    Temp0 on Toolboard V1.1 suddenly reading wrong values / offset
    750
    • pasqueundefined
      pasque
      Good evening,
      Yesterday during a print the temperature on temp0 suddenly jumped 100°C.
      After a reboot and cooling down of the hotend, the sensor shows permanently 80-100°C. A unplugged thermistor shows -273,1°C (I think this is the standard behavior).
      With a new, alternative thermistor the same behavior.
      Only input temp0 is affected. When connected and reconfigured to input temp1 the correct temperature is displayed.
      I measured the resistance at both pins of temp0 and temp1:
      resistance temp0 = 29k Ohm
      resistance temp1 = 2.8k Ohm
      There are no defects on the toolboard to recognize.
      I therefore assume a defect of the temp0 input or the toolboard.
      I flashed RRF 3.4 beta 6 yesterday on my toolboard and Duet 3 Mini 5+ to test Input Shaping. Printing with RFF3.4 beta 6 worked really well until the incident.
      I flashed back to 3.3 just to check if this could cause the problem - it didn't work.
      The toolboard V1.1 was bought in July 2021.
      Many thanks in advance!
      Pascal
      config.g
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.3.0 on Sat Aug 14 2021 01:11:57 GMT+0200 (Mitteleuropäische Sommerzeit)
      G90                                             	; send absolute coordinates...
      M83                                            		; ...but relative extruder moves
      M550 P"Pascal''s VORON V2.1903"                		; set printer name
      M669 K1                                           	; select CoreXY mode
      ; Wait a moment for the CAN expansion boards to start
      G4 S2
      M552 S1                                          ; enable network
      M586 P0 S1                                       ; enable HTTP
      M586 P1 S0                                       ; disable FTP
      M586 P2 S0                                       ; disable Telnet
      M569 P0.0 S0                                     			; physical drive 0.0 (Z0) goes backwards
      M569 P0.1 S1                                     			; physical drive 0.1 (Z1) goes forwards
      M569 P0.2 S0                                     			; physical drive 0.2 (Z2) goes backwards
      M569 P0.3 S1                                     			; physical drive 0.3 (Z3) goes forwards
      M569 P0.5 S0                                    			; physical drive 0.5 (X) goes backwards D2= forced SpreadCycle
      M569 P0.6 S0                                    			; physical drive 0.6 (Y) goes backwards D2= forced SpreadCycle
      M569 P121.0 S1                                  			; physical drive 121.0 (Extruder) goes forwards
      M584 X0.5 Y0.6 Z0.0:0.1:0.2:0.3 E121.0        				; set drive mapping
      M350 X16 Y16 Z16 E16 I1                         			; configure microstepping with interpolation
      M92 X160 Y160 Z400.00 E423	          						; set steps per mm
      M566 P1 X1200.00 Y1200.00 Z200.00 E600            			; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z8000.00 E3000.00     				; set maximum speeds (mm/min)
      M201 X3500.00 Y3500.00 Z500.00 E10000          				; set accelerations (mm/s^2)
      M906 X1400 Y1400 Z1300 E400 I30               				; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                         			; Set idle timeout
      M572 D0 S0.065				 								; set Pressure Advance
      M208 X0 Y0 Z0 S1                                ; set axis minima
      M208 X350 Y356 Z300 S0                      	; set axis maxima
      M574 X2 S1 P"io5.in"                             ; configure active-high endstop for high end on X via pin io5.in
      M574 Y2 S1 P"io6.in"                             ; configure active-high endstop for high end on Y via pin io6.in
      M574 Z1 S1 P"io3.in"                             ; configure active-high endstop for low end on Z via pin io3.in
      M558 P8 C"121.io0.in" H5 F1500 T15000				; enable Z Probe, set dive height, probe speed and travel speed
      G31 Z4.5											; Set Z-Offset of Probe (Y Offset of Probe not set, depends on nozzle coordinates)
      M557 X15:330 Y5:310 S31.5:30.5                    	; define mesh grid
      M671 X-60:-60:410:410 Y0:422:422:0 S10				; position of "leadscrew" (belt closest to gantry)
      	; Bed
      M308 S0 P"temp1" Y"thermistor"									; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out1" T0                               				; create bed heater output on out1 and map it to sensor 0
