    heaters above 305c
    Duet Web Control
    • rexxundefined
      rexx
      Hi all i have tried looking for a bit on how to get to 400c with pt1000
      its working now up to 305 after that limit setpoint is not updating afer this last line is added
      M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
      M143 H0 S125 ; Set temperature limit for heater 0 to 125C
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S350 ; Set temperature limit for heater 1 to 350C
      350 c does not take either
      others have had this issue but I cant find the fix....
        Can you post your full config.g?
        What firmware version are you using?
        What exactly isn't working?
        Your M305 is for a thermistor, but you say you're using a PT1000?
        rexxundefined 5 Replies Last reply Reply Quote 0
        • rexxundefined
          rexx @Phaedrux
          @phaedrux sure ,
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 16:20:11 GMT-0400 (Eastern Daylight Time)
          M550 P"Ender 5 Plus" ; set printer name
          M569 P3 S0 ; physical drive 3 goes forwards
          M92 X80.00 Y80.00 Z800.00 E96.6 ; set steps per mm
          M566 X500.00 Y500.00 Z42.00 E180.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X8200.00 Y8200.00 Z600.00 E6200.00 ; set maximum speeds (mm/min)
          M201 X950.00 Y950.00 Z350.00 E6100.00 ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S60 ; Set idle timeout
          M208 X350 Y350 Z400 S0 ; set axis maxima
          M574 Z1 S2 ; configure Z-probe endstop for low end on Z
          M558 P9 C"^zprobe.in" H3 F150 T10000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X-42 Y-1 Z2.90 ; set Z probe trigger value, offset and trigger height
          M557 X15:315 Y15:315 S75 ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 ; configure sensor 0 as thermistor on pin bedtemp
          M308 S1 P"e0temp" Y"pt1000" ; configure sensor 1 as thermistor on pin e0temp
          M143 H1 S325 ; Set temperature limit for heater 1 to 325C
          M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0.65 H-1 ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q20 ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S0.65 H1 T45 ; set fan 1 value. Thermostatic control is turned off
          ;Filament Sensor
          M591 D0 P1 C"e0_stop" S0 ; Filament run-out sensor triggers a pause
          M563 P0 D0 H1 ; define tool 0
          M501
          • rexxundefined
            rexx @Phaedrux
            @phaedrux weird 305 are wrong then i have a slice pt1000 and 50w 24v heater but my config now shows different from what i showed you ....not sure why yet still looking into either way this is the config.g
            • rexxundefined
              rexx @Phaedrux
              @phaedrux the new temps cannot be used i can only go to 305c
              • rexxundefined
                rexx @Phaedrux
                @phaedrux
                ok its working now i guess it never completed something but i have temp control
                i should be good thanks for reaching out
                • rexxundefined
                  rexx @Phaedrux
                  @phaedrux also congrats on the IDEX 22 sporting a duet 2 👍 👍
