    Passing Axis Letters As Macro Parameters to M98
    Gcode meta commands
    • davidjryanundefined
      davidjryan
      I have a non-3D printer, 13 axes CNC (M453) system.
      Is it possible to send an axis letter as a macro parameter through M98 and then use it in a G1 (or any) command?
      Say I want to have a single macro that will move any of my axes 5mm in the positive or negative direction. I want to use param.X and param.Y to signify axis letter and direction, respectively.
      Basic G-Code for forward and reverse (what I am trying to achieve through the macro):
      G91 G1 X5 F2000
      or
      G91 G1 X-5 F2000
      based on desired axis and direction, X could be Y, W, A, B, C, D, etc...
      I'd like to do this:
      M98 P"jog-axis.g" X"X" Y"Pos"
      or
      M98 P"jog-axis.g" X"X" Y"Neg"
      Contents of jog_axis.g:
      echo {param.X} ^ "  " ^ {param.Y}    ;just to confirm the macro inputs
      if {param.Y} = "Pos"
          echo "Positive"  ;confirm param.Y was interpreted correctly
          G91 G1 {param.X}5.0 F2000
      elif {param.Y} = "Neg"
          echo "Negative"  ;confirm param.Y was interpreted correctly
          G91 G1 {param.X}-5.0 F2000
      The jog_axis.g functon runs but the axis does not move and the console reports:
      Error: in file jog_axis.g line 12: Illegal parameter letter '-'
      So, it's interpreting the param.Y value and executing the correct condition. It's just not interpreting param.X as the axis letter for the G1 command and then, subsequently, the '-' in -5 is interpreted as a character/parameter out of place.
      If I put the 5.0 and -5.0 in {}, I can get the Error to go away but the axis still does not move.
      Am I doing anything wrong or am I trying to use a feature that does not currently exist?
      My alternative is to write 13(x2) conditionals for all of my axes. Not the end of the world but I thought passing the axis letter would be more elegant; 6 lines of code vs. 78.
      • T3P3Tonyundefined T3P3Tony referenced this topic
      • T3P3Tonyundefined
        T3P3Tony administrators @davidjryan
        @davidjryan this is not currently possible. It has been requested in the past and we have a feature request outstanding:
        https://github.com/Duet3D/RepRapFirmware/issues/708
        @davidjryan said in Passing Axis Letters As Macro Parameters to M98:
        Unfortunately this work around is how you need to do it for now.
        T3P3 created this issue in Duet3D/RepRapFirmware
        open allow expressions to be used as a substitution for any part of a gcode string #708
        www.duet3d.com
        davidjryanundefined 1 Reply Last reply Reply Quote 0
          davidjryan @T3P3Tony
          @T3P3Tony Thanks, Tony!
          I have the longer form implemented and all works well.
