    Raspberry Pi OS - Bullseye
    • oozeBotundefined
      oozeBot
      Curious if anyone else has installed Bullseye on their Duet machines yet? I spent some time this morning testing it out. Overall, it's been successful. The only thing I've run into so far is hardware encoding for the webcam isn't working as OMX and MMAL has apparently been depreciated in favor of V4L2, which will take time to implement..
      • chrishammundefined
        chrishamm administrators @oozeBot
        @oozebot There's a pretty experimental DuetPi build based on bullseye on https://pkg.duet3d.com/testing/ but I haven't been able to get the RPi display working yet (using the DSI cable, not sure about HDMI). It just turns white when it's supposed to start the GUI and I don't know yet what is causing that. The DuetPi-lite build appears to be working nicely, though.
        Duet software engineer
        • oozeBotundefined
          oozeBot
          I also just installed the 64-bit version of Bullseye on a machine. Running a test print now, but so far, so good..
          @chrishamm - I haven't run into that since we don't use displays directly connected to the Pi.
          • omtekundefined
            omtek
            I got aarm64 bullseye running on my RPi4b+ today, as well.
            I used the 2021-10-30-raspios-bullseye-arm64.zip image (from here) and flashed to an M.2 drive. After booting, updating, enabling SPI and increasing the buffer size (per here), then added the unstable sources.
            After copying back my configuration and doing one last reboot of SBC and Duet 3 Mini 5+, I was greeted with a working printer once again. Running a test print right now to see how everything is working.
            The only issue I see right off the bat, is the DuetPi management plugin, when attempting to start via 'Settings - Machine-specific - External Plugins' complains that:
            Failed to start plugin:
            InvalidOperationException in StartPlugin: Cannot perform command because the plugin service (root) is not started
            however, systemd reports:
            pi@legionXY:~ $ systemctl status duetpluginservice
            ● duetpluginservice.service - Duet Plugin Service
                 Loaded: loaded (/lib/systemd/system/duetpluginservice.service; enabled; vendor preset: enabled)
                 Active: active (running) since Thu 2021-11-11 14:29:25 EST; 1h 7min ago
               Main PID: 1046 (DuetPluginServi)
                  Tasks: 8 (limit: 4178)
                    CPU: 1.455s
                 CGroup: /system.slice/duetpluginservice.service
                         └─1046 /opt/dsf/bin/DuetPluginService
            Nov 11 14:29:23 legionXY systemd[1]: Starting Duet Plugin Service...
            Nov 11 14:29:24 legionXY DuetPluginService[1046]: Duet Plugin Service v3.4-b6
            Nov 11 14:29:24 legionXY DuetPluginService[1046]: Written by Christian Hammacher for Duet3D
            Nov 11 14:29:24 legionXY DuetPluginService[1046]: Licensed under the terms of the GNU Public License Version 3
            Nov 11 14:29:24 legionXY DuetPluginService[1046]: [info] DuetPluginService.Program: Settings loaded
            Nov 11 14:29:25 legionXY DuetPluginService[1046]: [info] DuetPluginService.Program: Connection established
            Nov 11 14:29:25 legionXY DuetPluginService[1046]: [info] DuetPluginService.Program: Plugin DuetPiManagementPlugin loaded
            Nov 11 14:29:25 legionXY DuetPluginService[1046]: [info] DuetPluginService.Program: Plugin InputShaping loaded
            Nov 11 14:29:25 legionXY systemd[1]: Started Duet Plugin Service.
            along with an error in /var/log/syslog
            Nov 11 15:35:07 legionXY DuetControlServer[429]: [error] IPC#189: Failed to execute StartPlugin
            Nov 11 15:35:07 legionXY DuetControlServer[429]:    System.InvalidOperationException: Cannot perform command because the plugin service (root) is not started
            Nov 11 15:35:07 legionXY DuetControlServer[429]:    at DuetControlServer.IPC.Processors.PluginService.PerformCommand(Object command, Boolean asRoot) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/IPC/Processors/PluginService.cs:line 69
            Nov 11 15:35:07 legionXY DuetControlServer[429]:    at DuetControlServer.Commands.StartPlugin.Start(String id, String requiredBy) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Commands/Plugins/StartPlugin.cs:line 130
            Nov 11 15:35:07 legionXY DuetControlServer[429]:    at DuetControlServer.Commands.StartPlugin.Execute() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Commands/Plugins/StartPlugin.cs:line 36
            Nov 11 15:35:07 legionXY DuetControlServer[429]:    at DuetAPI.Commands.Command.Invoke() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/Commands/BaseCommand.cs:line 46
            Nov 11 15:35:07 legionXY DuetControlServer[429]:    at DuetControlServer.IPC.Processors.Command.Process() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/IPC/Processors/Command.cs:line 88
            but I cannot glean any information beyond that.
            Let me know if I can provide any further information.
              chrishamm administrators @omtek
              @omtek Check duetpluginservice-root as well
              omtekundefined 1 Reply Last reply Reply Quote 0
              • omtekundefined
                omtek @chrishamm
                @chrishamm That was the problem!
                pi@legionXY:~ $ sudo systemctl enable duetpluginservice-root
                Created symlink /etc/systemd/system/multi-user.target.wants/duetpluginservice-root.service → /lib/systemd/system/duetpluginservice-root.service.
                pi@legionXY:~ $ sudo systemctl start duetpluginservice-root
                pi@legionXY:~ $
                Success!
