Strange layer offset on coreXY
Firmware installation
10
38
1.9k
  • undefined
    JoergS5 @DVD479
    @dvd479 I am wondering why your printout is so height, when it should be a cube. Either XY print much shorter than calculated or your Z layer heights are heigher than 20 mm. Can you please tell me the dimensions of the printouts?
    Do you have any gears at X, Y or Z steppers or Nema steppers with 400 instead of 200 steps?
    • undefined
      JoergS5 @DVD479
      @dvd479 Something is wrong with your config.g:
      M669 K1 ; switch to CoreXY mode
      M569 P5 T2.5:2.5:5:5 S0 ; physical drive 0 goes backwards
      M569 P6 T2.5:2.5:5:5 S1 ; physical drive 1 goes backwards
      M584 X6 Y5 Z7 E8 ; set drive mapping
      Z7 and E8 have no mapping to steppers, there are no M569 definitions.
      M350 Z2 with M92 Z80 is also a strange combination, what do you use for Z?
      • undefined
        mrehorstdmd
        Photos of the printer...?
        • undefined
          DVD479
          the stl file represents a cube with 20mm side, for the z I had used M350 Z2 combined with M92 Z80 as I set the driver at 400 microstep and having a screw with 5mm pitch doing the calculation should result 400/5 = 80 which it should be the microsteps needed by the Z to move 1mm,
          the strange thing is that the cube is 20mm high and the sides are also 20mm the difference is in the printing angle which with slic3r is much lower while with CURA the deviation is greater
          thanks for the tips
          ? undefined 2 Replies Last reply 29 Nov 2021, 15:15 Reply Quote 0
          • undefined
            JoergS5
            your print bed could also move,resulting in this shift. Or while printing the object is moved. Images would definitely help now to think about possible reasons.
            About slic3r versus Cura, the g-code files have some different settings like bed temperature and filament temperature are different, this can be a reason. Thermal expansion of the bed e.g.
            ? 1 Reply Last reply 29 Nov 2021, 12:47 Reply Quote 0
              A Former User @JoergS5
              @joergs5
              So I have also layer shifts BUT ONLY when I´m switching tools.
              May we have a similar problem.....
              I slice with cura.
              Richard
              undefined 1 Reply Last reply 29 Nov 2021, 14:35 Reply Quote 0
              • undefined
                JoergS5 @A Former User
                @gruna-studio please talk with @DVD479 , he has the problem.
                  A Former User @DVD479
                  @dvd479 So I have also layer shifts BUT ONLY when I´m switching tools.
                  I slice with cura.
                  Richard
                  Any news?
                  I´m also frustrated about the offset.
                  • undefined
                    deckingman @DVD479
                    @dvd479 At what angle is the part sloping with respect to the build plate? By that I means, does it slope front to back, left to right, or at 45 degrees to X and Y? A picture of the machine with the completed part on the build plate would be a great help.
                    • undefined
                      Phaedrux Moderator @mrehorstdmd
                      @mrehorstdmd said in Strange layer offset on coreXY:
                      I would try modifying the step/dir/en timing parameters in the M569 statements. You may be operating right at the limits or the external hardware. Try increasing the values until they are well above the minimum specs in the driver manual. In my sand table with servomotors I use
                      M569 P5 S1 R0 T4.0:5.0:6.0:12.0 ; drive 5 reverse, lo enable, timing parameters for servomotors
                      M569 P6 S1 R0 T4.0:5.0:6.0:12.0 ; drive 6 reverse, lo enable, timing parameters for servomotors
                      These values allow the motors to hit their back-emf speed limit of 3k rpm.
                      Some photos of the printer might be useful...
                      @DVD479 Have you taken a look at this yet?
                      • undefined
                        DVD479
                        first of all I want to thank all those who have given me useful advice to solve my problem. in conclusion it seems that the problem is solved using Slic3r and going to set the value of XY SIZE COMPENSATION after several attempts and in this way I was able to solve the positioning error and the 20mm cube was printed correctly. I just have to test if this procedure works with other more complex files but I think it can work.Screenshot (18).png
                        undefined 1 Reply Last reply 29 Nov 2021, 16:21 Reply Quote 0
                        • undefined
                          DVD479
                          Based on your experience, is this a valid solution or can cause problems on complex prints?
                          • undefined
                            mrehorstdmd @DVD479
                            @dvd479 It doesn't make any sense that that would fix the problem. Something else is wrong. XY size compensation is there to adjust things like hole sizes that print smaller than design size. It's essentially going to scale the print size slightly. That should not fix a layer shifting problem.
                            Keep looking.
                            • undefined
                              DVD479
                              thanks for the advice I will try to understand better what is the cause of the problem
                              • undefined
                                DVD479
                                in the end I realized that the problem was not due to that parameter as you told me. as solution I reduced the transition speed and everything was fine
                                thank you all
                                • undefined Phaedrux marked this topic as a question 30 Nov 2021, 16:43
                                • undefined Phaedrux has marked this topic as solved 30 Nov 2021, 16:43
                                33 out of 38