      M307 H0 B0 R0.265 C1255.8 D14.97 S1.00                      	; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                          				; map heated bed to heater 0
      M143 H0 S110                                     				; set temperature limit for heater 0 to 110C
      	; Hotend
      M308 S1 P"121.temp0" Y"thermistor"								; configure sensor 1 as thermistor on pin 121.temp0
      M950 H1 C"121.out0" T1                           				; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 B0 R2.682 C201.5:121.6 D9.09 S1.00	                    ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S255                                     				; set temperature limit for heater 1 to 240C
      M950 F0 C"121.out1" Q500                         				; create fan 0 on pin 121.out1 and set its frequency "Toolfan"
      M106 P0 S0 H-1 				                                   	; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"121.out2" Q500                         				; create fan 1 on pin 121.out2 and set its frequency
      M106 P1 S0.6 H1 T40 C"Hotend"                               	; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"out4" Q500                             				; create fan 2 on pin out4 and set its frequency
      M106 P2 S1 H1:0 T25 C"Gehäuse"                               	; set fan 2 value. Thermostatic control is turned on
      M563 P0 S"Hotend" D0 H1 F0                   			; define tool 0
      G10 P0 X0 Y0 Z0                                  		; set tool 0 axis offsets
      G10 P0 R0 S0											; set initial tool 0 active and standby temperatures to 0C
      T0														; set T0 active
      ; Display
      M918 P2 R6 C30 E4 F200000
      M150 X2 R0 U255 B0 P125
      ; Accelerometer
      M955 P121.0 I10
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: 2GMYT-T296U-D65J0-40KM4-1F03Z-7F950
      Used output buffers: 3 of 40 (11 max)
      Static ram: 102724
      Dynamic ram: 112864 of which 0 recycled
      Never used RAM 28116, free system stack 196 words
      Tasks: NETWORK(ready,14.4%,253) HEAT(delaying,0.0%,348) Move(notifyWait,0.1%,338) CanReceiv(notifyWait,0.0%,773) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,352) TMC(notifyWait,1.1%,106) MAIN(running,83.4%,410) IDLE(ready,0.1%,29) AIN(delaying,0.8%,264), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:04:42 ago, cause: power up
      Last software reset at 2021-11-28 23:30, reason: User, GCodes spinning, available RAM 28116, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      MCU revision 3, ADC conversions started 283813, completed 283811, timed out 0, errs 0
      Step timer max interval 955
      MCU temperature: min 20.7, current 26.6, max 26.7
      Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 25682, writes 11, timeouts 0, DMA errors 0
      Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 25681, writes 11, timeouts 0, DMA errors 0
      Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 25681, writes 11, timeouts 0, DMA errors 0
      Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 25681, writes 11, timeouts 0, DMA errors 0
      Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 25684, writes 9, timeouts 0, DMA errors 0
      Driver 5: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 25681, writes 11, timeouts 0, DMA errors 0
      Driver 6: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 25681, writes 11, timeouts 0, DMA errors 0
      Date/time: 2021-11-29 14:25:40
      Cache data hit count 517737907
      Slowest loop: 4.99ms; fastest: 0.12ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.6ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = 0 -1, chamberHeaters = -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 2555, received 3388, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 314, free buffers 17 (min 16), ts 1415/1414/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 10.53ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.26
      WiFi MAC address f0:08:d1:02:e8:ee
      WiFi Vcc 3.33, reset reason Power up
      WiFi flash size 2097152, free heap 24552
      WiFi IP address 192.168.178.88
      WiFi signal strength -63dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      M122 B121 (for diagnosis only CAN and POWER connected)
      Diagnostics for board 121:
      Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)
      Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
      Never used RAM 2624, free system stack 2789 words
      Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,117) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,2.8%,57) MAIN(running,92.0%,352) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
