    Ender 3 RRF v1.1 setting up BLtouch
    4.2k
    • Gixxerfastundefined
      Gixxerfast @re_tour
      @re_tour said in Ender 3 RRF v1.1 setting up BLtouch:
      G31 P500 X117.5 Y90 Z3.55
      No, wait a minute here. Everything in G31 is relative to the nozzle, nothing else. You only tell where the probe is relative the nozzle. Nada mas.
      Also, the middle of the bed for you should be 235/2 right? That you only use in the mesh-g file not in the G31 command.
      Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
      Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
      Ender 3 Pro with BTT SKR-2 + RRF
      re_tourundefined 1 Reply Last reply Reply Quote 1
      • re_tourundefined
        re_tour @Gixxerfast
        @gixxerfast Oh alright, so its gonna be this in the config.g:
        G31 P500 X-44 Y-18 Z3.55
        this in the mesh.g:
        var xoffset = -44
        var yoffset = -18
        var xpos = {117.5 - var.xoffset}
        var ypos = {117.5 - var.yoffset}
        But for some strange reason my nozzle homes to X130 Y160
        Creality Ender 3 | BIGTREETECH E3 RRF V1.1 Wifi | BLTouch | RepRap 3.3.0_11
        Gixxerfastundefined 1 Reply Last reply Reply Quote 0
          Gixxerfast @re_tour
          @re_tour That looks better.
          Well, that's where you go in your homez.g
          G1 X130 Y160 F6000
          You can change it to the same as in the mesh.g
          • re_tourundefined
            re_tour @Gixxerfast
            @gixxerfast Oh my god I'm starting to get really exhausted 😬
              Gixxerfast @re_tour
              @re_tour Yeah, take a break. Start again tomorrow 🙂
              It will work now as it is. Maybe not perfectly but good enough to print PLA and stuff.
              With PC, ABS and ASA it need to be pretty spot on but with PLA it should work fine.
              You should not print those others anyway with your PTFE lined hotend.
              re_tourundefined 2 Replies Last reply Reply Quote 1
              • re_tourundefined
                re_tour @Gixxerfast
                @gixxerfast You're right, I'll leave it be for today. I can't thank you enough for all the help, I would be nowhere without your assistance.
                  Gixxerfast @re_tour
                  @re_tour No problems, happy to help out when I can 🙂
                  • re_tourundefined
                    re_tour @Gixxerfast
                    @gixxerfast I'm bosting everythin here so that it won't get lost somehow and I can better check it tomorrow 😁 Maybe someone can find it helpful as well
                    homez.g:
                    ; homez.g
                    ; called to home the Z axis
                    ; do nothing if XY is not homed yet
                    if !move.axes[0].homed || !move.axes[1].homed
                        echo "XY are not homed yet. Aborting"
                        abort
                    ;end if
                    G91
                    G1 H2 Z5 F6000
                    G90
                    G1 X117.5 Y117.5 F6000
                    G30 K0 Z-99999						    ; Probe the Z pin at the back
                    G1 Z10 F9000
                    homex.g:
                    ; homex.g
                    ; called to home the X axis
                    G91
                    if !move.axes[1].homed
                    	; raise Z a bit
                    	G1 H2 Z5
                    G1 H2 Z5 F6000    ; lift Z relative to current position
                    G1 H1 X-240 F3000 ; move quickly to X axis endstop and stop there (first pass)
                    G1 H2 X5 F6000    ; go back a few mm
                    G1 H1 X-240 F240  ; move slowly to X axis endstop once more (second pass)
                    G90               ; absolute positioning
                    homey.g:
                    ; homey.g
                    ; called to home the Y axis
                    G91
                    	; raise Z a bit
                    	G1 H2 Z5
                    G1 H1 Y-240 F3000 ; move quickly to Y axis endstop and stop there (first pass)
                    G1 H2 Y5 F6000    ; go back a few mm
                    G1 H1 Y-240 F240  ; move slowly to Y axis endstop once more (second pass)
                    homeall.g:
                    ; homeall.g
                    ; called to home all axes
                    M98 P"/sys/homex.g"
                    M98 P"/sys/homey.g"
                    M98 P"/sys/homez.g"
                    config.g:
                    ; Configuration file for SKR-RFF-E3-v1.1 (firmware version 3)
                    ; generated by RepRapFirmware Configuration Tool v3.3.1-LPC-STM32+2 on Tue Dec 28 2021 01:07:55 GMT+0100 (közép-európai téli idő)
                    G90                                            ; send absolute coordinates...
