    Heater fault but print keeps going
    • Gordon Linundefined
      Gordon Lin
      Guys,
      My printer is showing heater fault, it turns off the heater BUT the print keeps going, until the hot end is too cold then it jams.
      One would assume if a fault is detected then it would pause the print? If I pause the print using the panel it does work.
      Any ideas?
      12/6/2021, 9:51:35 AM M122
      RepRapFirmware for Duet 3 MB6HC version 3.4.0beta1 (2021-07-10 16:20:28) running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956L2-G43S8-6JKDJ-3S86J-983AF
      Used output buffers: 2 of 40 (13 max)
      Static ram: 150904
      Dynamic ram: 62832 of which 192 recycled
      Never used RAM 137408, free system stack 142 words
      Tasks: SBC(ready,1.9%,324) HEAT(delaying,0.0%,203) Move(notifyWait,0.1%,254) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,366) CanClock(delaying,0.0%,339) TMC(notifyWait,20.5%,59) MAIN(running,77.3%,922) IDLE(ready,0.1%,29), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 02:36:18 ago, cause: power up
      Last software reset details not available
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 164
      MCU temperature: min 29.7, current 49.7, max 50.2
      Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/118/106, gc cycles 0
      Driver 0: position 28800, standstill, reads 19089, writes 21 timeouts 0, SG min/max 0/1023
      Driver 1: position 20000, standstill, reads 19089, writes 21 timeouts 0, SG min/max 0/1023
      Driver 2: position 2578, standstill, reads 19089, writes 21 timeouts 0, SG min/max 0/1023
      Driver 3: position 0, standstill, reads 19089, writes 21 timeouts 0, SG min/max 0/1023
      Driver 4: position 0, standstill, reads 19089, writes 21 timeouts 0, SG min/max 0/1023
      Driver 5: position 0, standstill, reads 19089, writes 21 timeouts 0, SG min/max 0/1023
      Date/time: 2021-12-05 20:51:33
      Slowest loop: 80.06ms; fastest: 0.03ms
      === Storage ===
      Free file entries: 10
      DMs created 125, maxWait 774590ms, bed compensation in use: mesh, comp offset 0.014
      === MainDDARing ===
      Scheduled moves 9388, completed moves 9388, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 49], CDDA state -1
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.1
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File* is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 93586, received 112391, lost 0, longest wait 1ms for reply type 6018, peak Tx sync delay 455, free buffers 48 (min 45), ts 46891/46890/0
      Tx timeouts 0,0,0,0,0,0
      === SBC interface ===
      State: 4, failed transfers: 1, checksum errors: 0
      Last transfer: 3ms ago
      RX/TX seq numbers: 37629/37629
      SPI underruns 0, overruns 0
      Disconnects: 0, timeouts: 0, IAP RAM available 0x2c778
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.4-b1
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz
      Full transfers per second: 28.39, max wait times: 81.2ms/0.0ms
      Codes per second: 0.35
      Maximum length of RX/TX data transfers: 5052/1664
      File /opt/dsf/sd/gcodes/extreme.gcode is selected, paused
      Thanks for your help.
      Gordon
        Can you share your full config.g?
        Are you using toolboards?
        Have you seen the limitations listed here? https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations
        Have you tested with 3.4 beta6?
        Gordon Linundefined 1 Reply Last reply Reply Quote 0
        • Phaedruxundefined Phaedrux moved this topic from Firmware installation
          Gordon Lin @Phaedrux
          @phaedrux hello, yes I am using a expansion board, and I am still on firmware 3.4.0beta1, I will upgrade now. here is my full config.
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 08 2021 13:20:30 GMT+1200 (New Zealand Standard Time)
          M550 P"Duet 3" ; set printer name
          M669 K1 ; select CoreXY mode
          M569 P0.0 S1 ; physical drive 0.0 goes forwards X
          M569 P0.1 S1 ; physical drive 0.1 goes forwards Y
          M569 P0.2 S1 ; physical drive 0.2 goes forwards Z0
          M569 P0.3 S0 ; physical drive 0.2 goes forwards Z1
          M569 P0.4 S1 ; physical drive 0.2 goes forwards Z2
          M569 P0.5 S0 ; physical drive 0.2 goes forwards Z3
          M569 P1.0 S1 ; physical drive 1.0 goes forwards Extruder
          M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0 ; set drive mapping
          M92 X80.00 Y80.00 Z400.00 E429 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120 ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z3000 E15000 ; set maximum speeds (mm/min)
          M201 X2000 Y2000 Z250 E1800 ; set accelerations (mm/s^2)
          M204 P1500 T2000
          M906 X1200 Y1200 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X350 Y355 Z280 S0 ; set axis maxima
          M574 X2 S1 P"^io1.in" ; configure active-high endstop for high end on X via pin !^io1.in
          M574 Y2 S1 P"^io2.in" ; configure active-high endstop for high end on Y via pin !^io2.in
          M574 Z0 S1 P"nil"
          M558 K0 P8 C"^io4.in" T18000 F120 H5 A5 S0.01 R0.2
          G31 K0 P500 X0 Y23.5 Z1.822 ; Don't really care about inductive probe Z offset
          M558 K1 P8 C"^io3.in" T18000 F120 H2 A10 S0.005 R0.2
          G31 K1 P500 X0 Y0 Z0.70 ; Z switch offset (if positive, greater value = lower nozzle. if negative, more negative = higher nozzle)
          ;at 60°C Z=0. at 100°C Z = ; at 70° Z = 0.70
          M671 X-58:-58:420:420 Y0:421:421:0 S10
          M557 X25:325 Y25:325 S25 ; define mesh grid
          M308 S0 A"Bed heater" P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
          M308 S2 A"Bed plate" P"temp1" Y"thermistor" T100000 B4725 C7.06e-8
          M950 H0 C"out1" T2 ; create bed heater output on out1 and map it to sensor 2
          M140 P0 H0 ; map heated bed to heater 1
          M143 H0 P1 T0 A2 S115 C0
          M143 H0 P2 T2 A1 S110 C0
          M143 H0 S110 ; set temperature limit for heater 1 to 110C
          M308 S1 A"Hotend" P"1.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as PT1000 on pin 1.temp0
          M950 H1 C"1.out0" T1 ; create nozzle heater output on 1.out0 and map it to sensor 1
          M143 H1 S350 ; set temperature limit for heater 0 to 350C
          M950 F0 C"1.out6" Q250 ; create fan 0 on pin 1.out6 and set its frequency
          M950 F1 C"1.out7" Q20 ; create fan 1 on pin 1.out7 and set its frequency
          M308 S3 Y"mcu-temp" A"MCU"
          M308 S4 Y"drivers" A"DIVERS"
          M950 F2 C"out7" Q30
          M950 F3 C"out8" Q30
          M106 P2 S1 H3:4 T50 C"MCU"
          M106 P3 S1 H3:4 T50 C"MCU"
          M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
          T0 ; select first tool
          M572 D0 S0.075 ; Pressure Advance PLA 0.075 PETG 0.2
          M592 D0 A0.015 B0.0012 L0.2 ; Non-linear extrusion
          M376 H10 ; Fade mesh out compensation over 10mm Z
