    using while and loop and variable in Macro
    Gcode meta commands
    1.1k
    • CrazyCreatorundefined
      CrazyCreator
      I came up with a few lines of code with which I would like to try to let the neopixel stripes connected to the MB6HC "breathe" as long as the printer is idle.
      Unfortunately, my knowledge is currently more or less at NULL ... so I have absolutely no idea whether my lines of code work or whether they are in the correct syntax.
      I would prefer the whole thing as a macro, which starts when the printer is switched on and ends as soon as I turn on the heating and / or a print is running.
      maybe someone can help me with learning and solving.
      thanks
      Declare variable
      var <counter> = <int>
      var <down> = <bool>
      Fill variable
      var.counter = 1
      var.down = false
      while <heater.0 < 40>
      	if <var.counter> == 255
      		<var.down> = true
      	if <var.counter> == 0
      		<var.down> = false
      	if <var.down> == false
      		M150 …. P<var.counter> F0
      		var.counter = var.counter+1
      	if <var.down> == true
      		var.counter = var.counter-1
      http://www.crazycreatorcube.com
        dc42 administrators @CrazyCreator
        @crazycreator something like this may work if you put it in daemon.g assuming that sensor 0 is the bed thermistor:
        var counter = 1
        var down = false
        while sensors.analog[0].lastReading < 40
        	if var.down
        		set var.counter = var.counter-1
        		if var.counter == 255
        			set var.down = true
        	else
        		set var.counter = var.counter+1
        		if var.counter == 0
        			set var.down = false
        	G4 P100
        CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
          CrazyCreator @dc42
          @dc42 Many, many thanks for the feed, I have something to try and test and expand on. thanks.
          Is it imperative that I have to run it in a deamon.g, or could I also start it in a macro ... for testing the script or so.
          So the "breathing" of the led strip in idle should of course always run.
          I only ask if I want to program something similar for something else.
          First question:
          if I want to check var.down for true or false, then
          if var.down
          is enough to check the condition?
          /EDIT
          When I create a macro with this content:
          M150 X1 ; Define RGB NeoPixel (default in RRF 3.2 and later)
          var counter = 1
          var down = false
          	if var.down
          		M150 R255 U0 B0 S20 P<var.counter> F0
          			set var.down = true
          	else
          		if var.counter == 0
          	G4 P100
          Then nothing happens when I start it ...
            CrazyCreator @CrazyCreator
            can you explain to me why nothing happens when i start the macro?
            • fcwiltundefined
              fcwilt @CrazyCreator
              @crazycreator said in using while and loop and variable in Macro:
              if sensors.analog[0].lastReading >= 40 then the while loop will not run.
                CrazyCreator @fcwilt
                @fcwilt
                The heating is not on ... or there is not even one installed. Only one temperature sensor is connected.
                How can I display, for check, the result of sensors.analog[0].lastReading ???
                is this the right value? rounding in dwc I see 23°C
                • fcwiltundefined
                  @fcwilt
                  right before the line containing the while put this:
                  echo sensors.analog[0].lastReading
                  It will display a message showing the value. While the message will go away after a few seconds you can still see the result in the DWC Console.
                    @fcwilt said in using while and loop and variable in Macro:
                    i See the message in dwc but this is the only thing.
                    my macro:
                    ; R=Red / U=Green / B=Blue / P=Brightness (0-255)
                    var counter = 150
                    var down = true
                    	if var.down
                    			set var.down = true
                    	else
                    		if var.counter == 0
                    	G4 P100
                    When I change P<var.counter> to P155 the script is running actually endless 😄
                    and always in the same if ....
                    I think the variable var.counter will not be changed.
                    because if I change var down = true and var.down = false then it changes from the if to the else but it then gets stuck in it.
                    fcwiltundefined GeneRisiundefined 2 Replies Last reply Reply Quote 0
                    • fcwiltundefined
                      @crazycreator
                      If the while loop is not ending it is either because the sensor reading is not changing OR the firmware does not update the sensor reading in a while loop.
                      You could put code in daemon.g but that only runs once every 10 seconds.
                        @fcwilt
                        But that would be strange if the while loop only continues when the value of the sensor has changed.
                        the condition says if the value is less than 40 then run.
                        • fcwiltundefined
                          @fcwilt
                          What was the value displayed by the echo statement when you ran the macro?
                            @fcwilt 23
                            	if var.down
                            		echo var.counter
                            		if var.counter == 0
                            	else
                            		**echo var.counter**
                            			set var.down = true
                            	G4 P50
                            if I write an echo IN the loop and display the value of var.counter, then the outputs are perfectly counted. exactly as it should be, but the light does not come on.
                            if instead of P <var.counter> a fixed number is written in, the light goes on ... but then of course it doesn't breathe
                            if P <var.counter> the correct spelling?
                            • GeneRisiundefined
                              GeneRisi @CrazyCreator
                              @crazycreator Values passed to a macro are found using "param." parameter letter. So, if the macro was called with P155, you would access the value as param.p. You could do this in the beginning of your macro:
                              If exists(param.p)
                                 Set var.value = param.p
                              Else
                                 Set var.value = 150
                              Use var.value in the body of your macro.
                              Does that help ?
                              • fcwiltundefined
                                @crazycreator
                                Try using { and } instead of < and >.
                                CrazyCreatorundefined 1 Reply Last reply Reply Quote 1
                                  @fcwilt
                                  it lives ... it breathes
                                  the {} were the solution
                                  many many thanks: D
