Gcode edit tool?
Anyone know, not a text editor, any tool to edit gcode files? (add commands at the beginner or at the end, change temperatures by layers, change speeds,jerk, acceleration, ...)
Examples of where it could be used:
- Change the temperature per layer (make temperature towers)
- Edit pressure in advance
- Edit the speeds to see the effect on the print
- add or remove gcodes at the beginning and/or end
And more..
@peirof I don't know of such a tool, however I think you can do most of those things without one. To make changes per layer, use the facility provided by some slicers to call a layer change script. For greatest flexibility, that script can call a macro file, passing it the layer number.
