    tool change - y slide?!?!
    • A Former User?
      A Former User
      hey community
      I have the problem, that y is moving in + direction in regularly moves.
      That only happens when changing tools while printing. BUT NOT when changing tools just (when nothing is printed) --> I changed more than 100 times when not printing. Everything fine....
      A few weeks ago, I have been printing with tool change for weeks without problems.
      With printing after a few layers the coupler has moved so far Y+ (see picuture) that the TC doesn´t fit anymore to collect a new tool. See picture.
      I already tried_
      • different cura version
      • update duet 3 and boards
      • it´s definetly not a physical problem
      Is there somebody who has/had the same problem?
      ---very happy for any suggestionens.
      Duet 3
      Send code...
      Status
      Idle
      Mode: FFF
      Tool Position
      X
      68.5
      Y
      10.0
      Z
      50.90
      C
      200.0
      Extruder Drives
      Drive 0
      186.0
      Drive 1
      895.1
      Drive 2
      0.0
      Speeds
      Requested Speed
      0 mm/s
      Top Speed
      0 mm/s
      Sensors
      Vin
      24.0 V
      V12
      12.2 V
      MCU Temperature
      41.6 °C
      Z-Probe
      0
       Tools
       Extra
       Control Heaters
      Tool	Heater	Current	Active	Standby
      Tool 0
      T0 - Load Filament	Heater 1
      off	27.0 °C
      0
      0
      Tool 1
      T1 - Load Filament	Heater 2
      standby	209.0 °C
      209
      209
      Tool 2
      T2 - Load Filament	n/a	n/a
      0
      0
      Bed	Heater 0
      active	62.9 °C
      63
      0
      Temperature Chart
      System Directory
      0:/sys/config.g
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Aug 02 2021 16:15:35 GMT+0200 (Mitteleuropäische Sommerzeit)
      G90                                                        ; send absolute coordinates...
      M83                                                        ; ...but relative extruder moves
      M550 P"Duet 3"                                             ; set printer name
      M552 S1 P192.168.2.108                                     ; Wifi
      G4 S4
      M574 C1 S3
      M574 C0 Z0  						; No C Z endstop
      M915 P1.2 C S0 F0 R1
      M569 P0.0 S1                                               ; physical drive 0.0 goes forwards
      M569 P0.1 S1                                               ; physical drive 0.1 goes forwards
      M569 P0.2 S0                                               ; physical drive 0.2 goes forwards
      M569 P0.3 S0                                               ; physical drive 0.2 goes forwards
      M569 P0.4 S0                                               ; physical drive 0.2 goes forwards
      M569 P0.5 S0                                               ; physical drive 0.2 goes forwards
      M569 P1.0 S0                                               ; physical drive 0.2 goes forwards
      M569 P1.2 S0                                               ; physical drive 0.2 goes forwards
      M569 P20.0 S0                                             ; physical drive 121.0 goes forwards
      M569 P21.0 S1                                             ; physical drive 122.0 goes forwards
      M569 P123.0 S1                                             ; physical drive 123.0 goes forwards
      M584 X1.0 Y0.0:0.1 Z0.2:0.3:0.4:0.5 C1.2 E20.0:21.0:123.0     ; set drive mapping
      M350 X128 Y128 Z128 E16:16:16 I1                              ; configure microstepping with interpolation
      M92 X1280.00 Y1280.00 Z5120.00 C91.022 E409.00:409.00:409.00          ; set steps per mm
      M566 X1800.00 Y1800.00 Z30.00 C3000 E3.00:3.00:3.00       ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z800.00 C5000 E6000.00:6000.00:6000.00 ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z500.00 C400 E2500.00:2500.00:2500.00         ; set accelerations (mm/s^2)
      M906 X1300 Y1300 Z2300 C400 E1000:1000:1000 I30                 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                    ; Set idle timeout
      M671 X-80:-80:930:930 Y-80:930:930:-80 S20 ; leadscrews at front left1 and n´back2. back rigth3 and front4
      M208 X-10 Y-89.4 Z0 S1                                      ; set axis minima
      M208 X860 Y890 Z850 S0                                  ; set axis maxima
      M574 X2 S1 P"^io3.in"                                      ; configure active-high endstop for high end on X via pin ^io3.in
      M574 Y2 S1 P"^io1.in"                                      ; configure active-high endstop for high end on Y via pin ^io1.in
      ; Z probe
      M558 P5 C"io2.in" H8 F2000 I0 T5000 	; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
      G31 P200 X5 Y30 Z0	 				    ; Set Z probe trigger value, offset and trigger height; Z probe
      M556 S50 X0 Y0 Z0                                         ; set orthogonal axis compensation parameters
      M557 X50:800 Y50:800 S37.5                             ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138               ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                         ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 R0.243 C586.2 D33.87 S1.00 V0                   ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                    ; map heated bed to heater 0
