    M84 error after upgrade to 3.3
    1.7k
    • mringersollundefined
      mringersoll
      Hello everything worked fine when i was at ver 3.22 than went to ver 3.3 and now things are messed up
      get a M84 error tells me the line in the Gcode and all but how do i look at the error. also now the nozzle does not go down close to print bed stays about 10 mm up.
      Thank You
      Mike
        Can you provide us with more information?
        Can you share your full config.g and the results of sending M122 and M98 P"config.g" ?
        Where do you see the M84 error?
        For your nozzle problem if may help to share your homing files, bed.g, start gcode, etc.
        mringersollundefined 1 Reply Last reply Reply Quote 0
          mringersoll @Phaedrux
          @phaedrux
          Ok been a while went back to 3.2.2 and all is fine, anyway how do i post the info you are requesting and i will reinstall 3.3 and post the info sound good right after the print that is going is done.
          Mike
            Phaedrux Moderator @mringersoll
            @mringersoll said in M84 error after upgrade to 3.3:
            Copy and paste.
              @phaedrux Ok here we go The Error comes after i start print either during the Bed Probing or right after.
              12/9/2021, 3:44:02 PM M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
              Board ID: 08DGM-9T6BU-FG3S8-6J9DD-3S86R-KBKHF
              Used output buffers: 6 of 24 (16 max)
              Static ram: 23876
              Dynamic ram: 75072 of which 0 recycled
              Never used RAM 15468, free system stack 174 words
              Tasks: NETWORK(ready,12.0%,246) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,86.4%,461) IDLE(ready,1.5%,29), total 100.0%
              Owned mutexes:
              Last reset 00:01:02 ago, cause: power up
              Last software reset time unknown, reason: User, GCodes spinning, available RAM 15468, slot 0
              Error status: 0x00
              Aux0 errors 0,0,0
              Step timer max interval 0
              MCU temperature: min 18.9, current 24.0, max 24.2
              Supply voltage: min 24.3, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: position 0, standstill, SG min/max not available
              Driver 1: position 0, standstill, SG min/max not available
              Driver 2: position 0, standstill, SG min/max not available
              Driver 5: position 0
              Driver 6: position 0
              Driver 7: position 0
              Driver 8: position 0
              Driver 9: position 0
              Driver 10: position 0
              Driver 11: position 0
              Date/time: 2021-12-09 15:44:01
              Cache data hit count 2273262020
              Slowest loop: 5.70ms; fastest: 0.17ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 7.2ms, write time 0.0ms, max retries 0
              === MainDDARing ===
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 16.18ms; fastest: 0.00ms
              Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is active
                WiFi firmware version 1.26
                WiFi MAC address b4:e6:2d:60:31:eb
                WiFi Vcc 3.28, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 24792
                WiFi IP address 10.0.0.169
                WiFi signal strength -64dBm, mode 802.11n, reconnections 0, sleep mode modem
                Clock register 00002002
              Config.g
              ; Configuration file for Duet WiFi (firmware version 3.3)
              ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Dec 06 2021 04:14:12 GMT-0600 (Central Standard Time)
              M550 P"My Hacked Ender 3" ; set printer name
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P0 S0 ; physical drive 0 goes backwards
              M569 P3 S0 ; physical drive 3 goes backwards
              M92 X80.00 Y80.00 Z400.00 E97.18 ; set steps per mm
              M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
              M906 X850 Y850 Z850 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X-3 Y-3 Z0 S1 ; set axis minima
              M208 X235 Y235 Z255 S0 ; set axis maxima
              M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
              M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
              M574 Z1 S2 ; configure Z-probe endstop for low end on Z
              M558 P5 C"^!zprobe.in" H5 F240 T9000 ; set Z probe type to switch and the dive height + speeds
              G31 P1000 X-47 Y-11 Z1.90 ; set Z probe trigger value, offset and trigger height
              M557 X12:193 Y16:214 S25 ; define mesh grid
              M307 H0 B1 S1.50 ; enable bang-bang mode for the bed heater and set PWM limit
              M143 H0 S150 ; set temperature limit for heater 0 to 150C
              M307 H1 B0 S0.00 ; disable bang-bang mode for heater and set PWM limit
              M106 P1 S1 H1 T65 ; set fan 1 value. Thermostatic control is turned on
              12/9/2021, 3:47:32 PM M98 P"config.g"
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is disabled
              Error: bad model parameters
              Phaedruxundefined 2 Replies Last reply Reply Quote 0
                Yes, and what exactly is the error?
                  @phaedrux sorry here is the error also the print head is like 6mm off the bed when it starts printing but for some reason the display says it is at.30 for Z axis i am really confused with this please help 3.2.2 works fine so maybe just go back to 3.2.2 and stay there i guess.
                  12/10/2021, 3:04:49 PM Error: in GCode file line 20 column 6: M84: expected number after 'E'
                  same error just different lines and columns depends the file i choose for printing.
