    Homing issue on IDEX
    504
    • make_shake99undefined
      make_shake99
      Hello All,
      I'm having an issue with Z homing after I print with my tool1. So I noticed when trying to calibrate dual extrusion that if tool 1 is the last tool to print the next time I home it tries to use the U carriage to probe for Z. My probe is on the X carriage tool 0. All other times it probes correctly. I'm using cura 4.11 and firmware version 3.3 my machine is a custom built idex cartesian layout.
      Thanks in Advanced
      • fcwiltundefined
        fcwilt @make_shake99
        @make_shake99
        Please post your configuration and homing files.
        Please use the </> tag to post each file separately. Click on the </> icon then copy-and-paste the contents of each file where it say code_text
        Thanks.
        make_shake99undefined 1 Reply Last reply Reply Quote 0
          make_shake99 @fcwilt
          @fcwilt
          ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.4 on Sat Oct 23 2021 12:57:10 GMT-0400 (Eastern Daylight Time)
          M575 P1 S1 B57600                                ; enable support for PanelDue
          G90                                              ; send absolute coordinates...
          M83                                              ; ...but relative extruder moves
          M550 P"Viper_3D"                                 ; set printer name
          ; Wait a moment for the CAN expansion boards to start
          G4 S2
          M552 S1                                          ; enable network
          M586 P0 S1                                       ; enable HTTP
          M586 P1 S0                                       ; disable FTP
          M586 P2 S0                                       ; disable Telnet
          M569 P0.0 S0                                     ; physical drive 0.0 goes backwards
          M569 P0.1 S1                                     ; physical drive 0.1 goes forwards
          M569 P0.2 S0                                     ; physical drive 0.2 goes backwards
          M569 P0.3 S1                                     ; physical drive 0.3 goes forwards
          M569 P121.0 S0                                   ; physical drive 121.0 goes forwards
          M569 P122.0 S1                                   ; physical drive 122.0 goes forwards
          M584 X0.0 Y0.2 Z0.3 U0.1 E121.0:122.0                 ; set drive mapping
          M350 X16 Y16 Z16 U16 E16:16 I1                       ; configure microstepping with interpolation
          M92 X200.00 Y160.00 Z1300.00 U200.00 E660.00:660.00      ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 U900.00 E300.00:300.00       ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 U6000.00 E3600.00:3600.00  ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 U500.00 E600.00:600.00       ; set accelerations (mm/s^2)
          M906 X1200 Y1200 Z1500 U1200 E1000:1000 I30            ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                          ; Set idle timeout
          M208 X0 Y-4 Z0 U31 S1                               ; set axis minima
          M208 X470 Y500 Z490 U497.4 S0                           ; set axis maxima
          M574 X1 S1 P"!io2.in"                            ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !io2.in
          M574 Y1 S1 P"!io3.in"                            ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !io3.in
          M574 Z1 S2                                       ; configure Z-probe endstop for low end on Z
          M574 U2 S1 P"!io1.in"                            ; configure switch-type (e.g. microswitch) endstop for high end on U via pin !io1.in
          M950 S0 C"121.io0.out"                           ; create servo pin 0 for BLTouch
          M558 P9 C"^121.io0.in" H5 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X-38 Y-13 Z2.75                         ; set Z probe trigger value, offset and trigger height
          M557 X40:460 Y40:450 S40                        ; define mesh grid
          M308 S0 P"temp0" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out0" T0                               ; create bed heater output on out0 and map it to sensor 0
          M307 H0 B1 S2.00                                 ; enable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                          ; map heated bed to heater 0
          M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
          M308 S1 P"121.temp0" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin 121.temp0
          M950 H1 C"121.out0" T1                           ; create nozzle heater output on 121.out0 and map it to sensor 1
          M307 H1 B0 R1.899 C260.7:211.4 D8.27 S1.00 V23.5                                 ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S350                                     ; set temperature limit for heater 1 to 350C
          M308 S2 P"122.temp0" Y"pt1000" R2200             ; configure sensor 2 as PT1000 on pin 122.temp0
          M950 H2 C"122.out0" T2                           ; create nozzle heater output on 122.out0 and map it to sensor 2
