    Using variables as GCode argument keys
    Gcode meta commands
    675
    • pfnundefined
      pfn
      I'm trying to write some gcode expressions like so:
      G1 {global.extruder_axis}2
      G1 {global.extruder_axis ^ "2"}
      G1 {"E2", "F600"}
      M92 {global.extruder_axis ^ global.extruder_steps}
      But all of these result in no action occurring, it seems that the gcode parser ignores the argument keys that evaluate as a result of the expression. (Basically, it's like G1 without arguments, or M92 without arguments).
      I have a workaround, but I really don't like it, is there something that can be done to support the above use-case? @dc42 thoughts?
      echo >"tmp.g" "G1 " ^ global.extruder_axis ^ 2
      M98 P"tmp.g"
      M400
      M30 "sys/tmp.g"
      fcwiltundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
      • pfnundefined
        pfn
        This post is deleted!
        • fcwiltundefined
          fcwilt @pfn
          @pfn
          Another work-around would be to pass a parameter with the desired axis and use that value in a series of IF statements.
          pfnundefined 1 Reply Last reply Reply Quote 0
          • pfnundefined
            pfn @fcwilt
            @fcwilt said in Using variables as GCode argument keys:
            @pfn
            This approach wouldn't work as there would be any axis, not XYZE. It could be any if UVWABCD and I don't want to repeat the same line of code for each with only the single letter changed.
            • fcwiltundefined
              fcwilt @pfn
              @pfn said in Using variables as GCode argument keys:
              Well it would work but if you don't care for it that is entirely up to you.
              • pfnundefined
                pfn @fcwilt
                @fcwilt it's not a scalable solution
                • T3P3Tonyundefined
                  T3P3Tony administrators @pfn
                  this is invalid, should be G1 {global.extruder_axis}^2
                  G1 {"E2", "F600"}
                  This should be G1 {"E2"^" "^"F600"}
                  However I have confirmed the core issue in tests, you cannot pass string arguments within gcode meta commands in the way you are trying to do. This impacts situations like this:
                  M92 {global.extruder_axis}^100
                  as well as the combinations you have used above.
                  however
                  M92 E{global.extruder_steps}
                  Should work.
                  Will flag this to @dc42.
                  www.duet3d.com
                  • T3P3Tonyundefined
                    @pfn we have updated the documentation to make this clear. :
                    https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands?#Section_Use_of_expressions_within_GCode_commands
                    And I will move this discussion to the firmware wishlist category.
                    www.duet3d.com
                    T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
                    • T3P3Tonyundefined
                      T3P3Tony administrators @T3P3Tony
                      @T3P3Tony leaving this here if it comes up in searches. There is a feature request for this here:
                      https://github.com/Duet3D/RepRapFirmware/issues/708
                      Related to this request:
                      https://forum.duet3d.com/topic/35660/passing-axis-letters-as-macro-parameters-to-m98
                      T3P3 created this issue in Duet3D/RepRapFirmware
                      open allow expressions to be used as a substitution for any part of a gcode string #708
                      www.duet3d.com
