    Bed mesh compensation BLT
    • gibsea402undefined
      gibsea402
      Hi
      I am having a issue with the mesh compensation. It seems like it i generating a height map just fin. But when i then turn compensation on, it seems like it is not working very well. The spot that i zero the nozzel is of course 0 when i dont have it on. But when i turn the compensation on, it becomes Z-0.4. which means the nozzel is far too of the bed. height map.jpg
      When i then move the nozzel to the far left corner with the compensation on, it lifts the nozzel to G1 X100 Y280 Z0. Then it is like 3mm form the bed. This should be Z0.318
      It is like it is doing the opposite of what its supposed to do.
      Any idea what could be wrong? let me know what code can help to solve it
        Please share with us your config.g, bed.g, mesh.g, homeall.g, homez.g files.
        Also the results of M122 and M98 P"config.g" for good measure.
        Have you calibrated the probe offsets? https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
        gibsea402undefined 1 Reply Last reply Reply Quote 0
          gibsea402 @Phaedrux
          @phaedrux
          Config.g:
          ; Configuration file for Duet WiFi (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Nov 29 2021 13:09:44 GMT+0100 (Centraleuropæisk normaltid)
          M575 P1 S1 B57600                                  ; enable support for PanelDue
          M550 P"Tronxy"                                     ; set printer name
          M669 K1                                            ; select CoreXY mode
          M551 P"Tronxy"                                     ; set password
          M569 P0 S1                                         ; physical drive 0 goes forwards
          M569 P1 S0                                         ; physical drive 1 goes backwards
          M569 P2 S0                                         ; physical drive 2 goes backwards
          M569 P3 S0                                         ; physical drive 3 goes backwards
          M584 X0 Y1 Z2 E3                                   ; set drive mapping
          M92 X80.00 Y80.00 Z400.00 E424.00                  ; set steps per mm
          M566 X600.00 Y600.00 Z12.00 E300.00                ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z400.00 E1800.00          ; set maximum speeds (mm/min)
          M201 X3000.00 Y3000.00 Z100.00 E10000.00           ; set accelerations (mm/s^2)
          M906 X950 Y950 Z950 E950 I30                       ; set motor currents (mA) and motor idle factor in per cent
          M208 X-10 Y-23 Z0 S1                               ; set axis minima
          M208 X320 Y313 Z390 S0                             ; set axis maxima
          M574 X1 S1 P"!xstop"                               ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !xstop
          M574 Y1 S1 P"!ystop"                               ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !ystop
          M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
          M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H5 F120 T6000                ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X63 Y-5 Z2.2                             ; set Z probe trigger value, offset and trigger height
          M557 X65:305 Y30:313 S50                            ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
          M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
          M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
          M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan1 and set its frequency
          M106 P2 S1 H1 T45                                  ; set fan 2 value. Thermostatic control is turned on
          M501
          Bed.g
          ; bed.g
          G29  ; probe the bed and enable compensation
          mesh.g
          Cant find a mesh.g i the systems files
          homeall.g
          ; homeall.g
          ; called to home all axes
          G1 H2 Z5 F6000          ; lift Z relative to current position
          G1 H1 X-335 Y-341 F1800 ; move quickly to X or Y endstop and stop there (first pass)
          G1 H1 X-335             ; home X axis
          G1 H1 Y-341             ; home Y axis
          G1 X5 Y5 F6000          ; go back a few mm
          G1 H1 X-335 F360        ; move slowly to X axis endstop once more (second pass)
          G1 H1 Y-341             ; then move slowly to Y axis endstop
          G1 X150 Y150 F9000       ; go to first bed probe point and home Z
          G30                     ; home Z by probing the bed
          ;G91                    ; relative positioning
          ;G1 Z5 F100             ; lift Z relative to current position
          ;G90                    ; absolute positioning
          HomeZ.g
          ; homez.g
          ; called to home the Z axis
          G1 H2 Z5 F9000    ; lift Z relative to current position
          G1 X150 Y150 F9000; go to first probe point
          Result of M122:
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
          Used output buffers: 3 of 24 (12 max)
          Static ram: 23876
          Dynamic ram: 75380 of which 24 recycled
          Never used RAM 15136, free system stack 124 words
          Tasks: NETWORK(ready,13.4%,237) HEAT(delaying,0.0%,314) Move(notifyWait,0.1%,293) MAIN(running,86.3%,441) IDLE(ready,0.1%,29), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:17:32 ago, cause: power up
          Last software reset at 2021-12-01 17:06, reason: User, GCodes spinning, available RAM 12104, slot 0
          Error status: 0x08
          Aux0 errors 0,0,0
          Step timer max interval 0
          MCU temperature: min 19.1, current 27.6, max 27.7
          Supply voltage: min 23.8, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 17600, standstill, SG min/max 0/189
          Driver 1: position 6400, standstill, SG min/max 0/160
          Driver 2: position 886, standstill, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-12-03 18:10:47
          Slowest loop: 13.24ms; fastest: 0.16ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 52.4ms, write time 0.0ms, max retries 3
          DMs created 83, maxWait 621510ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 34, completed moves 34, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 23], CDDA state -1
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 15.45ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          - WiFi -
          Network state is active
          WiFi firmware version 1.26
          WiFi MAC address d8:bf:c0:fc:2a:7e
          WiFi Vcc 3.40, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 24240
          WiFi IP address 192.168.87.164
          WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
          M98 P"config.g"
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 205C
          I have calibrated the probe offsets and it seems to be the same every time 🙂
            Phaedrux Moderator @gibsea402
            @gibsea402 said in Bed mesh compensation BLT:
            Can you confirm that your -X moves left, +X moves right, -Y moves forward, +Y moves back? And that if that is true your BLTouch offsets are also the correct direction in relation to the nozzle?
