Duet 2 Wifi Z-Probe Recommendations
I was wondering if there is any recommended Z-Probes for Duet 2 Wifi use or any model that hooked up and was more compatible than others. I'm used to seeing the BL Touch but after some research, it looks like a bit of a hassle to set up. Wondering what else is out there and common in this community.
https://duet3d.dozuki.com/Wiki/Choosing_a_Z_probe
Take a look at the options. There are pros and cons to all of them.
The BLTouch seems complicated but it's not that bad really.
@phaedrux Man I always try and find these sorts of posts before I make a new one in the forum but everytime it seems like there’s the perfect one I missed. Thank you
