    Help creating NeoPixel LSD-language
    Gcode meta commands
    neopixel arduino copro ws2812b
    1.6k
    • o_lampeundefined
      o_lampe
      Hi Gents,
      don't get scared, LSD stands for LED_Strip_Descriptive- language 😉
      Short story: I want to write a macro which sends various strings to an arduino.
      The arduino parses the string and controls 4 LED-strips with 72 LEDs each.
      For my HashPrinter/ Quad Ball Sand table I want to use NeoPixel strips. I tried to run one strip from a Duet2 in BitBang mode, but it didn't work at all. (Levelshifter and slowest frequency, big 5V/35A PSU)
      OTOH, the arduino nano worked right away.
      So, why not take a huge workload from the Duet and invent a descriptive language?
      My first usecase would be some spotlight where only the LEDs near the XYUV-toolheads would be on. Useful in a scenario, where a steelball has lost contact with the magnet and I have to manually jog the magnet.
      Other modes will follow. The macro call could be implemented in the gcode or sent from DWC console.
      First hurdle is, how to send a string (with momentary object model data [eg. XYUV-pos, print status, bed temps etc.] )?
      Is it a simple echo> "... to a TX-pin?
      Beside the required data, like brightness, color or speed/direction of animated changes (think slow sundown simuation), what would you like to add to such a tool?
      zaptaundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
      • zaptaundefined
        zapta @o_lampe
        @o_lampe, if the arduino contains some language interpreter (micro python?), then the duet can download once a program and then can send only commands and parameters that are specific to that program.
        E.g. in the case of the moving light at the sand table, sending head x,y and the interpreted program would do the rest.
        Extra points for a DWC plugin with IDE and LED simulator for developing those programs 😉
        BTW, have you considered using the Raspberry Pico? It's a superior module IMO, more rom/ram, faster, better API, less expensive, and you can use the PIO to generate the neo pixel 's signals.
        • o_lampeundefined
          o_lampe @zapta
          @zapta
          It would be cool to program the Arduino through a DWC plugin, but there are so many different Arduino boards and they need special parameters to flash.
          The RPi Pico was the first CoPro that came to my mind, but for the LED strips I got it would again need a level shifter. (Although I have the code for NeoPixel state machines, I don't want to add another PCB)
          The Adafruit NeoPixel library is already there and easy to use, so I'll stick with it
          zaptaundefined 1 Reply Last reply Reply Quote 0
          • o_lampeundefined
            o_lampe
            The other NeoPixel libraries I've seen yet, use 800kHz as SWI frequence.
            Why does the BitBang method for Duet2 use 2.5MHz? BTW.: I've set it to 2.4MHz, but it showed 2.5MHz?
            Even the RRF STM branch seems to use 1250ns cycle time = 800kHz
            • rjenkinsgbundefined
              rjenkinsgb
              Several Duet boards have firmware support for Neopixel and/or Dotstar already, though limited to 60 LEDs.
              The simplest expansion would be a multiplexer controlled by some other outputs, that allows each M150 to update a different bank of LEDs, so the whole array can be updated in a few lines in a macro.
              And with a separate 5V power feed so the Duet is not overloaded.
              If you specifically want to control large numbers from a separate MCU, then one simplest colour setting method could be an image file, like four rows of 72 pixels for your example, with each settable to any 32 bit RGBA value?
              Saved as uncompressed bitmaps, they are quite simple to interpret.
              For unrestricted updates within a gcode program, you cannot get around the fact that each LED somehow needs four 0-255 values.
              The format Duet use in the M150 command is pretty much as simple as it can get, for that.
              For a cheap and powerful MCU, have a look at the Seeeduino Xiao - SAMD21 ARM M0 CPU with 256K flash, 32K RAM; same as the Pi Pico but smaller. That works with the Arduino IDE once you add the Seeed library.
              It's the same memory etc. spec as the Pi Pico, but less I/O connections & Arduino compatible.
