    M671 definition with gobal variable problem
    Gcode meta commands
    • apakundefined
      apak
      here i have my config, for a machine that could be model XL os ST (bed size change) and have a IR probe or a superpinda.
      I have problems with the M671 comand that does not accept a global variable with the text.
      config.g
      ; Hbot XL by Campy3d
      global model = 1								; 1 = XL 		2 = ST    for  CUSTOM (edit in config-var.g on you model type XT or ST)
      global probetype = 2							; 1 = IR mini	2 = Superpinda
      ; Load model type
      M98 P"0:/sys/config-var.g" S{global.model} L0 Z0
      G90												; send absolute coordinates...
      M83												; ...but relative extruder moves
      M550 P"HBot XL RRF3"						    ; set printer name
      M669 K1											; select CoreXY mode
      M552 S1											; enable network
      M586 P0 S1										; enable HTTP
      M586 P1 S1										; enable FTP
      M586 P2 S0										; enable Telnet
      M569 P0 S1										; X physical drive 0 goes forwards
      M569 P1 S0										; Y physical drive 1 goes backwards
      M569 P2 S1										; Z1 physical drive 2 goes forwards
      M569 P3 S0										; E0 physical drive 3 goes backwards
      M569 P4 S1										; Z2 physical drive 3 goes backwards
      M584 X0 Y1 Z2:4 E3								; set drive mapping
      M350 X16 Y16 Z16 E16 I1							; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E400.00				; set steps per mm
      M566 X500.00 Y500.00 Z60.00 E600.00				; set maximum instantaneous speed changes (mm/min)
      M566 P1
      M203 X18000.00 Y18000.00 Z800.00 E4800.00		; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z400.00 E4000.00			; set accelerations (mm/s^2)
      M204 P1200.0 T5000.0                                     ; set print and travel accelerations (mm(s^2)
      M566 E400						;300	  ; Set maximum instantaneous speed changes (JERKS) (mm/min) ONLY EXTRUDER
      M205 X8 Y8 Z8							; Set maximum instantaneous speed changes (JERKS) (mm/seg) XYZ . USE this for Marlin COMPATIBILITY
      M906 X1000 Y1000 Z1000 E560 I30					; set motor currents (mA) and motor idle factor in per cent
      M84 S30											; Set idle timeout
      M208 X0 Y0 Z-1 S1								; set axis minima
      M208 X{global.sizeX} Y{global.sizeY} Z400 S0							; set axis maxima
      ; Definimos Leadscrews para el Z_Tilt
      M671 {global.lscrews}
      ;M98 P"0:/sys/config-var.g" S0 L{global.model} Z0				; leadscrews at left (connected to Z) and right (connected to E1) of X axis ---	S Ajustarlo segun sensibilidad del probe
      M574 X1 S1 P"!xstop"							; configure active-low endstop for low end on X via pin xstop
      M574 Y2 S1 P"!ystop"							; configure active-low endstop for high end on Y via pin ystop
      ; Filament Sensor
      M98 P"0:/sys/00-Functions/FilamentsensorStatus"
      M98 P"0:/sys/config-var.g" S0 L0 Z{global.probetype}  ;
      ; Heaters BED
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 A"Heated Bed"	; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0							; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00								; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0											; map heated bed to heater 0
      M143 H0 S120									; set temperature limit for heater 0 to 120C
      M143 H0 P0 S120 A2								; disable temporarily H0 if temp exceeds 120C
      M143 H0 P0 S130 A0								; heater fault H0 if temp exceeds 130C
      M570 H0 P60 T15 S0
      ; Heaters HOTEND
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 A"Nozzle T0" ; Configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1									; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00										; disable bang-bang mode for heater	and set PWM limit
      M143 H1 S290											; set temperature limit for heater 1 to 300C
      M143 H1 S275 A2											; disable temporarily H1 if temp exceeds 275C
      M143 H1 S285 A0											; heater fault H1 if temp exceeds 280C
      M570 H1 P10 T30 S0										; heater fault for 10 seg of 30ยบC excursion
      ;PID backup
      M307 H0 R0.322 C632.982:632.982 D5.13 S1.00 V24.3 B0 I0		; Bed PID
      M307 H1 R2.813 C295.614:204.933 D6.24 S1.00 V24.5 B0 I0		; Hotend PID
      ; Fan0 = Part Coooling
      M950 F0 C"fan0" Q500							; create fan 0 on pin fan0 and set its frequency
      M106 P0 C"LayerFAN" S0 H-1 B0.3					; set fan 0 name and value. Thermostatic control is turned off
      ; Fan1 = Hotend
      M950 F1 C"fan1" Q500							; create fan 1 on pin fan1 and set its frequency
      M106 P1 C"ToolFAN" S1 H1 T60					; set fan 1 name and value. Thermostatic control is turned on
      ; Fan2 = Chamber cam
      M950 F2 C"fan2" Q500							; create fan 2 on pin fan2 and set its frequency
      M106 P2 I0 C"ChamFAN" S0 H-1                    ; Set fan 2 PWR fan
      ; Sensor = MotherBoard Cooling
      ;----MCU & DRIVERS sensors------
      ;M912 P0 S-13							        ; Cpu temp correction MUST BE ADJUSTED ON EACH BOARD
