    While printing Z axis is not going to the correct height
    • Duncanundefined
      Duncan
      Hello!
      I'm having problems with my machine.
      When I print, if layer height is 0,6mm the printer goes to 0,23mm in first layer. I check it in Web Control Panel and I really don't know why is happening that.
      On first tests I think it was working ok, and the only difference is that I use the mesh grid and now I load the mesh before printing (G29 S1)
      Any ideas?
      I
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @Duncan
        @duncan Check your slicer, you can set the first layer thickness. Unlesss you have the wrong steps per mm for Z.
        Duncanundefined 1 Reply Last reply Reply Quote 0
        • Duncanundefined
          Duncan @Stephen6309
          @stephen6309 I've just discovered the problem.
          In Simplify 3D I have in Gcode z offset in -1, so the Web panel starts in 0 but for gcode is really in -1, so first layer was 105% layer height of 0.6mm, thats 0,63mm, and second layer 0,6 more, thats 1,23mm, minus 1 because of the negative offset is the 0,23 that webpanel was showing me...
