    Extrusion Control in DWC unavailable, even after M302 P1
    Duet Web Control
    358
    • oracledudeundefined
      oracledude
      Trying to figure out why I can't run my extruder. M122 shows some weird messages:
      Driver 0: position 38683, standstill, read errors 0, write errors 1, ifcnt 23, reads 6775, writes 6, timeouts 0, DMA errors 0
      Driver 1: position 38683, standstill, read errors 0, write errors 1, ifcnt 23, reads 6775, writes 6, timeouts 0, DMA errors 0
      Driver 2: position 38683, standstill, read errors 0, write errors 1, ifcnt 23, reads 6775, writes 6, timeouts 0, DMA errors 0
      Driver 3: position 0, standstill, read errors 0, write errors 1, ifcnt 20, reads 6775, writes 6, timeouts 0, DMA errors 0
      Driver 4: position 0, standstill, read errors 0, write errors 1, ifcnt 20, reads 6775, writes 6, timeouts 0, DMA errors 0
      Driver 5: position 0, assumed not present
      Driver 6: position 0, assumed not present
      I only have 4 motors in the printer X, Y, Z & E. Why would both 3 & 4 report errors? Did I fry a driver somehow?
      Since I know someone will ask for it, here's my config.g:
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      M550 P"Griffin Delta"                              ; set printer name
      M665 R130 L288.87 B130 H229.4                      ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0                                      ; endstop adjustments here, or let auto calibration find them
      M586 P0 S1 C"*"                                    ; enable HTTP
      M586 P1 S1                                         ; enable FTP
      M586 P2 S1                                         ; enable Telnet
      M569 P0 S0                                         ; physical drive 0 goes backwards
      M569 P1 S0                                         ; physical drive 1 goes backwards
      M569 P2 S0                                         ; physical drive 2 goes backwards
      M569 P3 S1                                         ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M92 X80.00 Y80.00 Z80.00 E506.92                   ; set steps per mm
      M566 X12000.00 Y12000.00 Z12000.00 E1200.00        ; set maximum instantaneous speed changes (mm/min) ---was 1200
      M203 X18000.00 Y18000.00 Z18000.00 E2400.00        ; set maximum speeds (mm/min)
      M201 X5000.00 Y5000.00 Z5000.00 E1000.00           ; set accelerations (mm/s^2)  -- was 1000
      M906 X1000 Y1000 Z1000 E1000 I30                   ; set motor currents (mA) and motor idle factor in per cent
      M208 Z0 S1                                         ; set minimum Z
      M574 X2 S1 P"xstop"                                ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop"                                ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop"                                ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
      M558 P1 X0 Z0 H5 F600 T5000 C"zprobe.in+zprobe.mod" ; Set Z probe type to dc42 IR_PROBE
      G31 P450 X18 Y18 Z0.934                            ; set Z probe trigger value, offset and trigger height
      M557 R75 S20                                       ; define mesh grid
      ; Bed Heater
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 A"Bed Heater"    ; configure sensor 0 as thermistor on pin bedtemp
      ;M307 H0 B0 S0.90                                   ; use PID tuning for the bed heater and set PWM limit // CONFIG_OVERRIDE handles this
      M140 H0                                            ; map bed to heater 0
      M140 S-273 R40                                     ; active/standby to 25/40.  turn off bed heater by setting to -273
      ; Hot End Heater
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138 A"Hot End"      ; configure sensor 1 as thermistor on pin e0temp
      ;M307 H1 B0 S0.90                                   ; use PID tuning for the heater and set PWM limit // CONFIG_OVERRIDE handles this
      ; Fans  Q30000 Q1000
      M950 F0 C"fan0"                                    ; Layer fan on pin fan0 and set its frequency
      M106 P0 S0 H-1 C"Print Layer Fan"                  ; set fan 0 starting speed. Thermostatic control is disabled
      M950 F1 C"fan1"                                    ; Heat sink fan on pin fan1 and set its frequency
      M106 P1 S1 H1 T45 C"HotEndFan"                     ; set fan 1 value. Thermostatic control is turned on
      M563 P0 S"DeltaEffector" H1 F0			   ; define tool 0 with heater 1, fan 0
      ;G10 P0 R25 S125                                   ; Active 125 Standby 25
      M568 P0 R20 S25 A0                                 ; replaces g10; Set tool 0 Active/Standby=150C/25C and Current State = Off   R25 S150 A0
      M501                                               ; load saved parameters from non-volatile memory
      T0                                                 ; select first tool
      • o_lampeundefined
        o_lampe @oracledude
        @oracledude said in Extrusion Control in DWC unavailable, even after M302 P1:
        Your tool definition misses a D parameter for the extruder drive.
        oracledudeundefined 1 Reply Last reply Reply Quote 1
          oracledude @o_lampe
          @o_lampe - It seemed to be hit or miss in examples with the D0 in tool definition, so I left it out at first. Re-added it, but still getting no joy from the extruder section of DWC, nor can I use GCODE to cold extrude.