           M307 H2 B0 R1.714 C203.4:187.5 D6.32 S1.00 V23.8                                ; disable bang-bang mode for heater  and set PWM limit
          M143 H2 S350                                     ; set temperature limit for heater 2 to 350C
          M950 F0 C"121.out1" Q500                         ; create fan 0 on pin 121.out1 and set its frequency
          M106 P0 S0 H-1                                   ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"121.out2" Q500                         ; create fan 1 on pin 121.out2 and set its frequency
          M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"122.out1" Q500                         ; create fan 2 on pin 122.out1 and set its frequency
          M106 P2 S1 H-1                                   ; set fan 2 value. Thermostatic control is turned off
          M950 F3 C"122.out2" Q500                         ; create fan 3 on pin 122.out2 and set its frequency
          M106 P3 S1 H2 T45                                ; set fan 3 value. Thermostatic control is turned on
          M563 P0 S"hotend 0" D0 H1 F0                     ; define tool 0
          G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
          G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
          M563 P1 S"hotend 1" D1 H2 X3 F2                     ; define tool 1 to use U
          G10 P1 X0 Y0 Z0                                  ; set tool 1 axis offsets
          G10 P1 R0 S0                                     ; set initial tool 1 active and standby temperatures to 0C
          ''' Create a tool that prints 2 copies of the object using both carriages'''
          M563 P2 S"dual ext" D0:1 H1:2 X0:3 F0:2 ; tool 2 uses both extruders, hot end heaters and fans, and maps X to both X and U
          G10 P2 X40 Y0 U-40 S0 R0 ; set tool offsets and temperatures
          M567 P2 E1:1 ; set mix ratio 100% on both extruders
          M568 P2 S1 ; turn on mixing for tool 2
          ; homeall.g
          ; called to home all axes
          G1 H2 Z5 F6000          ; lift Z relative to current position
          G1 H1 X-475 Y-505 U500 F3000 ; move quickly to X and Y and U axis endstops and stop there (first pass)
          G1 H2 X5 Y5 U5 F6000       ; go back a few mm
          G1 H1 X-475 Y-505 U500 F360  ; move slowly to X and Y and U axis endstops once more (second pass)
          G1 X80 Y40 F6000        ; go to first bed probe point and home Z
          G30                     ; home Z by probing the bed
          G1 X0 Y0 F1200				; return to X and Y to 0
          ;G91                    ; relative positioning
          ;G1 Z5 F100             ; lift Z relative to current position
          ;G90                    ; absolute positioning
          ; homeu.g
          ; called to home the U axis
          G1 H1 U500 F1800 ; move quickly to U axis endstop and stop there (first pass)
          G1 H2 U-5 F6000    ; go back a few mm
          G1 H1 U500 F360  ; move slowly to U axis endstop once more (second pass)
          G1 H2 Z-5 F6000   ; lower Z again
          ; homex.g
          ; called to home the X axis
          G1 H1 X-475 F1800 ; move quickly to X axis endstop and stop there (first pass)
          G1 H2 X5 F6000    ; go back a few mm
          G1 H1 X-475 F360  ; move slowly to X axis endstop once more (second pass)
          ; homey.g
          ; called to home the Y axis
          G1 H1 Y-505 F1800 ; move quickly to Y axis endstop and stop there (first pass)
          G1 H2 Y5 F6000    ; go back a few mm
          G1 H1 Y-505 F360  ; move slowly to Y axis endstop once more (second pass)
          ; homez.g
          ; called to home the Z axis
          G1 U500 F2000 ; make sure the U carriage is out of the way
          G1 X80 Y40 F6000 ; go to first probe point
          Here you go
          oliofundefined 1 Reply Last reply Reply Quote 1
          • oliofundefined
            oliof @make_shake99
            @make_shake99 I'd recommend to unselect all tools at the end of a print so they get parked correctly with T-1. In addition, add T0 P0 at the beginning of homez.g and homeall.g, adding T-1 at the end again for a well defined state and no tool selected
            make_shake99undefined 2 Replies Last reply Reply Quote 2
              make_shake99 @oliof
              @oliof
              Thank you I'll give that a shot later today.
              • fcwiltundefined
                @make_shake99
                I also noticed in your homeALL.g file in the G1 H2 command to backoff from the endstops the U value is wrong based on the U values in the G1 H1 commands.
                make_shake99undefined 2 Replies Last reply Reply Quote 0
                  @fcwilt
                  Yea likely is I've been trying to tune in my nozzle distance and haven't cleaned those up.
                    @fcwilt
                    Thanks I was able to take care of the back off. Works like a champ. I kind of noticed it didn't seem to back off but with tuning out my other issues, I never looked into that.
                    Thanks again.
                      make_shake99 @oliof
                      @oliof
                      did the trick thanks so much
                      • make_shake99undefined make_shake99 referenced this topic
