    Rr_download failing
    • tomasfundefined
      tomasf
      I have noticed that rr_download (clicking the download button in the web interface) seems to fail with large files. It cuts out somewhere half-way and inserts an HTTP response, with headers and all, in the middle of the file data. I tried running it in curl:
      [c]curl "http://172.24.1.100/rr_download?name=%2Fgcodes%2FAnimals%2Fowl.gcode"[/c]
      [c][…tons of of G-code...]
      G1 Z9.028 F3600
      G1 X-2.120 Y21.120 F9000
      G1 Z8.928 F3600
      G1 E0.0000 F360HTTP/1.1 200 OK
      Cache-Control: no-cache, no-store, must-revalidate
      Pragma: no-cache
      Expires: 0
      Content-Type: application/json
      Content-Length: 9
      Connection: close
      curl: (18) transfer closed with 31668467 bytes remaining to read
      {"err":1}[/c]
      Is this a known bug? Thanks!
        I've just tried downloading some large files via the web interface, and they fail at around 2.5Mb with a similar symptom. Also the web interface disconnects. I didn't implement rr_download, but I'll take a look at the code when I get more time.
        • Merlinundefined
          Merlin
          Excuse my ignorance but where is the Web Interface [Download] meant to Download to?
          If on the PC what Path & FileName?
          • StephenRCundefined
            StephenRC
            The download should default to where ever your browser is set for.
            • Merlinundefined
              Merlin
              Now I see why I could not find my 'Download' it always save it as rr_download.txt
              or rr_download-<n>.txt if you take the [Create New File] option instead of overwrite.</n>
