    Maestro Expansion Board driver not working
    • xstainzxundefined
      xstainzx
      i am trying to get the expansion board running on the Duet Maestro. For me it seems like the pinout for the steppers is different on the expansion board in comparison to the onboard drivers. So i cant simply plug a Stepper from the onboard driver on the expansion Board driver and have to swap the phases on the cable right?
      I am running klipper and all other drivers (onboard) are working fine.
      • rjenkinsgbundefined
        rjenkinsgb
        No, the middle two are reversed.
        The simplest alternative to swapping wires would be to get some extra plugs and sockets, then make up some short adapter cables with the middle two pins swapped.
        eg. Something like these:
        https://www.ebay.co.uk/itm/301876749335
        Robert J.
        Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
          dc42 administrators @xstainzx
          @xstainzx I've never noticed that before! I suspect it is just a naming difference and you won't have to change the wiring. The expansion board wasn't designed by Duet3D so it may have different naming conventions. I will check and report back.
          dc42undefined 1 Reply Last reply Reply Quote 1
            dc42 administrators @dc42
            As I suspected, it's just a difference in nomenclature. The motor pin connections for the expansion board are the same as for the main board, i.e. connect the 2 wires from to one phase of the motor at one end of the 4-pin connector, and the 2 wires from the other motor phase at the other end.
            The confusion arises because Trinamic used a different nomenclature on their datasheets than most manufacturers of stepper motors use.
            xstainzxundefined 1 Reply Last reply Reply Quote 0
            • xstainzxundefined
              xstainzx @dc42
              @dc42 Thanks for confirmation. The different pin naming was really confusing...
