    Additional stepstick extruders playing nice with onboard tmc2660
    • raykholo
      raykholo last edited by
      This shows how to add a 3rd extruder via breakout and stepstick: https://duet3d.com/wiki/Using_external_drivers
      Is it possible to use this and the first 2 extruder TMC2660 drivers together?
      I read somewhere that for dynamic microstepping to work all the drivers had to be of the same type, so I would like to get clarification on this.
      Thanks,
      Ray
        The restriction is that if you assign more than one driver to the same axis (e.g. to use two or three Z leadscrew drivers), those drivers must use the same microstepping. So there should be no problem with using a stepstick to drive a 3rd extruder, and different extruders can use different microstepping.
        • raykholo
          Thanks for the clarification.
          There may be a possible typo on that external drivers page, the TB6600 is rated to 4A max, not 5.
            @raykholo:
            I've checked the datasheet and the TB6600 IC is rated at 5A peak, 4.5A "operating range maximal value". So I've changed the value 5A to 4.5A in that wiki page.
            • raykholo
              Interesting. Every China vendor notes 4.0 peak and the box has settings shown up to 4.0 peak.
              I do see your point about the 4.5 and 5A values concerning the IC itself.
                The peak current you can use in practice will depend on how well the chip is cooled.
