    PanelDue Firmware 3.4.0-rc2 released
    PanelDue
    1
    • mfs12undefined
      mfs12
      Release Notes 3.4.0-rc2
      This release requires RepRapFirmware 3.4 or later.
      Version 2 (after August 2016) and Version 3 PanelDue are supported.
      • add cross-platform headless builds based on cmake
      • cleaned up dim/screensaver handling
      • removed compiler warnings
      • enabled Russian localization by default
      • enabled Ukrainian localization by default
      • improved list-locales tool for translation debugging
      • fixed displaying of M291 S2 and S3 if followed by M292
      • fixed displaying macro buttons in control tab
      • fixed setting of serial baud rate after reboot
      • cleaned up English
      • cleaned up Czech translation
      • cleaned up French translation
      • cleaned up German translation
      • fixed access to second sd card
      • cleaned up Russian translation
      • fixed persistent pressed button handling in some dialogs
      • fixed updates via RRF
      • fixed displaying of multiple heaters per tool
      • improved readme
      • fix brightness handling during pop-ups
      • disabled spammy debug information
      • show babystep button if printer is idle
      • cleaned up Spanish translation
      • change default feedrates
      • extend m291 popup to allow movement of other axis, up to 10
      • updated RRFLibraries
      • fixed babystep button alignment in setup tab
      • moved popup code into separate module
      • show connection loss in status
      • show warning when more than 2 malformed successive request responses are received
      • log status changes console
      Downloads and flashing instructions:
      Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.4.0-rc2
      Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
      Visit me on github at https://github.com/mfs12/
      • mfs12undefined mfs12 pinned this topic
      • mfs12undefined mfs12 referenced this topic
      • mfs12undefined mfs12 unpinned this topic
      • mfs12undefined mfs12 locked this topic
      • mfs12undefined
        mfs12
        New release available at https://forum.duet3d.com/topic/26276/paneldue-firmware-3-4-0-released/1.
