    Troodon to Duet3 conversion (kcress)
    • kcressundefined
      kcress
      Hi, After months of struggling with a flaky Vivendo Troodon 400 controller board and pretty much zero documentation available from tight-fisted FormBot I decided to take ownership of it and replace the controller.
      I snagged a Duet3 MB 6HC and a Duet3 EB 3HC.
      They're mounted and I have the steppers re-connectored and installed.
      Driver0 A-stepper (Left rear on gantry)
      Driver1 B-stepper (Right rear on gantry)
      Driver2 Z axis Front Left
      Driver3 Z axis Rear Left
      Driver4 Z axis Rear Right
      Driver5 Z axis Front Right
      Driver0 on the 3HC Extruder
      OUT 0 Heater Bed
      OUT 1 Heater Extruder
      Temp 0 Bed
      Temp 1 Extruder
      OUT 7 Fan Pan (Blows air into control space)
      OUT 8 Fan Drivers (Blows air across the 6HC drivers)
      OUT 9 Fan Extruder (Hotend)
      Note: All fans are 24V, the HEPA fan is 24V @ 0.75A (!)
      I'd like to speed control the HEPA fan
      I'd also like to speed control the Print Cooling Fan.
      I believe they should be plugged into OUT 4-6. I can not find anywhere how to wire them to the 6HC. The "Connecting and configuring fans" wiki does not actually explain how to hook a speed controlled fan to the 6HC.
      I believe that 3/4A fan can be controlled by OUT 4-6. Can someone confirm that?
      Also I think this is where the Print Cooling fan would be driven. Same wiring question, how to a 6HC.
      Anything above questionable? Flat out bonkers?
      I'll sum up all my connections when I get this thing done so any others can use this like a guide for Troodons.
      Thanks for any input.
        Phaedrux Moderator @kcress
        @kcress said in Troodon to Duet3 conversion (kcress):
        Have you seen these pages?
        https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_IO
        For fan control you'd want to use a PWM capable pin, which would mean io 4,5,7
        kcressundefined 1 Reply Last reply Reply Quote 0
        • kcressundefined
          kcress @Phaedrux
          @phaedrux Thanks that did it.
          • droftartsundefined droftarts marked this topic as a question
          • droftartsundefined droftarts has marked this topic as solved
