    X axis moving the wrong way on a CoreXY
    Firmware installation
    1.4k
    • Exerqtorundefined
      Exerqtor
      Having a weird issue with a machine I'm setting up atm with the X axis moving the wrong way while the Y axis works as intended. I didn't think that should even be possible on a corexy since the X/Y steppers have to work in tandem. And i can't for the life of it find an error in the config 😳
      And I've checked the wiring, both ends of each stepper wire is connected identical to each other😅
      Here's a snippet of the config.g:
      M111 S0                 													; Debugging off
      G21																; Work in millimetres
      G90																; send absolute coordinates...
      M83																; set extruder to relative mode
      M575 P1 B57600 S1														; enable and configure PanelDue
      ; General setup
      M669 K1																; select CoreXY mode
      ; --- drive map ---
      ;    _______
      ;   |   0   |
      ;   | 2 | 1 |
      ;     front
      M569 P0 S0															; Z1 (physical drive 0) goes backwards
      M569 P1 S0															; Z2 (physical drive 1) goes backwards
      M569 P2 S0															; Z3 (physical drive 2) goes backwards
      M569 P3 S0															; X (physical drive 3) goes backwards
      M569 P4 S0															; Y (physical drive 4) goes backwards
      M569 P5 S0															; E (physical drive 5) goes backwards
      ; Motor mapping and steps per mm
      M584 X4 Y3 Z0:1:2 E5														; set drive mapping
      M350 X16 Y16 Z16:16 E16 I1													; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00:400.00:400.00												; set XYZ steps per mm (1.8deg motors)
      M92 E430.11															; set Extruder steps per mm (BMG)
      ; Drive currents
      M906 X1400 Y1400 Z1200:1200:1200												; set XYZ motor currents (mA)
      M906 E1000															; set Extruder motor current (mA)
      M906 I30															; set ide current percentag
      M906 I30															; set ide current percentage
      M84 S30																; Set idle timeout
      ; Accelerations and speed
      M98 P"/macros/System/Speed/speed_printing.g"											; set normal speed & accel
      M208 X0 Y0 Z0 S1														; set axis minima
      M208 X347.5 Y358 Z300 S0													; set axis maxima
      M574 X2 S1 P"xstop"														; configure active-low endstop for low end on X via pin xstop
      M574 Y2 S1 P"ystop"														; configure active-low endstop for low end on Y via pin ystop
      M574 Z0 P"nil"															; no endstop
      jay_s_ukundefined fcwiltundefined dc42undefined 3 Replies Last reply Reply Quote 0
        jay_s_uk @Exerqtor
        @exerqtor mess around with the S setting on your M569 commands for the x and y steppers
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @jay_s_uk
          @jay_s_uk
          But if i change the S parameter on only say "X" that will just make it shit the bad since the two steppers have to work together in CoreXY won't it? Or am i overcomplicating it.
            jay_s_uk @Exerqtor
            @exerqtor no. It'll make sense once you start switching them about
            • fcwiltundefined
              fcwilt @Exerqtor
              @exerqtor
              From the DWC console execute M669. You should get something like this:
              11/8/2021, 2:12:06 PM	M669
              1.00 1.00 0 0
              1.00 -1.00 0 0
              0 0 1.00 0
              You can use M669 to enter the matrix values directly instead of specifying the kinematics type of K1.
              M669 X1:1:0 Y1:-1:0 Z0:0:1                     ; CoreXY
              Use that form of M669 and try different values after the X. That worked for me.
              X-1:1:0 or X1:-1:0 or X-1:-1:0 - one of them should work.
              • Exerqtorundefined
                Exerqtor @fcwilt
                @fcwilt said in X axis moving the wrong way on a CoreXY:
                @exerqtor
                1.00 1.00 0 0
                1.00 -1.00 0 0
                0 0 1.00 0
                M669 X-1:-1:0 Y1:-1:0 Z0:0:1
                worked! Thanks 😍
                • Exerqtorundefined Exerqtor marked this topic as a question
                • Exerqtorundefined Exerqtor has marked this topic as solved
                  dc42 administrators @Exerqtor
                  @exerqtor the usual way to switch between right hand and left hand coordinate systems on a CoreXY machine is to swap the X and Y motors, either in the wiring or in the M584 command. See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement.
                  • Exerqtorundefined
                    Exerqtor @dc42
                    Oh ok, so i will achieve the same result as adjusting the kinematics matrix by doing that? In that case that sounds like a more "correct" approach to solving the issue 😅
                    EDIT:
                    Tried swaping around the steppers wires and setting the kinematics matrix back to stock. And that didn't fix the issue in this case 😕
                    • Exerqtorundefined Exerqtor has marked this topic as unsolved
                    • fcwiltundefined
                      fcwilt @Exerqtor
                      @exerqtor said in X axis moving the wrong way on a CoreXY:
                      EDIT:
                      You can fix the problem by changing wiring, etc but it seems to me that adding one minus sign to the config.g file is a simpler approach.
                      And it works.
                      • Exerqtorundefined
                        Exerqtor @fcwilt
                        @fcwilt but like i can't shake the feeling of something having to be out of whack since i have to change up the wiring from how it's "supposed to be" , or to derp with the standard kinematics to make it behave like i want it to 😂
                        • fcwiltundefined
                          fcwilt @Exerqtor
                          I've always changed the matrix - it's simple, quick and easy.
                            dc42 administrators @fcwilt
                            Either method will work.
