    Duet 2 maestro Upgrade Heightmap issues
    Firmware installation
    • ap742undefined
      ap742
      Hi there was putting off upgrade for a while and finally did it.
      but why does it still say Board: Duet Maestro 1.0 (duetmaestro100)
      Firmware: RepRapFirmware for Duet 2 Maestro 2.04 (2019-11-01b1) I thought it was 3.3?
      also
      my map looks all kind of weird not sure how to fix it checked belts doesn't bad
      here's my config
      ; generated by RepRapFirmware Configuration Tool v2.0.3 on Fri Sep 13 2019 00:35:32 GMT+0100 (British Summer Time)
      M550 P"E5Maestro" ; set printer name
      M552 P192.168.2.212 S1 ; enable network & set IP
      M553 P255.255.255.0 ; set netmask
      M554 P192.168.2.1 ; set gateway
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P3 S0 ; physical drive 3 goes backwards
      M350 X16 Y16 Z16 E16 I1 ;M350 X64 Y64 Z64 E32 I0 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00 E391.455 ;M92 X345.00 Y320.00 Z6400.00 E1873.35 ;hemeraE782.91 ; M92 X80.00 Y80.00 Z800.00 E407.53 ; set steps per mm - ;E792testing
      M566 X900.00 Y900.00 Z12.00 E120.00 ;M566 X300.00 Y240.00 Z24.00 E3600.00 ;M566 X150.00 Y150.00 Z24.00 E3600.00 ; M566 X300.00 Y240.00 Z24.00 E3600.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z300.00 E1200.00 ;M203 X12000.00 Y12000.00 Z600.00 E6000.00 ;M203 X10000.00 Y10000.00 Z600.00 E6000.00 ; M203 X12000.00 Y12000.00 Z600.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E500.00 ;M201 X2400.00 Y1800.00 Z20.00 E3600.00 ;M201 X900.00 Y900.00 Z15.00 E3600.00 ; M201 X2400.00 Y1800.00 Z20.00 E3600.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I30 ;M906 X800 Y800 Z800 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X325 Y320 Z410 S0 ; set axis maxima M208 X355 Y355 Z410 S0 /M208 X324 Y332 Z410 S0
      M574 X2 Y2 S1 ; set active high endstops
      M574 Z1 S2 ; set endstops controlled by probe
      M558 P9 H2.5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-44 Y-2 Z1.389 ; set Z probe trigger value, offset and trigger height
      M557 X20:285 Y20:310 S50 ; define mesh gridM557 X10:305 Y10:330 P5:5 - M557 X-5:282 Y5:299 P5:5 - what works M557 X10:305 Y10:330 P5:5 M557 X20:285 Y20:310 S40 good shit
      M305 P0 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 0
      M143 H0 S130 ; set temperature limit for heater 0 to 130C
      M305 P1 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 1
      M143 H1 S280 ; set temperature limit for heater 1 to 260C
      M106 P0 S1 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 F1 ; define tool 0
      ; Custom settings
      M591 D0 P2 C3 S1 ; Filament Run out sensor
      G29 S1 ; Load mesh bed
      M564 H0 ; Process config overrides
      M918 P1 E-4 ; Activate LCD12864
      ;M593 F45
        dc42 administrators @ap742
        @ap742 you need to upgrade to 3.0 first, then you can upgrade immediately to 3.3. Or you can use Bossa to upgrade to 3.3 directly.
        A likely reason for your odd height map is play in the bearing or mounting of the print head, causing the head to rotate a little about the Y axis when the X direction reverses.
        ap742undefined 1 Reply Last reply Reply Quote 0
        • ap742undefined
          ap742 @dc42
          @dc42 after I asked the question I went to ready more and yah 😞 one day I learn how to read .. lol
          I missed Upgrading ANY Duet 2 from 2.x to 3.0 or later requires installing 3.0 first.
          anyway that did it . thank you for replying 🙂
          I'm going to re do cable management-(have feeling it might have enough tension to do weird stuff and carriage and check bearings on my exoslids