      Last reset 00:05:59 ago, cause: power up
      Last software reset data not available
      Driver 0: position 0, 423.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 12, reads 48690, writes 12, timeouts 0, DMA errors 0, steps req 0 done 0
      Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter -3/10, peak Rx sync delay 193, resyncs 0/0, no step interrupt scheduled
      VIN: 23.9V
      MCU temperature: min 24.0C, current 37.0C, max 37.0C
      Ticks since heat task active 78, ADC conversions started 359572, completed 359572, timed out 0, errs 0
      Last sensors broadcast 0x00000002 found 1 83 ticks ago, loop time 0
      CAN messages queued 4328, send timeouts 0, received 3251, lost 0, free buffers 37, min 37, error reg 110000
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
      Accelerometer detected: yes, status: 00
      I2C bus errors 0, naks 0, other errors 0```
      • T3P3Tonyundefined
        T3P3Tony administrators @pasque
        @pasque this may be related to an issue that was identified with another user
        Do you have a digital multimeter to test with? If you do please check the resistance of R21, shown in green in the image below
        The measure between the pin on the temp 0 header shown in a red box and the pad of C44 also shown in a red box. (you might be able to measure on the side of R21 instead of against C44, depending on how sharp the multimeter probe leads are).
        www.duet3d.com
        pasqueundefined 1 Reply Last reply Reply Quote 0
        • pasqueundefined
          pasque @T3P3Tony
          @t3p3tony I measured the resistance of R21 with a digital multimeter as explained.
          It shows 29.6k Ohm.
          • T3P3Tonyundefined
            @pasque please double check as it is a 2k2 resistor!
            www.duet3d.com
            • pasqueundefined
              pasque @T3P3Tony
              @t3p3tony I checked it 5 times now, R21 says 29.6k Ohm.
              To compare, I also checked R22. This resistor shows 2.2k Ohm.
              • T3P3Tonyundefined
                @pasque ok thanks, because it was working and then suddenly failed its not a case of the wrong resistor value being fitted so I suspect that there was a short period of over-voltage leading to overcurrent which partially damaged this resistor. The most likely cause is a intermittent short between your VIN power and the temperature input. Please check your wiring carefully, you may need to move the axis into a range of position to recreate the fault.
                www.duet3d.com
                • pasqueundefined
                  pasque @T3P3Tony
                  @t3p3tony thank you for your explanation!
                  Before I created this thread the first thing I checked was the wiring. I did not see any complications in my setup like blank wires or possible sources for shorts. In my opinion every wire is insulated well plus sometimes some extra insulation with a textile tape. Checked VIN and the heater wires twice. The wires of the heater cartridge are far away enough from the heating block. Also theres is enough space between the heater cartridge and the thermistor. There are no open wires of the thermistor to detect, as they are encapsulated and insulated with a sleeving.
                  Also during moves there is nearly no movement of the cables because they are quite good fixed in my Voron setup. Wires are only moving in the cable chains. So there is no position of the gantry where the wires could be touching anything. Furthermore the incident happened as the print head was in the middle of the print bed.
                  The printer was running now for nearly 4 months without any issue. On the day I flashed the new firmware the incident happened.
                  I also saw a similiar incident in the forum after a update to 3.4 beta 6:https://forum.duet3d.com/topic/25886/3-4-0beta6-after-update-heater-1-fault-shows-409-9-c
                  So could this be a firmware issue or is this a pure coincidence?
                  The toolboard was replaced in this case.
                  Also there was another case where the exact same resistor had a defect and the toolboard was replaced: https://forum.duet3d.com/topic/22754/toolboard-lc1-temp0-with-offset-or-wrong-reading/4
                  What should I do now?
                  I also added some pictures of my setup:3ab8f7da-b4ce-4ec5-881b-a5d3839b03fd-image.png 34a35e8b-6462-4401-9378-1bf979b20dca-image.png
                  Thank you in advance!