      M143 H0 S120                                               ; set temperature limit for heater 0 to 120C
      M308 S1 P"20.temp0" Y"thermistor" T100000 B4138            ; configure sensor 1 as PT1000 on pin 121.temp0
      M950 H1 C"out2" T1                                         ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 R1.553 C487.8 D10.35 S1.00 V0                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S250                                               ; set temperature limit for heater 1 to 250C
      M308 S2 P"21.temp0" Y"thermistor" T100000 B4138            ; configure sensor 2 as PT1000 on pin 122.temp0
      M950 H2 C"out1" T2                                         ; create nozzle heater output on 122.out0 and map it to sensor 2
      M307 H2 B0 B0 R1.553 C487.8 D10.35 S1.00 V0                ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S250                                               ; set temperature limit for heater 2 to 250C
      M308 S3 P"123.temp0" Y"pt1000" R2200                       ; configure sensor 3 as PT1000 on pin 123.temp0
      M950 H3 C"123.out0" T3                                     ; create nozzle heater output on 123.out0 and map it to sensor 3
      M307 H3 B0 S1.00                                           ; disable bang-bang mode for heater  and set PWM limit
      M143 H3 S250                                               ; set temperature limit for heater 3 to 250C
      M950 F0 C"20.out1" Q500                                   ; create fan 0 on pin 121.out1 and set its frequency
      M106 P0 S0 H-1                                             ; set fan 0 value. Thermostatic control is turned off
      M563 P0 D0 H1                                              ; tool uses extruder 0, heater 1
      M950 F1 C"20.out2" Q500                                   ; create fan 1 on pin 121.out2 and set its frequency
      M106 P1 S1 H1 T45                                          ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F1                                           ; tool uses extruder 0, heater 1
      M950 F2 C"21.out1" Q500                                   ; create fan 2 on pin 122.out1 and set its frequency
      M106 P2 S1 H-1                                             ; set fan 2 value. Thermostatic control is turned off
      M950 F3 C"21.out2" Q500                                   ; create fan 3 on pin 122.out2 and set its frequency
      M106 P3 S1 H2 T45                                          ; set fan 3 value. Thermostatic control is turned on
      M950 F4 C"123.out1" Q500                                   ; create fan 4 on pin 123.out1 and set its frequency
      M106 P4 S1 H-1                                             ; set fan 4 value. Thermostatic control is turned off
      M950 F5 C"123.out2" Q500                                   ; create fan 5 on pin 123.out2 and set its frequency
      M106 P5 S1 H3 T45                                          ; set fan 5 value. Thermostatic control is turned on
      M950 F6 C"out4" Q500                                       ; create fan 6 on pin out4 and set its frequency
      M106 P6 S1 H-1                                             ; set fan 6 value. Thermostatic control is turned off
      M950 F7 C"out5" Q500                                       ; create fan 7 on pin out5 and set its frequency
      M106 P7 S1 H T45                                           ; set fan 7 value. Thermostatic control is turned on
      M950 F8 C"out8" Q500 CMagnet0                              ; create magnet 0  on pin out9 and set its frequency
      M950 F9 C"out9" Q500 CMagnet1                              ; create magnet 0  on pin out9 and set its frequency
      M950 F10 C"1.out6" Q500 CMagnet2                           ; create magnet 0  on pin out9 and set its frequency
      M950 F11 C"out7" Q500 CMagnet3                           ; create magnet 0  on pin out9 and set its frequency
      M563 P0 D0 H1 F0                                           ; define tool 0
      G10 P0 X-29.8 Y-28.65 Z-39.65                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                               ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 D1 H2 F2                                           ; define tool 1
      G10 P1 X-29 Y-28.45 Z-40                                ; set tool 1 axis offsets
      G10 P1 R0 S0                                               ; set initial tool 1 active and standby temperatures to 0C
      M563 P2 D2 H3 F4                                           ; define tool 2
      G10 P2 X0 Y0 Z0                                            ; set tool 2 axis offsets
      G10 P2 R0 S0                                               ; set initial tool 2 active and standby temperatures to 0C
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"         ; set voltage thresholds and actions to run on power loss
      • T3P3Tonyundefined
        T3P3Tony administrators @A Former User
        @gruna-studio please post the bit of gcode in a print that recreates this
        www.duet3d.com
        • A Former User?
