    Z map with no probe
    1.0k
    • AZERATEundefined
      AZERATE
      Hello all. Long time listener, first time caller.
      I used several Duets on multiple machines over the years, but this one is perplexing.
      I'm doing a new build which is a hybrid of all FDM machines I've used, so I used the files for my older Duet Wifi to base my setup off of. However, the older machine uses a IR probe, and my new build uses a standard limit switch. Whenever I try to Home Z on either web interface or PanelDue, it instantnly goes to the Z map command screen when I thought I've already gotten rid of such commands in config.g. Also, the Z only moves a maximum of maybe 5mm before refusing commands without error codes.
      I can find Height Map still existing in the Settings>General>Plugins on the web interface, but I can't seem to delete it. Meanwhile, homez.g has a G30 quoting Probe.
      I'm best at mechanical builds, but this firmware stuff is really sticking it to me. Any Help?
      Thank you in advance.
      fcwiltundefined 1 Reply Last reply Reply Quote 1
      • fcwiltundefined
        fcwilt @AZERATE
        @azerate
        Hi we need to know what hardware and firmware you are using.
        And then we need to see your all of your configuration files. Please post them using the </> tag, one for each file.
        AZERATEundefined 1 Reply Last reply Reply Quote 0
        • AZERATEundefined
          AZERATE @fcwilt
          @fcwilt
          Like I said, I'm a first time user on the forum, so sorry if this comes out wrong.
          Congi.g here
          ;; Communications
          ;; Disable debugging output.
          M111 S0
          ;; Machine name, which will be displayed on the LCD screen. Please note that
          ;; this setting does not change the name of your printer as seen by your WiFi
          ;; router, as this setting is stored on the WiFi chip.
          M550 PIcarus
          ;; Set the IP address of the printer. '0.0.0.0' means the printer should use
          ;; the DHCP server on your WiFi router to get an IP address. In most cases,
          ;; this will work without any trouble. If this does not work and you do not
          ;; have control over the network you are trying to use, contact your system
          ;; administrator for assistance.
          M552 P0.0.0.0
          ;; Set the netmask. '255.255.255.0' is the correct setting for most cases.
          ;; If this doesn't work for you and you don't have control of your network,
          ;; contact your system administrator for assistance.
          M553 P255.255.255.0
          ;; Use Marlin-like output for GCode responses. If you use an alternative host
          ;; to control your Horizon H1, select "Marlin" for the firmware type.
          M555 P2
          ;; For LCD Screen (PanelDue): Require checksums (S1) and set the serial port
          ;; to 57600 baud.
          M575 P1 B57600 S1
          ;; Set the password for all external interfaces into the machine such as the
          ;; web interface, telnet, etc. The default password is "printit". To override,
          ;; issue M551 P<your password without spaces or special characters> and then
          ;; issue M500 to save your changes.
          M551 Pprintit
          ;; Enable the WiFi chip on the board. This command will cause the WiFi chip
          ;; to connect to its configured network (if set and the network is responsive).
          ;; If the network cannot be reached or no network has been
          ;; configured yet, this command will create a WiFi hotspot
          ;; named "Duet Wifi." You can connect to this access point
          ;; and configure your Horizon H1. After connecting to the "Duet WiFi" network,
          ;; go to http://192.168.1.1 and follow the instructions.
          M552 S1
          ;; Motion configuration
          ;; Configure drive mapping for Z. Z uses four stepper motors moving together,
          ;; connected to drives 5, 6, 7 and 8 on the Duex2 expansion board.
          ;; In clockwise order from the front of the machine, drive 5 is the back right
          ;; motor, 6 is the front right motor, 7 is the front left motor and 8 is the
          ;; back left motor.
          M584 Z5:6:7:8
          ;; Endstop configuration.
          ;; We home the machine at X,Y min (X1 Y1) using mechanical endstops.
          ;; Z has a max endstop (Z1).
          ;; We use normally-closed switches (S1).
          M574 X1 Y1 Z1 S1
          ;; Obey build volume dimensions by default.
          M564 S1
          ;; Set units to millimeters.
          G21
          ;; Use absolute coordinates.
          G90
          ;; Set minimum travel (S1) for each axis.
