    Warning: motor phase A may be disconnected reported by driver(s
    • rogerz79undefined
      rogerz79
      I have a duet 2 wifi board. I lost my sd card and had to start over. During the process of starting over there was a miscommunication between DWC and my board for the heaters and the way that was resolved was by upgrading to firmware 3.3. I also have a dual Z setup with each one connected to its own driver. Before I added the M671 command to my config file I was not getting any warnings and was able to home my system. No prints since yet since upgrading to 3.3. Once I added he M67 command I began to get warnings when ever the Z axis was used.
      12/9/2021, 3:56:47 PM G28
      Warning: motor phase A may be disconnected reported by driver(s) 2 4
      Warning: motor phase B may be disconnected reported by driver(s) 2 4
      12/9/2021, 3:57:00 PM Warning: motor phase A may be disconnected reported by driver(s) 4
      Warning: motor phase B may be disconnected reported by driver(s) 4
      12/9/2021, 3:57:05 PM Warning: motor phase A may be disconnected reported by driver(s) 4
      Everything moves as I would expected to move. The z axis still works but I get the warning. Before I lost my SD card and was running on 2.03 firmware I was able to use dual Z axis Just fine with out an warning. I have checked the wiring and everything looks good. Left Z motor is on Z1 and right z motor is on Z2. What do the warnings mean?
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Dec 05 2021 22:24:46 GMT-0500 (Eastern Standard Time)
      M550 P"Ender 3XL" ; set printer name
      M918 P1 E4 F2000000 ; configure direct-connect display
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S1 ; enable FTP
      M586 P2 S1 ; enable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P3 S1 ; physical drive 3 goes FOWARDS
      M584 X0 Y1 Z2:4 E3 ; set drive mapping
      M671 X-16:390 Y0:0 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M92 X80.00 Y80.00 Z400.00 E394.79 ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X200.00 Y200.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-16 Y-1 Z0 S1 ; set axis minima
      M208 X390 Y405 Z450 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      G31 P500 X-32 Y-36 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X50:350 Y50:350 S70 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M143 H0 S150 ; set temperature limit for heater 0 to 150C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S275 ; set temperature limit for heater 1 to 275C
      M106 P0 S0 ; set fan 0 value. Thermostatic control is turned off
      M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on
      ; Custom settings
      M501
        dc42 administrators @rogerz79
        @rogerz79 can you identify the type of the Z motors? Is it the same as the type of the X and Y motors? Do the Z motors get hot?
        Some 3D printers use low current high inductance Z motors so that two can be driven in parallel from a single driver. If that's the case then you need to reduce the Z motor current in the M906 command, and perhaps also the max Z speed in the M203 command.
        rogerz79undefined 1 Reply Last reply Reply Quote 0
        • rogerz79undefined
          rogerz79 @dc42
          @dc42 both are "Creality 42-34(Z)" motors. They do not get hot. Their specs are
          SPECIFICATIONS:
          Step angle: 1.8 degrees
          Steps: 200
          Nominal Voltage: 4.83V
          Current Rating: 1.5A
          Rated speed: 1-1000rpm
          Rated torque: 0.4NM
          Ambient Temperature: -20 - 50℃
          Length: 34mm
            @rogerz79 I suggest you plug those numbers along with the phase inductance (if you can find it) into the EMF calculator at https://www.reprapfirmware.org/emf.html to see whether your 180mm/sec Z speed exceeds the full-torque speed.
            • rogerz79undefined
              rogerz79 @dc42
              @dc42 I have plug those numbers in to the tool. I used 8.4mh for the inductance and 5.75 for the resistance. As far as I can tell it states that anything above a 20 mm/sec will cause it to loose torque and slip. Doesn't that sound too low? Or should I be getting different motors to drive my two lead screws that are 500mm long?
                Phaedrux Moderator @rogerz79
                @rogerz79 said in Warning: motor phase A may be disconnected reported by driver(s:
                20 mm/sec
                20mm/sec is quite fast for a z axis. Keep in mind the difference between mm/sec and mm/min.
                The creality motors aren't the greatest and don't tend to perform well outside of their intended configuration that Creality has chosen them for. There are better motors to choose from.
                • rogerz79undefined
                  rogerz79 @Phaedrux
                  @phaedrux dropping it down to 20mm /sec does get rid of the warning