          A Former User @T3P3Tony
          @t3p3tony
          I can only upload 4mb to the forum. the file has 10mb.... 😕
          • T3P3Tonyundefined
            @gruna-studio it looked like it happened at a particular point in the file, can you cut down the file to just after the issue occurred (worked out from the Z height or layer)
            www.duet3d.com
            Nxt-1undefined 1 Reply Last reply Reply Quote 0
            • Nxt-1undefined
              Nxt-1 @T3P3Tony
              @t3p3tony I am working with gruna-studio to investigate the issue. To test some stuff I made a short script that does about 10 changes back and forth with some moves inbetween. This was confirmed to cause the issue as well.
              MoveTC10_test.gcode
              To furter elaborate on the issue. Toolchanges seem to cause a growing y-offset, eventually leading to the toolchanger failing to pickup a tool and leaning prints. IIRC, a re-home of the axis resolves the issue. Also manually changing tools (selecting in DWC) many times does not seem to reproduce the issue.
              Duet3D and delta printer enthousiast. Buildlog
              Looking for Duet3D configuration support, check out Nxt-3D
              • T3P3Tonyundefined
                T3P3Tony administrators @Nxt-1
                @nxt-1 @gruna-studio
                Thanks for the file, I have looked at the file and it appears to include bits of tpostN.g files which is a bit confusing, are those just comments left over from some other testing or something else?
                Also I see a G1 D1 and G1 D0 commands what are the "D"s aiming to do?
                Please can you upload your tool change macros for tool 0 and tool 1 for reference.
                www.duet3d.com
                • Nxt-1undefined
                  Nxt-1 @T3P3Tony
                  @t3p3tony I noticed the D's as well and the fact that that parameter is not documented on the wiki. The reason I left it in there is because I copied/modified a g-code script (created by cura) I got from OP. I believe they are silently ignored by the Duet.
                  After some more testing we can confirm that just tool changes work. MoveTC10_test_2.gcode contains basically only toolchanges and that was reported working without issue.
                  So I figured somewhere between script 2 and script 1 lies an issue in the g-code commands.
                  My next step was to slowly remove more and more gcode starting from script 1 and see at what point it started working.
                  MoveTC10_test_3.gcode -> not working
                  MoveTC10_test_4.gcode -> not working
                  MoveTC10_test_5.gcode -> not working
                  MoveTC10_test_6.gcode -> reported not working but slower. Only after 1,5 runs of the script did the offset become to large for a tool change to fail. (normally failure is reported after ~8 changes)
                  EDIT: At this point I don't really know how to advice/test anyfurter. Since we can almost certainly rule out mechanical issues, since script 2 works without issue. But anything more that just tool changes does give issue ¯_(ツ)_/¯
                  Here are the free/pre scripts for T0, they are identical for T1
                  ; tfree0.g
                  ; called when tool 0 is freed
                  ;Drop the bed
                  G91
                  G1 Z4 F1000
                  G90
                  ;Purge nozzle
                  ;M98 P"purge.g"
                  ;Move In
                  G53 G1 X282 Y10 F10000
                  ;Magnet 100 prozent
                  M106 P10 S1
                  M106 P11 S1
                  ;brush cooler
                  M106 P0 S1
                  ;touch
                  G53 G1 X282.1 Y-86.4
                  ;Open Coupler
                  M98 P"/macros/Coupler - Unlock"
                  ;fan off
                  M106 P2 S1
                  ;Move Out
                  G53 G1 X282 Y10 F7000
                  ;magnet 50 prozent
                  M106 P10 S0.5
                  M106 P11 S0.5
                  ; tpre0.g
                  ; called before tool 0 is selected
                  ;Unlock Coupler
                  ;brush cooler
                  M106 P0 S0
                  ;Move in
                  G1 X282.1 Y10 F10000
                  ;Collect
                  G1 X282.1 Y-86.7 F4000
                  ;Close Coupler
                  M98 P"/macros/Coupler - Lock"
                  ;Magnet 0 prozent
                  M106 P10 S0
                  M106 P11 S0
                  ;WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING!
                  ;if you are using non-standard length hotends ensure the bed is lowered enough BEFORE undocking the tool!
                  G91
                  G1 Z0 F400
                  G90
                  ;Move Out
                  G1 X282.1 Y-35  F7000
                  ps I have no idea why the formum gives them different styling.