          ;; (-22.5, 0, 0) is the homing position for the Horizon H1.
          M208 X0 Y0 Z0 S1
          ;; Set the build volume to 355 mm x 240 mm x 248 mm.
          M208 X255 Y240 Z177
          ;; Set drive directions. All steppers are connected to the board in the same
          ;; orientation at the factory. The firmware defines the proper step direction
          ;; for each motor.
          ;; X motor goes forward
          M569 P0 S1
          ;; Y motor goes backward
          M569 P1 S0
          ;; Z motor goes forward
          M569 P2 S1
          ;; Extruder (E0) motor goes forward
          M569 P3 S0
          ;; Set motor currents for X, Y, Z and extruder (E0) in milliamps.
          ;; We use a 100% idle current (I1) so that the motors remain locked once
          ;; enabled.
          ;; We set Z separately from the rest to ensure it is set correctly despite our
          ;; mapping of the Z drives.
          M906 X1400 Y1400 E950 I100
          M906 Z1400
          ;; Define steps per millimeter for X, Y Z and extruder (E0).
          M92 X80 Y80 Z160 E281.38
          ;; Set acceleration in mm/s^2 for X, Y Z and extruder (E0).
          M201 X5000 Y5000 Z2000 E10000
          ;; Set the maximum speed in mm/min for X, Y, Z and extruder (E0).
          ;; X, Y at 30000 mm/min = 500 mm/s
          ;; Z at 240 mm/min = 4 mm/s
          ;; E at 2000 mm/min = 33 mm/s
          M203 X30000 Y30000 Z2000 E2000
          ;; Set the maximum standing start ("jerk") speed in mm/min for X, Y, Z and
          ;; extruder (E0).
          ;; X, Y at 1800 mm/min = 30 mm/s
          ;; Z at 150 mm/min = 2.5 mm/s
          ;; E at 30 mm/min = 0.5 mm/s
          M566 X1800 Y1800 Z150 E30
          ;; Heater and Thermistor Configuration
          ;; Set the maximum HotEnd temperature to 290C.
          ;; Reaching 300C or above WILL damage the thermistor in your E3D v6!
          M143 S290
          ;; Bed thermistor configuration for the Cantherm MF52A1104F4150 thermistor
          ;; on Calidum HALE 8" x 8" 12v heat bed.
          ;; Datasheet URL: http://www.cantherm.com/media/productPDF/cantherm_mf52_1.pdf
          M305 P0 T100000 B4150 R4700 H0 L0
          ;; Extruders (E0) - E3D v6 thermistor configuration for the Semitec
          ;; 104GT-2 thermistor.
          ;; Datasheet URL: http://www.atcsemitec.co.uk/gt-2-glass-thermistors.html
          ;; E3D Wiki page listing the recommended B and C values:
          ;; https://wiki.e3d-online.com/wiki/E3D-v6_Assembly
          M305 P1 T100000 B4725 C7.06e-8 R4700 H0 L0
          ;; Give extruder 3 minutes to reach the target temperature. If it does not,
          ;; trigger a heater fault (cancel all heating).
          M570 S180
          ;;Extruder (E0) uses drive 0, heater 1.
          M563 P0 D0 H1
          ;; Extruder uses 1.75 mm filament and a 0.6 mm nozzle stock.
          M404 N1.75 D0.6
          ;; Set heating process parameters for the Calidum HALE 8" x 8" 12v
          ;; Retrieved using the following commands:
          ;; M303 H0 S100
          ;; M307 H0
          M307 H0 A139.8 C516.6 D7.7 S1.00 B0 ; B0 disables bang-bang
          ;; Set heating process parameters for the E3D v6 12v
          ;; M106 S255
          ;; M303 H1 S245
          ;; M307 H1
          M307 H1 A438.8 C154.1 D6.0 S1.00 B0 ; B0 disables bang-bang
          M307 H2 A438.8 C154.1 D6.0 S1.00 B0 ; B0 disables bang-bang
          ;; Operate fan 1 in thermostatic mode, activating when the extruders
          ;; (E0) get at or above 45C.
