    SD Card questions and issues mounting
    PanelDue
    • po3plestormundefined
      po3plestorm
      So I have been running my duet 2 with this duet screen: https://www.amazon.com/gp/product/B085VZ6CKN/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
      And have pannel due version 3.3.0 running on it and have a intersting issue. I have the pannel connected to my board with a ribbon cable and use the sd card on the pannel for printing and it works great. But I have to access the sd card via the web app for it to mount. If I just plug the sd card into the pannel then try and go to the files on it nothing shows up under sd card 2. If I go on the web app and select sd card 2 the printer will mount the card and show me the files.
      Other than that everything works great on the pannel. Is there anyway to get the board to check for an sd card mounting or something to access the files without having to open the web app?
      droftartsundefined po3plestormundefined 2 Replies Last reply Reply Quote 0
      • po3plestormundefined po3plestorm marked this topic as a question
        dc42 administrators @po3plestorm
        @po3plestorm I think this is a known issue in recent PanelDue firmware and it may be fixed in the latest pre-release version.
        Edit: see https://github.com/Duet3D/PanelDueFirmware/issues/221.
        mfs12 created this issue in Duet3D/PanelDueFirmware
        closed Files on card button is not updated in files dialog #221
          droftarts administrators @po3plestorm
          @po3plestorm send M21 P1 to initialise the card. They don’t mount automatically. DWC sends this before trying to read the card. See https://duet3d.dozuki.com/Wiki/M21
            dc42 administrators @droftarts
            PanelDue should also mount the card automatically if you press the icon to display the second card. However, if you change the card while PanelDue is already displaying the files on the second card, then on Duet 2 it won't know that you have changed the card.
            po3plestormundefined 1 Reply Last reply Reply Quote 0
            • mfs12undefined
              mfs12
              there was also a bug fixed related to mounting sd cards.
              https://github.com/Duet3D/PanelDueFirmware/issues/207
              closed Wrong number for available sd card slots is use #207
              Visit me on github at https://github.com/mfs12/
                po3plestorm @dc42
                @dc42 so the second sd card button only appears after I mount the sd card via the web app, afterwards it is permanately there. Is there a way to get the board to run that mounting command on starup or get the button there?
                  • po3plestormundefined po3plestorm has marked this topic as solved
                    po3plestorm @po3plestorm
                    @po3plestorm I ened up just making a macro, ill update when the full release comes out.
                    Macro: Mount 2nd SD Card
                    M21 P1 ; mount the sd card
