaned up Czech translation
- cleaned up French translation
- cleaned up German translation
- fixed access to second sd card
- cleaned up Russian translation
- fixed persistent pressed button handling in some dialogs
- fixed updates via RRF
- fixed displaying of multiple heaters per tool
- improved readme
- fix brightness handling during pop-ups
- disabled spammy debug information
- show babystep button if printer is idle
- cleaned up Spanish translation
- change default feedrates
- extend m291 popup to allow movement of other axis, up to 10
- updated RRFLibraries
- fixed babystep button alignment in setup tab
Downloads and flashing instructions:
Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.4.0-rc1
Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
undefined mfs12 referenced this topic
undefined mfs12 pinned this topic
New release candidate out...
https://forum.duet3d.com/topic/26071/paneldue-firmware-3-4-0-rc2-released/1
undefined mfs12 locked this topic
undefined mfs12 unpinned this topic