                  Gixxerfastundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                  • Gixxerfastundefined
                    Gixxerfast @pasque
                    This post is deleted!
                    • T3P3Tonyundefined
                      @pasque yes, the more recent of those two posts that you referenced are what I had in mind when responding to you (the older one is a version 1.0 board with a different issue). In once case we have the board back already and confirmed that R21 was damaged by over voltage. That is why I suggested you check that. It may be worth checking for any continuity between the heater block and the temperature input pin, and between the heater and the heater block.
                      I cannot see a mechanism where the firmware could cause sufficient current to flow through this resistor to damage it. None the less I will raise it with @dc42 because it is odd that both you and one other user had the issue after upgrading to 3.4b6, although if course that could be an odd coincidence.
                      www.duet3d.com
                      • T3P3Tonyundefined
                        T3P3Tony administrators @T3P3Tony
                        @pasque ok I have confirmed with @dc42 that there is no firmware related mechanism to cause sufficient current to flow to damage the resistor.
                        Your wiring does not well constrained but its definitely worth looking for a path between VIN and the temperature input pin. Through the heater block is the obvious option if not between wires.
                        www.duet3d.com
                        • pasqueundefined
                          pasque @T3P3Tony
                          @t3p3tony Thank you for checking that with @dc42 .
                          Although I am pretty sure there is no short, I will replace the heater cartridge and thermistor including their wires just to be sure.
                          Unfortunately, I now have a defective toolboard. I can possibly change to temp1, but is there any chance to repair the toolboard / temp0? SMD soldering is not one of my skills... 😉
                          • T3P3Tonyundefined
                            @pasque before you replace the heater cartridge and the thermistor please check between the heater block and temp0 and between the heater cartridge and heater block.
                            Regarding repair, where are you located?
                            www.duet3d.com
                            • pasqueundefined
                              pasque
                              @t3p3tony I checked a possible short with the multimeter between
                              • heater block and heater cartridge - no short
                              • heater block and temp0 (thermistor plugged in) / temp1 (thermistor plugged in) - no short
                              • heater cartridge and temp0 (thermistor plugged in) / temp1 (thermistor plugged in) - no short
                              So a change of the heater cartridge wouldn't probably fix anything for the future.
                              I'm located near Stuttgart, southern Germany. Bought the Toolboard from Dold Mechatronik.
                              • pasqueundefined
                                pasque @T3P3Tony
                                @t3p3tony Checking POWER VIN+ to VSSA of the temp1 and temp0 pins, the multimeter shows a connection / short. Is this intended?
                                • T3P3Tonyundefined
                                  @pasque what resistance are you seeing between those pins?
                                  Ground to VSSA should be low resistance (there is only 10R and a fuse between them).
                                  VSSA to VIN should be high resistance or open.
                                  www.duet3d.com
                                  • pasqueundefined
                                    pasque @T3P3Tony
                                    @t3p3tony sorry, I need to apologize. I think I din't probe that good. I checked it now 3 times again and I think it matches your answer now:
                                    VSSA to VIN+ = ~390 Ohm
                                    VSSA to GND = 10 Ohm
                                    I also did some further testing that last hour.