      M308 S3 Y"mcu-temp"	A"MCU"						; create sensor for MCU temp M308 S3 Y"mcutemp"
      M308 S4 Y"drivers"	A"Drivers"					; create sensor for drivers temp M308 S4 Y"drivers"
      M200 D1.75
      M563 P0 S"T0" D0 H1 F0							; define tool 0
      G10 P0 X0 Y0 Z0									; set tool 0 axis offsets
      G10 P0 R0 S0									; set initial tool 0 active and standby temperatures to 0C
      M302 S180 R180                                         ; allow extrusion starting from 180°C and retractions already from 180°C
      ; Firmware Retraction
      M404 N1.75										; Define filament diameter for print monitor
      M207 S0.95 R0 F2400 Z0							; Firmware retraction
      ; Bed Compensation Taper
      M376 H10										; Bed Compensation Taper 10mm
      ; Pressure Advance
      ;M572 D0 S0.09			;PLA
      ;M572 D0 S0.11			;PETG
      ;M572 D0 S0.1			;ABS
      ; LCD
      M575 P1 S1 B57600								; enable support for PanelDue
      ; LEDS
      M950 P1 C"e1heat" Q500							;use heater 1 outupt for LED
      M42 P1 S0										; turn off LEDS
      ; Power Management
      M911 S23 R24 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"		; set voltage thresholds and actions to run on power loss
      ; Selecto Tool 0
      T0												; select first tool
      ; Load config-override
      M501											; load saved parameters from non-volatile memory
      ; Load Preloaded filamento config
      M703
      config-var.g
      ; Model type XL or ST
      if {param.S}==1 || {param.S}==2
      	if {param.S}==1					; XL
      		global sizeX = 330
      		global sizeY = 325
      		global posZ1 = -59.13
      		global posZ2 = 437.87
      		global posY = 164
      	elif {param.S}==2				; ST
      		global sizeX = 310
      		global sizeY = 208
      		global posZ1 = -55.50
      		global posZ2 = 411.50
      		global posY = 144
      	; end if bedsize
      	; Varibales definition
      	if global.probetype == 1 										; Z-Probe IR mini
      		global offsetPX = 18
      		global offsetPY = -38
      		global tiltZ1=18
      		if {param.S}=1
      			global tiltZ2=304
      		elif {param.S}=2
      			global tiltZ2=292
      		; end if
      		global meshmaxY= {global.sizeY-abs(global.offsetPY)}
      	elif global.probetype == 2 										; Z-Probe Superpinda
      		global offsetPX = -25
      		global offsetPY = 0
      		global tiltZ1=30
      		if {param.S}=1
      			global tiltZ2=295
      		elif {param.S}=2
      			global tiltZ2=272
      		; end if
      		global meshmaxY= {global.sizeY-(abs(global.offsetPY)+10)}
      	; end if variable definition
      	; Mid Points and Ztilt Points
      	global midX={(global.sizeX/2)-global.offsetPX}
      	global midY={(global.sizeY/2)-global.offsetPY}
      	global midXP={global.sizeX/2}
      	global midYP={global.sizeY/2}
      	global meshmaxX= global.tiltZ2
      	; M671 definition
      	global lscrews=("X"^{global.posZ1}^":"^{global.posZ2}^" Y"^{global.posY}^":"^{global.posY}^" S5")
      ; end if
      ; Locate LeadScrews
      if {param.L}==1 || {param.L}==2
      	if {param.L}==1					; XL
      		M671 X-59.13:437.87 Y164:164 S5
      	elif {param.L}==2				; ST
      		M671 X-55.50:411.50 Y164:164 S5
      	; end if bedsize
      ; Probe Setup
      if{param.Z}==1 || {param.Z}==2										; Probe type IR mini
      		M558 P1 C"zprobe.in" H5 F360:120 T9000 R0.4 A3 S0.03 ;B1    ; Set Z probe type mini ir sensor
      		G31 P500 X{global.offsetPX} Y{global.offsetPY} Z2.175		; set Z probe trigger value, offset and trigger height
      		M558 P8 C"zprobe.in" H5 F360:120 T9000 R0.4 A3 S0.03 ;B1    ; Set Z probe type mini ir sensor
      		G31 P1000 X{global.offsetPX} Y{global.offsetPY} Z0.74		; set Z probe trigger value, offset and trigger height   ;Inductivo
      	; end if
      	M557 X20:{global.meshmaxX} Y20:{global.meshmaxY} P3				; define mesh grid P6 hace 6 malla de 6x6
      ; end if
      I am NOT a programer, just a random guy trying to this...so any help would be apreciated
      • Gixxerfastundefined
        Gixxerfast
        @apak
        Hi, I don't think you can't write parameters in the way you have done.
        Try this instead:
        M671 X{global.posZ1,global.posZ2} Y{global.posY,global.posY} S5
        Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
        Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
        Ender 3 Pro with BTT SKR-2 + RRF
        apakundefined 1 Reply Last reply Reply Quote 0
        • apakundefined
          apak @Gixxerfast
          @gixxerfast said in M671 definition with gobal variable problem:
          Worked, sort off..
          instead of X1:X2 Y1:Y2 it has to be parsed as Leadscrew1 (X1,Y1) and Leadscrew2 (X2,Y2)
          M671 X{global.posZ1,global.posY} Y{global.posZ2,global.posY} S5
          So X and Y could lean to error if parsed as variable
          • Phaedruxundefined Phaedrux moved this topic from Tuning and tweaking
