    Dual Z - Axis Belt Drive Configuration Uncertainty
    968
    • TimVukman
      TimVukman last edited by
      Hi
      I have a Tevo Tarantula. I have removed all of the rollers from the axis build plates and I have replaced them with sliding mounts which are mounted on my rails. Very smooth action!
      I have included the Z axis in this changeover, so the threaded rod has been removed. I have two Z axis motors connected to the two Z ports on the DuetWifi. These motors have the same toothed gear wheels as the X and Y axis, and I have mounted roller wheels to the center cross frame on the bottom beam that crosses under the heat bed. The belts are fastened to the build plates on either end of the X axis.
      The Z motors will need to rotate in opposite directions in order to raise and lower the plates / X axis.
      Do the Z axis drivers on the DuetWifi have different names even though they are driven in a serial connection, or should I use Extruder 1 as the second driver in order to set the direction of rotation opposite to Z0?
      I have set the step/mm rate in the config.g file to match what is set for X and Y.
      Is there anything else that I should be aware of that I might be overlooking?
      Thanks,
      Tim
      • elmoret
        elmoret last edited by
        You can reverse the direction of a stepper by flipping the connector, or reversing the polarity of a coil.
          If you connect your two Z motors to the ZA and ZB connectors, then they have the same name in the firmware. Connect the wire colours of the two motors in the opposite order to make them turn in opposite directions.
          However, if the E1 motor connector is otherwise unused, then you can connect one Z motor to that one instead, and use the automatic bed levelling feature to adjust the Z motors independently after homing. See https://duet3d.com/wiki/Bed_levelling_using_multiple_independent_Z_motors.
          • TimVukman
            Thanks elmoret for the input on flipping the connector. That works for me.
            Thanks DC42 also for the input on flipping the connector. That is the easiest solution. Are you saying that they are referred to differently as ZA or ZB specifically instead of just Z as previously configured with 1 Z motor?
            I did also purchase and install the special IR Probe for the DuetWifi and so I would like to include it's configuration in the mix as well. For ease of mounting, I have installed it on a small acrylic panel that is intended for the limit switch, I would eventually like to print a case for it and mount it to the side of the hot end, but I want to get the print quality up first. The probe is near the edge of the gantry on the right side of the print bed. I have tested it and it certainly "sees" the surface and triggers.
            I have added the code that I found in the examples for the various home files, so I hope that will work. I am a little concerned that I did not define the probe in the configuration anywhere. I was previously using a limit switch on a threaded rod arrangement and I remember having to state the type for the system. Do I not have to do so for the IR Probe? or is it detected and all I need do the G30 to record the height that it tripped at?
            Thanks,
            Tim
              See the "Testing and commissioning the board" section at https://miscsolutions.wordpress.com/mini-height-sensor-board/.
              • TimVukman
                Hi dc42
                I shall read up and post if unclear. Thanks for the link!
                Tim
                • TimVukman
                  Hi dc42
                  Would you mind looking at my config.g file?
                  ; General Preferences - no changes
                  dropped the Z1 out of the M574 line. It was before the S0
                  uncommented M558 and changed P0 to P1
                  uncommented G31 and changed P600 to P500
                  I think I should be doing something here to assign ZA clockwise to raise hotend rail on the right side
                  motor and to assign ZB to counterclockwise to raise hotend rail on the left side in sync with motor ZA
                  I do not understand the relationship between P0 to what I expect should include a P4. Are they X, Y,
                  ZA, ZB, E0 in order? , with X backwards, Y backwards, ZA backwards? P3 is the extruder I think which
                  is set to go forwards, but does ZB get inserted ahead of P3?
                  In the M92 line I changed Z1600 from the threaded rod to Z80 like X and Y since I am using the same
                  motor and belt and gear wheel.
                  In the M906 line, do I need to bump the current because of the two Z motors, or do I need a line for
                  each of ZA and ZB to set each of them to 1200ma, or is this where I should decide to use E1 and do
                  do my setting there?
                  I made no other changes in config.g.
                  Thanks,
                  Tim
                  Here is the config.g file
                  ; Configuration file for Duet WiFi (firmware version 1.17)
                  ; generated by RepRapFirmware Configuration Tool on Fri Sep 08 2017 10:03:01 GMT-0400 (Eastern Daylight Time)
                  M111 S0 ; Debugging off
                  G21 ; Work in millimetres
                  ;M83 ; ...but relative extruder moves
                  M208 X210 Y280 Z200 S0 ; Set axis maxima
                  M574 X1 Y1 S0 ; Define active low and unused microswitches
                  M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
                  G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
                  M557 X25:175 Y25:175 S20 ; Define mesh grid
                  M569 P0 S0 ; Drive 0 goes backwards
                  ;M350 X128 Y128 Z128 E16 I0 ; Configure microstepping without interpolation
                  M92 X80 Y80 Z80 E333.33 ; Set steps per mm
                  M566 X900 Y900 Z200 E5000 ; Set maximum instantaneous speed changes (mm/min)
                  M203 X12000 Y12000 Z1200 E3000 ; Set maximum speeds (mm/min)
                  M201 X1000 Y1000 Z100 E3000 ; Set accelerations (mm/s^2)
                  M906 X1200 Y1200 Z1200 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M143 S260 ; Set maximum heater temperature to 260C
                  M305 P0 T100000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                  M305 P1 T100000 B4725 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                  M563 P0 D0 H1 ; Define tool 1
                  G10 P0 X0 Y0 Z0 ; Set tool 1 axis offsets
                  G10 P0 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                  M550 PTevo Tarantula ; Set machine name
                  M552 S1 ; Enable network
                  ; Access point is configured manually via M587 by the user
                  M586 P0 S1 ; Enable HTTP
                  M586 P1 S0 ; Disable FTP
                  M586 P2 S0 ; Disable Telnet
                  M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  T0 ; Select first tool
                  M501
                    Your config looks ok to me.The ZA and ZB connectors are wires in series to a single Z driver, so you don't need to refer to them separately in config.g.
