Need help setting up X-Scara on a Duet 3 mini 5+
I'm setting up a Scara type, one arm 3d printer on my Duet 3 mini 5+ . I have the Marlin config if that helps. I'm looking at the duet wiki about setting up Scara, and that has helped me mostly.
Here's the link to the X-Scara printer with Marlin Firmware
https://github.com/madl3x/x-scara/blob/master/firmware/CONFIGURE.mdRunning firmware 3.3.0 on web control and the main board
EDIT: Somewhat fixed temp probe problem, but now have another issue.
Temperature is now showing. the problem now is I have the tool selected, but can't change temperature of it.I followed some of the instructions from here: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Mini+5++Guide+Part+2:+Configuration/88
Here is my heaters setup in config.g:
M308 S1 P"temp1" Y"thermistor" T10000 B4138
M950 H1 C"out1" T0
M307 H1 B0 S1.00
M143 H1 S280;Tools
M563 P0 S"Hotend" D0 F0
G10 P0 X0 Y0 Z0
G10 P0 R0 S0
That's the first problem.The second part that isn't a problem yet, but I'm asking cause I've seen from threads on this, is setting up a precision piezo orion on my mini 5+. Here is what I've got so far, haven't tested it yet, but is this good?
M574 Z1 S2 P"io3.in"
M558 P8 C"^probe.in" H5 F300 T3000 R0.8
G31 P500 X0 Y0 Z-0.2
M557 X15:75 Y15:195 S30I haven't set up the homing files yet, but I want to solve these two first before I move on to the homing part. Thanks!
@iamthebest22 said in Need help setting up X-Scara on a Duet 3 mini 5+:
;Tools
G10 P0 X0 Y0 Z0
G10 P0 R0 S0This is missing H0
Where did this come from?
"^probe.in"
This doesn't look right either.
This looks better
M558 P8 C"io3.in" H5 F120 T6000
@phaedrux Thanks for the fast response.
I was looking around in some of the threads that was talking about setting precision piezo orion on Duet wifi's and maestros, and saw that on RRF3 , you need to tell which is the Z probe pin, so I thought I'd do that, guess that I was totally off the mark.
What should be the M574 for Z if "M574 Z1 S2 P"io3.in" is not the right setup?
I've changed M558 to M558 P8 C"io3.in" H5 F300 T6000 R0.8 as you've said for my precision piezo orion now, do I need to do anything for M574 ? Thanks.
current code:
M574 X1 S1 P"io5.in"
M574 Y1 S1 P"io6.in"; Z-Probe
M574 Z1 S2
M557 X15:75 Y15:195 S30 ; define mesh gridNew "problem", I've tried changing M574 Z1 S2 to S1. but both show the Z-probe the precision piezo orion at 1000, it does go to 0 when it triggers, but pretty sure it should be the other way around? Or is S2 correct cause according to https://forum.duet3d.com/topic/19236/piezo-orion-rrf-3-problems/2?_=1639887997050 it needs to be inverted for RRF3.
You do, but that's done in M558.
If you only want to use a Z probe you don't have to have a M574 for Z at all. It's only used for endstops.
To invert the signal for the probe you need to add a
to the front of the pin name used in M558.M558 P8 C"!io3.in"
@phaedrux Thanks once again, okay so just to confirm.
As I am using my Z probe Precision PIezo Orion as also the Z endstop, I don't need to put anything in for M574 for Z, like not even M574 Z0 P"nil" to indicate no endstop and free it up for something else? Thanks.
Right now it's:
M574 X1 S1 P"!io5.in"
M574 Y1 S1 P"!io6.in"; Z-Probe PRECISION PIEZO ORION
M558 P8 C"!io3.in" H5 F300 T6000 R0.8
M557 X15:75 Y15:195 S30 ; define mesh grid -
correct. you can leave it out entirely.
Some people have additional endstops used for fast homing, or tilt correction, or z max homing, so in those cases it would define the endstop used, separate to the probe.
@phaedrux Thanks again, right now I'm setting up the homing files, it somewhat works, but getting one error and one obsolete command on console.
Update: I'm an idiot, precision piezo orion can't use G1 S1 Z-305 F100 ; move Z down until the switch triggers
they have to use G30 instead. Will report back.
Second update: it's working, but I need the probing speed to be faster, how do I changed that,
I tried M558 P8 C"!^io3.in" H5 F300 T6000 R0.8 and changed F to F2000 but nothing changed.Third update: Found the issue, set the max speed for Z too low. It's sorted, now I just need to make the piezo not so sensitive.
thought I continue this thread, instead of editing it again and again.
Homing is successful, but not sure if my setting is wrong or something. I had to make this setting:
M669 K4 P98.00 D98.00 A-106:106 B16:140 C-1:0:0 X100 Y-100 T0.5 S300
in order for the arms to be perfectly in line with each other when I send G1 H2 X0 Y0
Is that correct for the B parameter? Thought the first number should be 0. Pretty sure the motors are going in the correct directions.
Update: got probing working sorta, need help with defining mesh grid. Currently I don't want to use the full half donut shape (until I've designed a proper bed for it). Right now the code is:
M557 X15:100 Y15:120 S30
and it's going slightly too far to my left for the first probe point. How should I change this?Btw is there a command to test probe accuracy?
@iamthebest22 Going to "close" this thread as what I'm doing now it's more tuning and tweaking rather than firmware installation. Thanks!
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