                                    I flashed 3.4 beta 6 again and reconfigured to temp1 input (that input that isn't broken right now):
                                    1.12.2021, 18:43:39	M122 M122 B121
                                    RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta6 (2021-11-06 11:39:32) running on Duet 3 Mini5plus WiFi (standalone mode)
                                    Used output buffers: 3 of 40 (13 max)
                                    Static ram: 103876
                                    Dynamic ram: 116860 of which 24 recycled
                                    Never used RAM 20952, free system stack 200 words
                                    Tasks: NETWORK(ready,12.1%,264) HEAT(notifyWait,0.0%,374) Move(notifyWait,0.0%,361) CanReceiv(notifyWait,0.0%,797) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,351) TMC(notifyWait,1.1%,114) MAIN(running,84.5%,428) IDLE(ready,1.4%,29) AIN(delaying,0.8%,274), total 100.0%
                                    Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
                                    Last reset 00:00:22 ago, cause: software
                                    Last software reset at 2021-12-01 18:43, reason: User, GCodes spinning, available RAM 20908, slot 1
                                    Error status: 0x00
                                    MCU revision 3, ADC conversions started 22998, completed 22997, timed out 0, errs 0
                                    Step timer max interval 751
                                    MCU temperature: min 27.1, current 28.2, max 28.4
                                    Driver 0: pos 0, standstill, SG min 0, read errors 0, write errors 1, ifcnt 35, reads 2046, writes 11, timeouts 0, DMA errors 0
                                    Driver 1: pos 0, standstill, SG min 0, read errors 0, write errors 1, ifcnt 35, reads 2045, writes 11, timeouts 0, DMA errors 0
                                    Driver 2: pos 0, standstill, SG min 0, read errors 0, write errors 1, ifcnt 35, reads 2045, writes 11, timeouts 0, DMA errors 0
                                    Driver 3: pos 0, standstill, SG min 0, read errors 0, write errors 1, ifcnt 35, reads 2045, writes 11, timeouts 0, DMA errors 0
                                    Driver 4: pos 0, standstill, SG min 0, read errors 0, write errors 1, ifcnt 29, reads 2047, writes 9, timeouts 0, DMA errors 0
                                    Driver 5: pos 0, standstill, SG min 0, read errors 0, write errors 1, ifcnt 35, reads 2045, writes 11, timeouts 0, DMA errors 0
                                    Driver 6: pos 0, standstill, SG min 0, read errors 0, write errors 1, ifcnt 35, reads 2045, writes 11, timeouts 0, DMA errors 0
                                    Date/time: 2021-12-01 18:43:37
                                    Cache data hit count 42338877
                                    Slowest loop: 4.56ms; fastest: 0.13ms
                                    === Storage ===
                                    SD card longest read time 3.2ms, write time 0.0ms, max retries 0
                                    DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                    === MainDDARing ===
                                    === AuxDDARing ===
                                    Bed heaters 0 -1, chamber heaters -1 -1, ordering errs 0
                                    Heater 1 is on, I-accum = 0.0
                                    Segments left: 0
                                    HTTP is ready with "M122 " in state(s) 0
                                    Code queue is empty
                                    === CAN ===
                                    Messages queued 216, received 454, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 606, free buffers 17 (min 16), ts 115/114/0
                                    === Network ===
                                    Slowest loop: 15.36ms; fastest: 0.00ms
                                    - WiFi -
                                    WiFi flash size 2097152, free heap 22864
                                    WiFi signal strength -60dBm, mode 802.11n, reconnections 0, sleep mode modem
                                    Duet TOOL1LC rev 1.1 or later firmware version 3.4.0beta6 (2021-11-06 11:56:11)
                                    Never used RAM 2576, free system stack 2788 words
                                    Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,64) CanRecv(notifyWait,0.0%,77) CanClock(notifyWait,0.0%,64) ACCEL(notifyWait,0.0%,61) TMC(delaying,3.0%,67) MAIN(running,91.9%,350) IDLE(ready,0.0%,27) AIN(delaying,4.9%,148), total 100.0%
                                    Last reset 00:00:23 ago, cause: software
                                    Driver 0: pos 0, 423.0 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 45, reads 11636, writes 11, timeouts 0, DMA errors 0, steps req 0 done 0
                                    Peak sync jitter -2/6, peak Rx sync delay 192, resyncs 0/0, no step interrupt scheduled
                                    VIN voltage: min 23.9, current 23.9, max 23.9
                                    MCU temperature: min 34.2C, current 34.7C, max 34.7C
                                    Last sensors broadcast 0x00000002 found 1 80 ticks ago, 0 ordering errs, loop time 0
                                    CAN messages queued 476, send timeouts 0, received 223, lost 0, free buffers 37, min 37, error reg 110000
                                    I2C bus errors 0, naks 3, other errors 0
                                    And I started a print. After about 6mins the exact same incident happened again as on sunday: There was a fault of the sensor:
                                    1.12.2021, 19:04:31	Connection established
                                    1.12.2021, 19:04:28	Connection interrupted, attempting to reconnect...