          M106 P1 T45 H1
          ;; Set bed and HotEnd active/standby temperatures to zero, and
          ;; configure nozzle offsets. P0 is the left nozzle, and P1 is the right
          ;; nozzle, corresponding to extruder drives E0 and E1.
          M140 S0
          G10 P0 S0 R0 X9 Y-9
          ;;Activate tool 0 (E0), as it is the only extruder on the machine
          T0
          ;; Load additional settings from config-override.g, if it exists. You should
          ;; use config-override.g to change settings, instead of altering this file.
          M501
          homez.g here
          ;; Use relative coordinates.
          G91
          ;; Move Z down 10 mm and obey max limit switch.
          G1 Z10 F240 S1
          G90
          ;; Move probe to X20 Y-02 (based on X0 Y12 offset)
          G1 X20 Y-02 F3600
          ;; Probe.
          G30
          ;; Move Z to nozzle.
          G1 Z0 F200/>
          Thanks again
          • fcwiltundefined
            fcwilt @AZERATE
            Based on your config commands it seems you are using a v2 firmware?
            Also you say you are not using a Z probe but you have a G30 command in your Z homing code - G30 commands for for Z probes.
              Please send M122 and report the results so we can see your hardware and firmware version.
              Is the microswitch being used as an endstop for the Z axis mounted to the frame, or is it supposed to be a probe mounted to the print head?
              AZERATEundefined 2 Replies Last reply Reply Quote 0
              • AZERATEundefined
                AZERATE @Phaedrux
                @phaedrux
                Thanks for the response. The switch is indeed being used as an endstop for Z and is mounted to the frame. If I delete the G30 command that should get rid of the Z Map commands from popping up, right?
                Phaedruxundefined 1 Reply Last reply Reply Quote 1
                • AZERATEundefined
                  AZERATE @Phaedrux
                  @phaedrux
                  For some reason I can't post the M122 results without being flagged for spam
                  droftartsundefined 1 Reply Last reply Reply Quote 1
                    droftarts administrators @AZERATE
                    @azerate I’ve upvoted a few of your posts, so you should be able to post now.
                      Phaedrux Moderator @AZERATE
                      @azerate said in Z map with no probe:
                      I'm not exactly sure what you mean by z map commands. Can you show a photo of what you're seeing?
                      • AZERATEundefined
                        AZERATE @Phaedrux
                        @phaedrux
                        M122 results
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
                        Board ID: 0JD0M-9P6M2-NW4SN-6JKD2-3SD6Q-9VTML
                        Used output buffers: 3 of 24 (7 max)
                        Static ram: 25712
                        Dynamic ram: 93684 of which 0 recycled
                        Exception stack ram used: 320
                        Never used ram: 11356
                        Tasks: NETWORK(ready,628) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3800) IDLE(ready,160)
                        Owned mutexes:
                        Last reset 00:28:45 ago, cause: power up
                        Last software reset at 2021-11-24 18:50, reason: User, spinning module GCodes, available RAM 11284 bytes (slot 3)
                        Error status: 0
                        Free file entries: 10
                        MCU temperature: min 28.7, current 30.4, max 31.5
                        Supply voltage: min 12.0, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
                        Driver 5: standstill, SG min/max not available
                        Driver 6: standstill, SG min/max not available
                        Driver 7: standstill, SG min/max not available
                        Driver 8: standstill, SG min/max not available
                        Driver 9: standstill, SG min/max not available
                        Date/time: 2021-11-25 11:39:12
                        Slowest loop: 5.59ms; fastest: 0.07ms
                        Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                        === DDARing ===
                        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                        Heater 0 is on, I-accum = 0.0
                        Heater 1 is on, I-accum = 0.0
                        Segments left: 0
                        Movement lock held by null
                        http is idle in state(s) 0
                        telnet is idle in state(s) 0
                        file is idle in state(s) 0
                        serial is idle in state(s) 0
                        aux is idle in state(s) 0
                        daemon is idle in state(s) 0
                        queue is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Slowest loop: 15.75ms; fastest: 0.00ms
                        HTTP sessions: 1 of 8
                        - WiFi -
                        Network state is running
                        WiFi firmware version 1.23
                        WiFi MAC address 84:0d:8e:b3:02:04
                        WiFi Vcc 3.42, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 21728
                        WiFi IP address 192.168.0.5
                        WiFi signal strength -42dBm, reconnections 0, sleep mode modem
                        Also, thank you very much Ian
                        • AZERATEundefined
                          AZERATE @Phaedrux
                          @phaedrux
                          I'm sorry, Settings>General>Plugins there is a Height Map plugin. Also on the PanelDue, if I hit the little wavy icon just above Macro, it homes everything and starts to move like it wants to start mapping with the probe. I've just gone through all *.g files and deleted everything related to G30, so now it doesn't start trying to map with a non-existent probe, but I still can't move Z any further than 5mm past homed.