                  Mike
                  • fcwiltundefined
                    fcwilt @mringersoll
                    Please post that line of code which is generating the error.
                    mringersollundefined 2 Replies Last reply Reply Quote 0
                      mringersoll @fcwilt
                      @fcwilt
                      so how do i get to that line of code to post it?
                        mringersoll @fcwilt
                        @fcwilt
                        and what do i use to open it to get the line
                        Thanks
                        • fcwiltundefined
                          fcwilt @mringersoll
                          Thanks
                          It's a text file. You can open it in most any text editor - one with line numbers would be helpful.
                          Or you can also upload to the SYSTEM folder in the DWC and open it there.
                            mringersoll @fcwilt
                            @fcwilt
                            M84 E ; disable for more accurate probing,is what is says.
                            Also why is the Z axis staying up so high the nozzle is about 6mm from the bed. and during probing i does not go down much at all before it goes back up the probe is triggering way early not even close to the bed when I home the printer the probe works as expected don't get it.
                            Mike
                            fcwiltundefined 2 Replies Last reply Reply Quote 0
                            • fcwiltundefined
                              fcwilt @mringersoll
                              Well there is why you are getting an error. Whatever is generating that line of code is not putting the number(s) after the E.
                              If you use to work possibly the older firmware didn't handle that error properly or perhaps in the absence of any number(s) it used a default.
                              • fcwiltundefined
                                fcwilt @mringersoll
                                We would need to see your homing files first.
                                Have you made any changes to your config file? If so post it again.
                                  If you change that line to M84 E0 that should solve that error, though I'm not sure it's related to your homing problem. For that we would need to see your homing files and start gcode as well.
                                    @phaedrux Ok here are the homing files but my problem is the nozzle stays like 3mm above bed when it prints.
                                    ; homeall.g
                                    ; called to home all axes
                                    G91 ; relative positioning
                                    G1 H2 Z5 F9000 ; lift Z relative to current position
                                    G1 H1 X-243 Y-241 F2400 ; move quickly to X and Y axis endstops and stop there (first pass)
                                    G1 H2 X5 Y5 F9000 ; go back a few mm
                                    G1 H1 X-243 Y-241 F600 ; move slowly to X and Y axis endstops once more (second pass)
                                    G90 ; absolute positioning
                                    G1 X59 Y27 F9000 ; go to first bed probe point and home Z
                                    ;G91 ; relative positioning
                                    ;G1 Z5 F150 ; lift Z relative to current position
                                    ;G90 ; absolute positioning
                                    ; homex.g
                                    ; called to home the X axis
                                    G1 H1 X-240 F2400 ; move quickly to X axis endstop and stop there (first pass)
                                    G1 H2 X5 F9000 ; go back a few mm
                                    G1 H1 X-240 F600 ; move slowly to X axis endstop once more (second pass)
                                    G1 H2 Z-5 F9000 ; lower Z again
                                    ; homey.g
                                    ; called to home the Y axis
                                    G1 H1 Y-240 F2400 ; move quickly to Y axis endstop and stop there (first pass)
                                    G1 H2 Y5 F9000 ; go back a few mm
                                    G1 H1 Y-240 F600 ; move slowly to Y axis endstop once more (second pass)
                                    ; homez.g
                                    ; called to home the Z axis
                                    G1 X59 Y25 F9000 ; go to first probe point
                                      What type of Z probe do you have?
                                      Have you calibrated the z trigger height recently?
                                      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                                      What do you have in your slicer start gcode? I don't see anything wrong with your homing files.
                                        @phaedrux Hello Again
                                        I am using an EZabl for my probe and calibration about 2 days ago. I am using an Ender 3 Cura or simplfy3d slicer i tried to copy and paste to get my cura Start G code but does not work.
                                        Mike
                                          @phaedrux Hello
                                          Here is the start gcode from my slicer
                                          ;M75 ; Start Print Timer and Engage Fil Sensor if USB Printing
                                          G92 E0 ; Reset Extruder distance to 0
                                          G1 E-2 ; Retracts filament to prevent blobs during probing
                                          M84 E ; Disable E Motor for probe accuracy on direct drive systems
                                          G28 ; home all axes
                                          G28 Z ; home Z to get more accurate Z position
                                          G29; EZABL mesh generation
                                          G4 S10; wait for heaters to recover
                                          M117 Purge extruder
                                          G92 E0 ; reset extruder
                                          G1 Z1.0 F3000 ; move z up little
                                          G1 X0.16 Y26 Z0.3 F5000.0 ; move to start-line position
                                          G1 X0.16 Y110.0 Z0.3 F750.0 E15 ; draw 1st line
                                          G1 X0.6 Y110.0 Z0.3 F3000.0 ; move to side a little
                                          G1 X0.4 Y13 Z0.3 F730.0 E12 ; draw 2nd line
                                          M117 Printing.....
                                          • fcwiltundefined
                                            fcwilt @mringersoll
                                            @phaedrux Hello
                                            G28 ; home all axes
                                            M117 Purge extruder
                                            M117 Printing.....
                                            Where did that code come from?