              To minimise software overhead, you can run Neopixels from an SPI port, using just the data connection.
              Each data bit to be sent becomes one nibble in the SPI stream, either 1000 for a 0 or 1100 for a 1, at an SPI data rate of 4MBit
              Pause for 50uS minimum at the end of each sequence.
              If you use 32 bit words and start with 0x88888888 as a template each time, you can translate each output byte to a word that sends 8 bits in a small, fast function that checks each input bit and sets the appropriate "4" bit in the output nibbles if its a 1.
              (I use that method in my christmas lights, though they run from a DSPIC MCU).
              Robert J.
              Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
              • o_lampeundefined
                o_lampe @rjenkinsgb
                @rjenkinsgb
                Thanks for answering. I must admit, I don't understand the last paragraphs about SW-details, but lets start from the top.
                A multiplexer would need a few extra pins and it has to be a level-shifter, too. Furthermore it wouldn't take workload from the Duet, it would quadruple it (in my case).
                With all respect, this is no option IMHO.
                @rjenkinsgb said in Help creating NeoPixel LSD-language:
                Unrestricted is not my goal. I want to describe the look of each strip instead of specifying each LEDs colour/brightness.
                Eg. tell the CoPro to fade LEDs #0-72 from dark red to bright white (*). That would be a string of a few bytes length only! The CoPro would then do the hard work of pushing Bits around.
                The restriction would be the complexity of the description.
                *) the string would be like a gcode line where each parameter has a letter followed by numbers: M150 P{0,72} B{50,250} C{hFF0000, hFFFFFF}
                Yes, I've seen that too and there is a "NeoPXL8 friend" for it, that allows us to control up to 8 strips w 250 LEDs each!
                I haven't digged deeper into this, if it would coop with Duet/gcode.
                Very promising indeed...
                rjenkinsgbundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                • o_lampeundefined
                  o_lampe @o_lampe
                  @o_lampe said in Help creating NeoPixel LSD-language:
                  I figured out it's M118 which sends data to a specific target. I'd either try USB or PaneDue port. Although IDK, if Duet's OTG USB port would act as host?
                  • zaptaundefined
                    zapta @o_lampe
                    There is no need to flash or deal with Arduino differences. Once you flash the LED language interpreter in the arduino, all should look the same. Then, at the beginning of the print you select or download the LED language program and during the print you send commands to control it (e.g. set head x,y for the sand table program).
                    The nano is very limited though, no much rom/ram. Old school 8 bits AVR 😉
                      rjenkinsgb @o_lampe
                      It would need some extra pins, yes. Two pins for four banks, three for eight etc.
                      As for workload - it is virtually zero.
                      The firmware converts the gcode parameter to the required data, then sends it using a hardware SPI port and DMA - so the whole data-output routine is hardware and uses zero CPU time or resources.
                      It just needs to interpret and convert the gcode line when that is read.
                      For an external unit, the hardest part would be getting the command string to it, from whichever Duet.
                      I had considered, for another application, using the Duet LED output as a kind of communications link to a slave SPI in the add-on MCU.
                      That can send as many words of definable data as is needed, using colour values for a small number of "LEDs" as the command data; 24 bits or more each, depending on the data format.
                      Commands like your example above could be sent by a string that, as far as the Duet is concerned, just sets colours on four LEDs.
                      Robert J.
                      • zaptaundefined
                        zapta @rjenkinsgb
                        If the goal is to have animations such as shifting heart beat, it requires frequent updates with each LED has a different color than its neighbors so I don't think the duet is a good fit (vs offloading to an external processor as @o_lampe plans to do).
                        • o_lampeundefined
                          o_lampe @rjenkinsgb
                          I have to take your word for it.
                          But then I'm asking myself, why there is a limitation of 60 LEDs in the RRF- STM branch?
                          And does it also apply for a Duet2 where I could only use BitBanging mode?
                          Nevertheless, the concept of having a second MCU (which takes over less timing critical tasks) can come handy for other FW-features as well.
