    Upgrade from Duet 0.8.5 to Duet Ethernet
    • darkstarone
      darkstarone last edited by
      How hard is it to upgrade from Duet 0.8.5 to Duet Ethernet? Anything significantly different connector wise or anything else I should watch out for?
      Thanks
      • T3P3Tony
        It's pretty straightforward, the Ethernet connector is at slightly different position. The majority of the connectors are MolexKK which you probably already have. We supply a connector pack so you can change any to KK if you need to.
        Duet Hardware Designer
        www.duet3d.com
        • darkstarone
          Awesome, thanks
