menu directory is missing
Duet Web Control
435
  • undefined
    jltx
    I have no menu directory, only firmware and system. Where do I put my menu files?
    from Dozuki:
    "You can create and edit menu files within Duet web Control version 1.22.1 and later. If the /menu folder doesn't exist on the SD card, it will be created when you use the New File button to create a menu file."
    that does not work
    undefined 1 Reply Last reply 2 Dec 2021, 07:33 Reply Quote 0
    • undefined
      dc42 administrators @jltx
      @jltx do you have a direct-connect display configured using a M918 command in config.g ?
      undefined 1 Reply Last reply 4 Dec 2021, 23:41 Reply Quote 0
      • undefined
        jltx @dc42
        @dc42 indeed. M918 P2 R6 C40 E4 F200000 ; Fysetc 12864 display
        undefined 1 Reply Last reply 5 Dec 2021, 17:28 Reply Quote 0
        • undefined
          Can you confirm your firmware and DWC version?
          • undefined
            @jltx said in menu directory is missing:
            Strange, it worked for me using a 3.4beta firmware version on a Duet WiFi:
            • Without that M918 command in config.g, the drop-down list of folders doesn't have Manu Directory in it
            • When I added that command to config.g and rebooted, then Menu Directory appeared in the drop down list, even though it didn't exist on the SD card.
            Perhaps the M918 command didn't work. Is there anything on the display? What does the Object Model Browser show under boards[0].directDisplay ?
            undefined 1 Reply Last reply 14 Dec 2021, 16:50 Reply Quote 0
            • undefined
              jltx @dc42
              Sorry for delay, I was replacing some HW.
              So the object model shows null for connected display. But the display works, changing LED color to my settings, displays
              “Error loading menu
              File: main
              File not found”
              I tried moving the M918 toward end of config.g (was near beginning) but still no menu directory.
              I’m on firmware 3.3. I am now also running with SBC.
              undefined 1 Reply Last reply 14 Dec 2021, 18:00 Reply Quote 0
              • undefined
                Phaedrux Moderator @jltx
                Would you be willing to try the 3.4 beta?
                https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
                undefined 1 Reply Last reply 14 Dec 2021, 21:14 Reply Quote 0
                • undefined
                  jltx @Phaedrux
                  @phaedrux I'm reviewing the change logs.
                  I see this in dozuki "Duet 3 mainboards are supplied with an SD card loaded with the Raspian OS suitable for Raspberry Pi 2, 3B+ or 4."
                  I did not receive any SD card with my Duet 3 mainboard.
                  undefined 1 Reply Last reply 14 Dec 2021, 22:49 Reply Quote 0
                  • undefined
                    jltx
                    This post is deleted!
                    undefined 1 Reply Last reply 14 Dec 2021, 22:37 Reply Quote 0
                    • undefined
                      jltx @jltx
                      • undefined
                        When and where did you purchase the Duet 3?
                        undefined 1 Reply Last reply 14 Dec 2021, 23:24 Reply Quote 0
                        • undefined
                          jltx @Phaedrux
                          @phaedrux I got it from the US distributer, I think in May this year. Anyway, I already bought another and set it up. Just thought you should know.
                          So after a few failed attempts ("Error: Failed to connect to DCS (A task was canceled.") upgrading/downgrading between 3.3 and 3.4b6 I finally got it to stick and now I see the menu directory! Hooray!
                          Hopefully this beta is stable enough to use.