                          Today I'll try the OTG USB port, see if it can feed the Arduino nano with power and data.
                          rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
                            rjenkinsgb @o_lampe
                            I'd guess the limit is down to buffer size, and power consumption?
                            60 LEDs with a 32 bit value each is 240 bytes, plus four bytes each for start and stop codes, plus buffer pointers etc. so roughly 256 bytes RAM.
                            And for a direct board connection, the 5V regulator has to feed the LEDs, which may be the more critical restriction.
                            That's for DotStar LEDs, which use SPI clock and data.
                            I went through the V3.3 firmware and they were the only LED option I could find; no mention of neopixels.
                            If your board supports firmware 3.3, it should work via DMA regardless of the exact board type.
                            [That's for the "official" RRF branch - no idea what the STM32 capabilities are, or what connectivity the hardware designers have included]
                            I'm not saying any one approach is "best", just going over possibilities to achieve the end result, and as a programmer it's an interesting idea!
                            Robert J.
                            o_lampeundefined 1 Reply Last reply Reply Quote 1
                            • o_lampeundefined
                              o_lampe @rjenkinsgb
                              The limit regarding current consumption is much lower than 60 LEDs. 8-10 LEDs with full brightness is max. (YMMV)
                              I'm sure it's related to SPI buffer size. So there is a limited resource worth to preserve for other tasks.
                              • o_lampeundefined
                                o_lampe
                                I got some reaction from the Arduino, when using RX/TX @57600 Baud. But I'd need a levelshifter here, I guess.
                                Over USB, I got no feedback whatsoever. Tried different M575 settings.
                                Maybe have to rewrite the Arduino Code, but IIRC the serial port 0 is the same as USB?
                                • o_lampeundefined
                                  o_lampe
                                  @rjenkinsgb
                                  beside the Seeedstudio Xiao, I also found the DFRobot Firebeetle M0 which has a huge 12MB +16MB storage capacity and a small breadboard area. (for level shifters and power distribution?) The storage would be big enough for some Bitmaps or other animated NeoPixel stuff.
                                  I would then only have to call the right animation, which I'll have predefined in flash.
                                  Not sure yet how to program it. Maybe the bootloader is specific for robotics-stuff?
                                  rjenkinsgbundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                                    rjenkinsgb @o_lampe
                                    @o_lampe
                                    Nice!
                                    That works with the Arduino IDE again, you just need to add the appropriate DFRobot SDK file; the instructions & file link are in the Audio photo album project section.
                                    Robert J.
                                    • o_lampeundefined
                                      o_lampe @rjenkinsgb
                                      RE audio: beside bitmaps and animations I could store some background music, too!
                                      The sand table is pretty noisy with only 1 ball, but 4 ball-ballet definitly needs some sound.
                                      I read a comment about a broken arduino library link. I hope it's sorted out now...
                                      • zaptaundefined
                                        zapta @o_lampe
                                        Very nice find. I bookmarked it. For IDE I suggest to check platformio. They support many CPUs and platforms and provide an very functional and auto updatable development environment on top of VSCode.
                                        https://docs.platformio.org/en/latest/platforms/atmelsam.html
                                        • o_lampeundefined
                                          o_lampe @zapta
                                          @zapta
                                          The DFRobot board isn't listed (yet) in PlatformIO. I'm not sure, if it would support the extra flash?
                                          Furthermore, PlatformIO seems to work on Linux systems. That's not my favourite OS, especially when it's text-based. I hate to search the web for every config-line and almost have to beg for read/write permissions as normal user.
                                          • o_lampeundefined
                                            o_lampe
                                            For those who want to install the DFRobot firebeetle M0 files for Arduino IDE:
                                            don't use the link provided in their Wiki!
                                            Instead use this link
                                            http://download.dfrobot.top/firebeetle/package_DFRobot_test_index.json
                                            Then open the boardmanager as usual and search for dfrobot. You will see several firebeetle packages, choose the M0 and your ready 🙂
