    Z AXES DOUBLE SETUP
    Example setups and prints
    • GiusepRapundefined
      GiusepRap
      Hi every one I' want remind the procedure that I used for understanding missing steps (if there are).
      1. M584 X0.0 Y0.0 Z0.2:0.4 E0.3
        "for selecting the 2 and 3 driver for the z axes".
      2. M574 Z1 S1 P"io3.in"
        "for selecting the microswitch z for the two motors"
      Can I have a confirmation by someone that is better then me with the duet mini 5 plus?
      Is there anything that should I change ? I ' m setting up a Prusa i3 modified.
      regards
      Giuseppe
      rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
      • rjenkinsgbundefined
        rjenkinsgb @GiusepRap
        @giuseprap said in Z AXES DOUBLE SETUP:
        You have used output zero twice, I suspect Y should be 0.1
        For two motors with separate limits, you need two inputs?
        This is what I have (on a Duet 6HC):
        M574 Z1 S1 P"io3.in+io4.in"                  ; configure active-high endstop for low end on Z via pin io3.in
        Robert J.
        Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
