    Vcore 3 500 with Duet 3 Mini 5+ and Bondtech Hot end
    418
    • DreamTechEntsundefined
      DreamTechEnts
      Hi all,
      So after a killer build and getting everything set up, I'm now at the stage I need to get the correct firmware onto my Duet for the above board and hot end.
      Does anyone have any pointers for me or even better a full zip file I can upload to the Board? I looked at trying to generate some but to no avail?
      Cheers in advance!!! And sorry if this is in the wrong place.
      Nurgelrotundefined 2 Replies Last reply Reply Quote 0
      • Nurgelrotundefined
        Nurgelrot @DreamTechEnts
        @dreamtechents which Bondtech? BMG LGX etc...
          Are you looking for just the firmware, or the full config?
          Do you have access to DWC? What version is currently installed?
          In general though, if you have access to DWC you can upload the full zip file from the latest stable release to the system tab: https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
            @dreamtechents Here are the major files for a Vcore3 500 with RRF 3.3. But this is for a LGX on a toolboard and a pinda so it wont be plug-n-play. Also this hasn't been tuned at all. E steps are just the generic drfault for the LGX (BMG would be 415 with .18 motor)
            homex.g homez.g homey.g homeall.g bed.g config.g
            Also this wont work if you followed the RatRig Duet wiring guide since they put the endstops ports in really foolish places... about all its good for is reference. Don't just drop it in and expect it to work.
            • A Former User?
              A Former User
              This post is deleted!
              Nurgelrotundefined 1 Reply Last reply Reply Quote 2
                Nurgelrot @A Former User
                @arnold_r_clark Ah yeah I just didnt update my comments sorry I can see how thats confusing. just ignore after the ; on the M569 lines.
                Fixed
                M569 P0.0 S0                                          ; physical drive 0.0 ZL goes forwards
                M569 P0.1 S0                                          ; physical drive 0.1 ZM goes forwards
                M569 P0.2 S0                                          ; physical drive 0.2 ZR forwards
                M569 P121.0 S1                                        ; physical drive 121.0 E goes backwards
                M569 P0.3 S1                                          ; physical drive 0.1 Y goes backwards
                M569 P0.4 S1                                          ; physical drive 0.2 X goes backwards
                M584 X0.4 Y0.3 Z0.0:0.1:0.2 E121.0                    ; set drive mapping
                • A Former User?
                  A Former User @Nurgelrot
                  Nurgelrotundefined 1 Reply Last reply Reply Quote 0
                    @arnold_r_clark Would be nice if the config tool understood multiple motors per axis so it got created in the right order to begin with but oh well. Just need to remember to update the comments as well when moving the drives around.
                    A Former User? Phaedruxundefined 2 Replies Last reply Reply Quote 0
                    • A Former User?
                        Phaedrux Moderator @Nurgelrot
                        @nurgelrot said in Vcore 3 500 with Duet 3 Mini 5+ and Bondtech Hot end:
                        Soon.
