    Using a Button with daemon.g
    Gcode meta commands
    • NeueKlasseundefined
      NeueKlasse
      I want to use a Button to Switch an Output
      (Button pressed (IO7.in) -> Output (Out7) on)
      (Button released: Output off)
      I‘m not Sure if daemon.g is capable of.. let‘s say
      a 100ms Cycletime (reliable), without bursting to
      Much Energy of the Atmel Chip.
      1 Second is way to slow for the goal to
      switch a laser on/off,
      And i hate to do that with the Touchscreen..
      Prusa Mini, Chiron @ BMG X2
      Metal SLS Printer Development
      fcwiltundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
      • Phaedruxundefined Phaedrux moved this topic from Using Duet Controllers
      • fcwiltundefined
        fcwilt @NeueKlasse
        @neueklasse
        daemon.g runs once every 10 seconds - I doubt that would work for you.
        Perhaps this will help:
        Trigger Example
        NeueKlasseundefined 1 Reply Last reply Reply Quote 0
          jay_s_uk @NeueKlasse
          @neueklasse use a loop using while. That will allow daemon.g to run constantly
            NeueKlasse @fcwilt
            @fcwilt
            Thanks, i don't had in mind that Duet has this Function, it works as expected!
            @jay_s_uk
            I never read about Loops faster than 1 second in RRF, what is the maximum possible?
            i suppose a while loop without a G4 Command inside can crash the Software?
            it's also not easy to Edit the daemon.g file.. only after having the .part file that'll
            be created after you try to edit the daemon.g file...
            maybe it's possible to STOP the daemon.g file from Running to edit it? maybe with a M-Command?
            for example the KUKA Roboters use a similar thing, called a "sps.sub" (submitinterpreter)
            and it is possible to Stop it separately...
            Alex.crundefined 1 Reply Last reply Reply Quote 0
              jay_s_uk
              @neueklasse actually, why not just use a trigger?
              Why does it have to be daemon.g?
              • Alex.crundefined
                Alex.cr @NeueKlasse
                @neueklasse I ran into the same problem about daemon.g being a pain to edit when a 'while true' statement was used. Instead of using a 'true' statement I made this a variable I called 'daemonRun' that I set to 1 in the config. When I want to edit daemon.g I first set it to 0 and then change daemon.g and reset it back to one.
                Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
