    Strange noise from X-axis after upgrading 3.3 -> 3.4.0-b6
    Beta Firmware
    445
    • Falkiaundefined
      Falkia
      After upgrading to 3.4.0-b6 there is strange noise from the X-axis when jogging from position 0.0 (Its just when the movement starts, and it looks like the axis jumps).
      If I jog X increment 10.0mm:
      • from 0.0 -> 10.0 (noise)
      • from 10.0 -> 0.0 (OK)
      • from 0.0 -> -10.0 (noise)
      • from -10.0 -> 0.0 (OK)
      • from -5.0 -> +5.0 (OK)
      • from +5.0 -> -5.0 (OK)
      Delta with Duet 2 WiFi. Smart effector but its not wired so the parameters for M665 are manually entered.
      The macros I have for testing the machine (only move axis) does not work so good anymore. I think steps are missing and a lot of hiccups is reported by M122
      m122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta6 (2021-11-06 11:37:41) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3SN-6JTD8-3SJ6L-9BWMG
      Used output buffers: 3 of 24 (24 max)
      Static ram: 23772
      Dynamic ram: 74772 of which 264 recycled
      Never used RAM 10272, free system stack 134 words
      Tasks: NETWORK(ready,14.4%,238) HEAT(notifyWait,0.0%,342) Move(notifyWait,0.0%,305) MAIN(running,85.6%,366) IDLE(ready,0.0%,30), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:15:51 ago, cause: software
      Last software reset at 2021-12-08 20:25, reason: User, GCodes spinning, available RAM 13152, slot 2
      Error status: 0x00
      Step timer max interval 0
      MCU temperature: min 34.1, current 34.4, max 34.9
      Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/20/20, gc cycles 0
      Driver 0: pos 213168, standstill, SG min 0
      Driver 1: pos 214760, standstill, SG min 0
      Driver 2: pos 212578, standstill, SG min 0
      Driver 3: pos 0, standstill, SG min n/a
      Driver 4: pos 0, standstill, SG min n/a
      Driver 5: pos 0
      Driver 6: pos 0
      Driver 7: pos 0
      Driver 8: pos 0
      Driver 9: pos 0
      Driver 10: pos 0
      Driver 11: pos 0
      Date/time: 2021-12-08 20:41:27
      Slowest loop: 3.93ms; fastest: 0.17ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 0.6ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 6, maxWait 48797ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 35, completed 35, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 10], CDDA state -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === Network ===
      Slowest loop: 199.83ms; fastest: 0.08ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      Failed messages: pending 0, notready 0, noresp 3
      WiFi firmware version 1.26
      WiFi MAC address 84:f3:eb:42:a2:ea
      WiFi Vcc 3.39, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 22440
      WiFi IP address 192.168.50.6
      WiFi signal strength -49dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.6 on Thu Nov 25 2021 21:02:18 GMT+0100 (centraleuropeisk normaltid)
      G90                                                 ; send absolute coordinates...
      M83                                                 ; ...but relative extruder moves
      M550 P"Deltacus"                                    ; set printer name
      M665 R300 L600 B285 H920                           ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0                                       ; put your endstop adjustments here, or let auto calibration find them
      M552 S1                                             ; enable network
      M586 P0 S1                                          ; enable HTTP
      M586 P1 S0                                          ; disable FTP
      M586 P2 S0                                          ; disable Telnet
      M569 P0 S1                                          ; physical drive 0 goes forwards
      M569 P1 S1                                          ; physical drive 1 goes forwards
      M569 P2 S1                                          ; physical drive 2 goes forwards
      M569 P3 S1                                          ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                    ; set drive mapping
      M92 X160.00 Y160.00 Z160.00 E663.00 				; set steps per mm
      M350 X16 Y16 Z16 E16 I1                             ; configure microstepping with interpolation
      M566 X800.00 Y800.00 Z800.00 E800.00            ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z15000.00 E1200.00         ; set maximum speeds (mm/min)
      M201 X4000.00 Y4000.00 Z4000.00 E1000.00            ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z1500 E800 I30                     ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                             ; Set idle timeout
      M208 Z0 S1                                          ; set minimum Z
      M574 X2 S1 P"xstop"                                 ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop"                                 ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop"                                 ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
      M558 P5 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
      G31 P500 X0 Y0 Z2.5                                 ; set Z probe trigger value, offset and trigger height
      M557 R85 S20                                        ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138      ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                               ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B1 S1.00                                    ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                             ; map heated bed to heater 0
      M143 H0 S120                                        ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138       ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                                    ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                        ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                                ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                      ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                                ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                   ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                    ; define tool 0
      G10 P0 X0 Y0 Z0                                     ; set tool 0 axis offsets
      G10 P0 R0 S0                                        ; set initial tool 0 active and standby temperatures to 0C
      Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
      Falkiaundefined 1 Reply Last reply Reply Quote 0
      • Falkiaundefined
        Falkia @Falkia
        Update: The problem is for Y axis also but only from -150.0 in any direction.
        • Falkiaundefined
          Falkia @Falkia
          Update 2:
          Testing all other 3.4 beta versions and this problem occurs first with beta 4.
          • Phaedruxundefined Phaedrux moved this topic from General Discussion
          • Falkiaundefined
            Falkia @Falkia
            Reading the change log for beta 4, there is a bug fix for step calculation for delta printers. Maybe that has something to do with this. Any clue @dc42 ?
            • Falkiaundefined
              Falkia
              Update 3:
              Changing the Delta Radius with M665 affect the position where the Y axis makes the noise. The position where the X axis makes the noise is still at 0.0.
              • Falkiaundefined
                Falkia
                Made a firmware downgrade to 3.3 and now the printer is happy and so am I. 👍
                  Thanks for verifying that switching back to 3.3 resolves the issue.
                  • Falkiaundefined
                    Falkia @Phaedrux
                    @phaedrux yes, but hopefully it will be fixed later on.
                    Thanks
                    Fredrik
                    • Falkiaundefined
                      Falkia
                      I can confirm that this is now fixed in 3.4-b7. Thanks @dc42
                      • Falkiaundefined Falkia has marked this topic as solved
                      • Falkiaundefined Falkia referenced this topic