          M122:
          RepRapFirmware for Duet 2 Maestro version 3.3 (2021-06-15 21:47:01) running on Duet Maestro 1.0
          Board ID: 08DAM-9F9GA-J24TD-6JKD0-3S86R-KP3UT
          Used output buffers: 5 of 24 (17 max)
          Static ram: 23556
          Dynamic ram: 66972 of which 0 recycled
          Never used RAM 24968, free system stack 214 words
          Tasks: NETWORK(ready,26.3%,262) HEAT(delaying,0.1%,353) Move(notifyWait,0.1%,403) TMC(notifyWait,1.3%,117) MAIN(running,71.8%,493) IDLE(ready,0.5%,30), total 100.0%
          Owned mutexes:
          Last reset 00:00:32 ago, cause: software
          Last software reset at 2021-12-06 08:17, reason: User, GCodes spinning, available RAM 24968, slot 1
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 940
          MCU temperature: min 22.1, current 23.2, max 23.4
          Supply voltage: min 14.0, current 14.1, max 14.1, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 38683, standstill, read errors 0, write errors 1, ifcnt 23, reads 5391, writes 6, timeouts 0, DMA errors 0
          Driver 1: position 38683, standstill, read errors 0, write errors 1, ifcnt 23, reads 5391, writes 6, timeouts 0, DMA errors 0
          Driver 2: position 38683, standstill, read errors 0, write errors 1, ifcnt 23, reads 5391, writes 6, timeouts 0, DMA errors 0
          Driver 3: position 0, standstill, read errors 0, write errors 1, ifcnt 20, reads 5391, writes 6, timeouts 0, DMA errors 0
          Driver 4: position 0, standstill, read errors 0, write errors 1, ifcnt 20, reads 5391, writes 6, timeouts 0, DMA errors 0
          Date/time: 2021-12-06 08:18:22
          Slowest loop: 24.27ms; fastest: 0.16ms
          === Storage ===
          Free file entries: 10
          SD card 0 detected, interface speed: 15.0MBytes/sec
          SD card longest read time 0.5ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = 0 -1, chamberHeaters = -1 -1
          Heater 0 is on, I-accum = 0.0
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 10.83ms; fastest: 0.02ms
          HTTP sessions: 1 of 8
          Interface state active, link 100Mbps full duplex
          updated config.g line:
          M563 P0 S"DeltaEffector" H1 F0 D0		           ; define tool 0 with heater 1, fan 0, extruder 0
            If you send M98 P"config.g" what does it respond with?
            What version of DWC are you using?
            What exactly do you see in DWC?
            Can you show a screenshot of what you see and explain what you expect to see?
            oracledudeundefined 1 Reply Last reply Reply Quote 0
              oracledude @Phaedrux
              M98 P"config.g"
              HTTP is enabled on port 80
              FTP is enabled on port 21
              TELNET is enabled on port 23
              Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 265C
              Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 522C
              Duet Web Control 3.4.0-b6
              I'd expect Retract and Extrude to become available. I don't think it's a DWC issue though, since G1 F200 E100 isn't engaging the stepper at all.
              The extruder motor works when connected to a different driver (x,y,z)
                jay_s_uk @oracledude
                @oracledude do you have a tool active?
                  oracledude
                  Doesn't the T0 at the end of the config.g select a tool?
                  • chrishammundefined
                    chrishamm administrators @oracledude
                    @oracledude If you have a heater and extruder mapped to a tool (M563 ... H1 D0), it must be active (selected) and up to temperature (> 160C for extrusion AFAIR). You can override the temperature limitation by sending M302 P1.
                    Duet software engineer
                      oracledude
                      Seems that once I clicked on the tool in DWC it worked, even after several resets. Guess that solved it. Thanks all.
