    Mini 5 IP 10.0.0.14
    Using Duet Controllers
    • tecnoundefined
      tecno
      How do I get rid of this IP 10.0.0.14?? Should and have been 192.168.1.xxx
      • tecnoundefined
        tecno
        Found the solution, I parameter is poorly documented.
        • T3P3Tonyundefined
          T3P3Tony administrators @tecno
          @tecno please let me know what would make the documentation clearer.
          www.duet3d.com
          tecnoundefined 1 Reply Last reply Reply Quote 0
          • tecnoundefined
            tecno @T3P3Tony
            @t3p3tony
            I think it was in getting started with WiFi the I is mentioned but no explanation
              droftarts administrators @tecno
              @tecno The M587 I parameter is mentioned here https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s50 with a link to M587 in the Gcode dictionary straight after:
              If you have a Duet 2 WiFi or Duet 3 Mini 5+ WiFi, this is sufficient to enable networking and let your network router assign an IP address via DHCP. If you need to assign a static IP address, use M587 with the I parameter when setting up the SSID in Step 9. See M587 in the G-code dictionary.
              I guess you had set this before with M587 ... I10.0.0.14 ? Sending M587 on it's own lists the saved SSIDs, including any fixed IP address. Unfortunately the Guide format doesn't give much space for a long explanation of this, and it is covered in the Gcode dictionary, so I'm not planning any changes.
