Loosing steps when running homeall.g
The small annoying issues keep proving hard to iron out.
When i run homeall.g at least the x axis loose a couple steps (can hear it "rattle" even) when it backs of the endstops after the first pass off homing.
I can't replicate this if i run only homex.g or homey.g.Anyone got a clue? (Running latest pre-release / beta on everything).
homeall.g:
; homeall.g ; called to home all axes ; M98 P"/macros/System/Speed/speed_probing.g" ; Apply low speed & accel M98 P"/macros/System/Current/xy_current_low.g" ; Apply low XY currents M98 P"/macros/System/Current/z_current_low.g" ; Apply low Z currents M561 ; ignore current heightmap G91 ; relative positioning G1 H2 Z10 F6000 ; lower Z(bed) relative to current position) G1 H1 X370 Y370 F1800 ; move quickly to X or Y endstop (first pass) G1 H1 X370 ; home X axis G1 H1 Y370 ; home Y axis G1 H2 Y-5 F1800 ; go back a few mm G1 H2 X-5 ; go back a few mm G1 H1 X370 F360 ; move slowly to X axis endstop (second pass) G1 H1 Y370 ; then move slowly to Y axis endstop G90 ; absolute positioning M98 P"/macros/System/Home/move_over_microswitch.g" ; move above the Z endstop switch G30 K1 Z-99999 ; home Z by probing the bed M98 P"/macros/System/Speed/speed_printing.g" ; Restore normal speed & accel M98 P"/macros/System/Current/xy_current_high.g" ; Restore normal XY currents M98 P"/macros/System/Current/z_current_high.g" ; Restore normal Z currents
The low current settings for XY are 30% of 1400mA and the low speed/accel settings are :
M566 X900.00 Y900.00 Z20.00:20.00 P1 ; set maximum instantaneous speed changes (mm/min) and jerk policy M203 X18000.00 Y18000.00 Z3000.00:3000.00 ; set maximum speeds (mm/min) M201 X2000.00 Y2000.00 Z100.00:100.00 ; set accelerations (mm/s^2)
undefined Exerqtor marked this topic as a question
@exerqtor What sort of printer is this? You should not need to use H2 moves (in G1 H2 X-5) to move away from the endstops, they should at this point be homed, if this is a corexy you may only be moving one motor (rather than both).
That little typo there have caused way more cursing than one would think
. Fat finger-typing on the numpad ended up with them being H2 instead of H0, and of course that fixed all the issues, thanks dude!
undefined Exerqtor has marked this topic as solved