                                    1.12.2021, 19:04:19	Error: Failed to switch off remote heater 1:
                                    Cancelled printing file 0:/gcodes/Fab365_Bottom.gcode, print time was 0h 5m
                                    1.12.2021, 19:04:19	Emergency stop, attemping to reconnect...
                                    1.12.2021, 18:58:46	Leadscrew adjustments made: 0.063 -0.012 -0.026 0.071, points used 4, (mean, deviation) before (0.035, 0.030) after (0.000, 0.000)
                                    1.12.2021, 18:58:22	File 0:/gcodes/Fab365_Bottom.gcode selected for printing
                                    This time, the temp1 input seems to be okay, resistance of temp1 is normal, temperature was as intended to be. Didn't change anything in the hardware configuration.
                                    I flashed back to 3.3 again. Started the exact same file again.
                                    1.12.2021, 19:26:12	Leadscrew adjustments made: -0.277 -0.254 -0.327 1.087, points used 4, (mean, deviation) before (0.146, 0.401) after (0.000, 0.000)
                                    1.12.2021, 19:25:49	M32 "0:/gcodes/Fab365_Bottom.gcode"
                                    1.12.2021, 19:29:17	M122 M122 B121
                                    Used output buffers: 3 of 40 (12 max)
                                    Static ram: 102724
                                    Dynamic ram: 113112 of which 144 recycled
                                    Never used RAM 24868, free system stack 132 words
                                    Tasks: NETWORK(ready,15.4%,240) HEAT(delaying,0.0%,344) Move(notifyWait,0.1%,272) CanReceiv(notifyWait,0.0%,773) CanSender(notifyWait,0.0%,363) CanClock(delaying,0.0%,347) TMC(notifyWait,1.2%,106) MAIN(running,82.3%,426) IDLE(ready,0.1%,29) AIN(delaying,0.8%,264), total 100.0%
                                    Last reset 00:09:54 ago, cause: software
                                    Last software reset at 2021-12-01 19:19, reason: User, GCodes spinning, available RAM 28116, slot 0
                                    Error status: 0x00
                                    MCU revision 3, ADC conversions started 594986, completed 594985, timed out 0, errs 0
                                    Step timer max interval 870
                                    MCU temperature: min 28.4, current 32.8, max 33.0
                                    Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                    Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/4/4, gc cycles 0
                                    Driver 0: position 55754, standstill, SG min/max 0/508, read errors 0, write errors 1, ifcnt 39, reads 54050, writes 15, timeouts 0, DMA errors 0
                                    Driver 1: position 7320, standstill, SG min/max 0/492, read errors 0, write errors 1, ifcnt 39, reads 54050, writes 15, timeouts 0, DMA errors 0
                                    Driver 2: position 80, standstill, SG min/max 0/482, read errors 0, write errors 1, ifcnt 39, reads 54050, writes 15, timeouts 0, DMA errors 0
                                    Driver 3: position 0, standstill, SG min/max 0/474, read errors 0, write errors 1, ifcnt 39, reads 54050, writes 15, timeouts 0, DMA errors 0
                                    Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 29, reads 54056, writes 9, timeouts 0, DMA errors 0
                                    Driver 5: position 0, ok, SG min/max 0/492, read errors 0, write errors 1, ifcnt 39, reads 54050, writes 15, timeouts 0, DMA errors 0
                                    Driver 6: position 0, ok, SG min/max 0/432, read errors 0, write errors 1, ifcnt 39, reads 54050, writes 15, timeouts 0, DMA errors 0
                                    Date/time: 2021-12-01 19:29:15
                                    Cache data hit count 1065433227
                                    Slowest loop: 215.67ms; fastest: 0.12ms
                                    === Storage ===
                                    Free file entries: 9
                                    SD card longest read time 3.9ms, write time 0.0ms, max retries 0
                                    DMs created 83, maxWait 215333ms, bed compensation in use: none, comp offset 0.000
                                    === MainDDARing ===
                                    Scheduled moves 2620, completed moves 2580, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state 3
                                    === AuxDDARing ===
                                    Heater 0 is on, I-accum = 0.1
                                    Segments left: 1
                                    File is doing "G1 X196.459 Y167.695 E0.02106" in state(s) 0
