    External stepper drivers (TB6600) on duet 2 wifi
    Using Duet Controllers
    • m0ck1nj
      m0ck1nj last edited by
      Is it possible that i can remap the z axis to External stepper driver (in my case TB6600) without actully using the expansion board because i pretty much don't seem to have a need of other things of duex board like more integrated drivers,thermistors,heater outputs etc.
      for ex: i can use the pins 5, 7, 9, 11 to connect the TB6600?
      Thank you for your help in advance 🙂
      o_lampe 1 Reply Last reply Reply Quote 0
      • o_lampe
        o_lampe @m0ck1nj last edited by
        @m0ck1nj
        Check the TB6600 datasheet. If it is OK with 3.3V signals on step, dir, enable you can wire it directly.
        If it needs differential signals or 5V you can use the much cheaper expansion breakout board
        m0ck1nj 1 Reply Last reply Reply Quote 3
        • m0ck1nj
          m0ck1nj @o_lampe last edited by
          @o_lampe hugely thank you so much!
          that worked...i was just confused regarding the 3.3 v pin because on the TB6600 there is only 5v pin but somehow that worked without any problems; tbh that mini breakout board is the real lifesaver.
