Solved Slicer shuts off hotend fan.
Hi, I have a problem with my Hevo(duet wifi, Duet Web Control 3.3.0)
My hotend fan is configured as thermostatic and works as it should, but when I start printing the slicer g-code shuts the fan off. I use cura or Prusa slicers but both are doing the same thing.
This is my config.g
M106 P0 C"Part Cooling Fan" S0 H-1 ; set fan 0 value. Thermostatic control is turned off
M106 P1 C"Hotend Fan" S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 S"Sherpa/Dragon" D0 H1 F1 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0CCura and Prusa are using M107 in the code with no parameters which shuts off the hotend fan. I've set cooling fan number in Cura to 0.
What I'm doing wrong? Because I can't fix it.
I assume you verified that fans are connected to the correct connectors on the board?
@fcwilt said in Slicer shuts off hotend fan.:
When I turn on the hotend fan in the duet web control it turns the right fan on. So I assume its ok.
@luka1952 I think you might have the fans swapped. The hotend fan (which cools the hotend) does not have a control in the web interface. The print cooling fan, which cools the filament just after it has extruded, can be controlled from web interface.
@luka1952 said in Slicer shuts off hotend fan.:
The hotend fan should not be showing in the duet web control. Only the part cooling fan should be visible.
@generisi
I know it has no control. I just turn on the hotend and when the temp. riches 45deg. it turns on. -
@generisi Sorry my mistake.
To be clear:
I have only one slider in duet web control and it is part cooling fan.
When I use it part cooling fan is working.
When I set temp. higher the 45 deg. on my hotend the hotend fan kicks in. -
Is this correct?
I'm assuming you should have F0 instead ?
@gixxerfast
I've just change it.
Before it was F0 but I've got the same problem. -
@luka1952 Your config has this
I think you either want to say S255 or S1.0 . S1 looks to the firmware like you want the fan set to 1 out of 255. -
@luka1952 It should be the part cooling fan associated with the tool so it should be F0 (or nothing at all).
Also you should (as far as I know) end your config by selecting the tool with a:
T0
Also try removing the S"Sherpa/Dragon" (just to test)
And the above that GeneRisi wrote ^
Ok, thanks I'll try to change it and see what happens
@generisi said in Slicer shuts off hotend fan.:
That's what the docs say. However testing reveals that, in firmware 3.3 at least, S1 get special treatment and is the same as S1.0
Did you look at the slicer code and verify the M106/M107 commands have no parameter?
@fcwilt
Yes,it has no parameter. -
Could you post your latest config.g and a picture from DWC where one can see the fans?
So just to recap, before you run the gcode from the slicer the hotend fan (Fan 1) is running and directly when you start the slicer gcode, fan 1 stops?
And, when you move the tool fan slider in DWC the part cooling fan starts and stops?
Hi everyone.
After making suggested changes everything is working correctly now. Thanks a lot -