                                    === CAN ===
                                    Messages queued 7888, received 7168, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 271, free buffers 17 (min 13), ts 2975/2974/0
                                    === Network ===
                                    Slowest loop: 208.88ms; fastest: 0.00ms
                                    - WiFi -
                                    WiFi flash size 2097152, free heap 26440
                                    WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
                                    Never used RAM 2624, free system stack 2745 words
                                    Tasks: Move(notifyWait,0.2%,99) HEAT(delaying,0.2%,109) CanAsync(notifyWait,0.0%,61) CanRecv(notifyWait,0.0%,74) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,2.8%,57) MAIN(running,91.8%,352) IDLE(ready,0.0%,27) AIN(delaying,5.0%,142), total 100.0%
                                    Last reset 00:09:55 ago, cause: software
                                    Driver 0: position 94168, 423.0 steps/mm, ok, SG min/max 0/16, read errors 0, write errors 1, ifcnt 48, reads 35274, writes 14, timeouts 0, DMA errors 0, steps req 109058 done 109015
                                    Moves scheduled 2487, completed 2485, in progress 1, hiccups 0, step errors 0, maxPrep 572, maxOverdue 3, maxInc 2, mcErrs 0, gcmErrs 0
                                    Peak sync jitter -4/9, peak Rx sync delay 209, resyncs 0/0, next step interrupt due in 400 ticks, enabled
                                    VIN: 23.7V
                                    MCU temperature: min 40.6C, current 44.7C, max 44.7C
                                    Ticks since heat task active 196, ADC conversions started 594830, completed 594829, timed out 0, errs 0
                                    Last sensors broadcast 0x00000002 found 1 202 ticks ago, loop time 0
                                    CAN messages queued 7191, send timeouts 0, received 7895, lost 0, free buffers 37, min 36, error reg 110000
                                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 529, adv 22117/74617
                                    The printer printed the file without any error, no drops in temperature or any unusual behavoiur.
                                    I'm really confused right now 😲
                                    Edit: with 3.4 beta 6 Input Shaping was activated, in case that matters:
                                    M593 P"MZV" F61
                                    • T3P3Tonyundefined
                                      @pasque this really has all the symptoms of an intermittent fault - I definitely don't think this is a firmware issue (even though it coincided with a firmware upgrade initially).
                                      @pasque said in Temp0 on Toolboard V1.1 suddenly reading wrong values / offset:
                                      This is interesting as well - did you notice any CAN communication drops? I wonder if the fault caused the tool board processor to shut down temporarily.
                                      www.duet3d.com
                                      • pasqueundefined
                                        pasque @T3P3Tony
                                        @t3p3tony I just printed another file with 3.3 without any issue for over 3h.
                                        To investigate I will flash 3.4 beta 6 tomorrow again to see if this may happen again.
                                        I did not notice any CAN communication issues - is there a way to detect them?
                                        • T3P3Tonyundefined
                                          @pasque issues with CAN communication are reported in the M122 of the mainboard and of the toolboard.
                                          www.duet3d.com
                                          • pasqueundefined
                                            pasque @T3P3Tony
                                            Hi @t3p3tony, I disassembled the print head and checked every wiring. Therey may have been a loose wire behind the tool fan, I'm not completely sure. I also changed the wires of the thermistor as I suspected these most likely to be the problem.
                                            Since then the printer worked without any further incident - I will carefully check the next prints.
                                            I can't really comprehend why the resistor R21 of temp0 is damaged now but I would really like to have it repaired because the temp0 port is at a better position for my wiring. Any suggestions?