                          droftartsundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                            @azerate after removing the G30, you don’t have any Gcode homing the Z axis. You need a G1 H1 Z… move towards your Z micro switch.
                              That button would be running bed.g which would explain what you're seeing.
                              • AZERATEundefined
                                AZERATE @droftarts
                                @droftarts
                                Thanks a lot for the help. This is what I show in homez.g
                                So where should I put G1 H1 Z?0?
                                Sorry. Like I said, I'm great with the mechanical build, but I'm terrible with anything firmware related.
                                G91
                                G1 Z10 F240 S1
                                G90
                                G1 Z0 F200
                                  See some examples here: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_files
                                  • AZERATEundefined
                                    AZERATE @Phaedrux
                                    @phaedrux
                                    Perfect. That solves the no-probe issue.
                                    But I still can't move the Z motors. Any ideas?
                                      With the print head place safely away from the bed, send these commands to test movement
                                      G92 Z10
                                      G91
                                      G1 Z5 F100
                                      That should cause some z motor movement. If not, please post your config.g.
                                      This may also be a good time to think about upgrading your firmware from RRF2 to RRF3 before you get too far along.
                                      • AZERATEundefined
                                        AZERATE @Phaedrux
                                        @phaedrux
                                        No movement from any of the commands. here's my config.g
                                        ;; Communications
                                        M111 S0
                                        M550 PIcarus
                                        M552 P0.0.0.0
                                        M553 P255.255.255.0
                                        M555 P2
                                        ;; to 57600 baud.
                                        M575 P1 B57600 S1
                                        M551 Pprintit
                                        M552 S1
                                        ;; back left motor.
                                        M584 Z5:6:7:8
                                        M574 X1 Y1 Z1 S1
                                        M564 S1
                                        G21
                                        G90
                                        M208 X0 Y0 Z0 S1
                                        M208 X255 Y240 Z177
                                        ;; for each motor.
                                        M569 P0 S1
                                        M569 P1 S0
                                        M569 P2 S1
                                        M569 P3 S0
                                        ;; enabled.
                                        M906 Z1400
                                        M92 X80 Y80 Z160 E277.6
                                        ;; extruder (E0).
                                        M143 S290
                                        M570 S180
                                        M563 P0 D0 H1
                                        M404 N1.75 D0.6
                                        ;;      M303 H0 S100
                                        ;;      M307 H0
                                        ;;      M106 S255
                                        ;;      M303 H1 S245
                                        ;;      M307 H1
                                        M106 P1 T45 H1
                                        M140 S0
                                        G10 P0 S0 R0 X9 Y-9
                                        T0
                                        M501
                                        • fcwiltundefined
                                          fcwilt @AZERATE
                                          @azerate
                                          Your comment for the M584 command says you are using a Duex 2 board - is that correct? If it is you cannot connect 4 steppers.
                                          I think you should update your config file by:
                                          • adding X and Y to your M584 command
                                          • adding a M350 command
                                          • AZERATEundefined
                                            AZERATE @fcwilt
                                            @fcwilt
                                            That is correct. I suppose I should go down the list real quick.
                                            Duet Wifi (bought less than a year ago)
                                            Duex to expand for 4 Z motors
                                            PanelDue 7i
                                            I'm basically finishing the build from another printer that uses the same electronics, and have just been modifying the files piece by piece to make it reflect this particular machine (e.g. this machine is a single extruder, non-Core XY, no probe, etc.) Hope that clears it up a little.