                    M83                                            ; ...but relative extruder moves
                    M550 P"Ender3"                                 ; set printer name
                    M552 S1                                        ; enable network
                    M586 P0 S1                                     ; enable HTTP
                    M586 P1 S0                                     ; disable FTP
                    M586 P2 S0                                     ; disable Telnet
                    M569 P0 S0                                     ; physical drive 0 goes backwards using TMC2209 driver timings
                    M569 P1 S0                                     ; physical drive 1 goes backwards using TMC2209 driver timings
                    M569 P2 S1                                     ; physical drive 2 goes forwards using TMC2209 driver timings
                    M569 P3 S1                                     ; physical drive 3 goes forwards using TMC2209 driver timings
                    M584 X0 Y1 Z2 E3                               ; set drive mapping
                    M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                    M92 X80.00 Y80.00 Z400.00 E93.00               ; set steps per mm
                    M566 X1200.00 Y1200.00 Z60.00 E360.00          ; set maximum instantaneous speed changes (mm/min)
                    M203 X9000.00 Y9000.00 Z1800.00 E6000.00       ; set maximum speeds (mm/min)
                    M201 X500.00 Y500.00 Z100.00 E5000.00          ; set accelerations (mm/s^2)
                    M906 X1000 Y1000 Z1000 E1000 I30               ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30                                        ; Set idle timeout
                    M208 X0 Y0 Z0 S1                               ; set axis minima
                    M208 X235 Y235 Z260 S0                         ; set axis maxima
                    M574 X1 S1 P"xstop"                            ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                    M574 Y1 S1 P"ystop"                            ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                    M950 S0 C"servo0"                              ; create servo pin 0 for BLTouch
                    M558 P9 C"^probe" H5 F300:120 A3 T6000         ; set Z probe type to bltouch and the dive height + speeds,the F300:120 first speed 300 second 120
                    G31 P500 X-45 Y-7 Z3.55                      ; set Z probe trigger value, offset and trigger height
                    M557 X30:190 Y30:190 P5                       ; define mesh grid
                    M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                    M950 H0 C"bed" T0                              ; create bed heater output on bed and map it to sensor 0
                    M307 H0 B0 R0.365 C296.6 D3.97 S1.00 V24.0                               ; disable bang-bang mode for the bed heater and set PWM limit
                    M140 H0                                        ; map heated bed to heater 0
                    M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                    M308 S1 P"e0temp" Y"thermistor" T100000 B4092  ; configure sensor 1 as thermistor on pin e0temp
                    M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                    M307 H1 B0 R2.845 C121.4:119.4 D5.71 S1.00 V24.0                               ; disable bang-bang mode for heater  and set PWM limit
                    M143 H1 S245                                   ; set temperature limit for heater 1 to 245C
                    M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                    M106 P0 C"Part Cooling Fan" S0 H-1             ; set fan 0 name and value. Thermostatic control is turned off
                    M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                    M106 P1 C"Hotend Fan" S0.01 H1 T45             ; set fan 1 name and value. Thermostatic control is turned on
                    M563 P0 D0 H1 F0                               ; define tool 0
                    G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                    G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                    M918 P1 E4 E1000000
                    bed.g:
                    ; bed.g
                    G29  ; probe the bed and enable compensation
                    mesh.g:
                    if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                     G28
                    M290 R0 S0    ;  clear baby stepping
                    G29 S2
                    ; move to the center of the mesh with the PROBE (mind affset in Y is 25 above noozle)
                    G90
                    var xoffset = -45
                    var yoffset = -7
                    G1 X{var.xpos} Y{var.ypos} Z15 F6000
                    echo "Setting Probe Offset now"
                    G30 K0
                    G1 Z15 F3000
                    G29 S0
                    • re_tourundefined
                      re_tour @Gixxerfast
                      @gixxerfast Hey there! So today I've tried the mesh and it works! This is what I see after running it:
                      So now all is left is to slice the things I want in Cura and upload the gcode which I get? 😁
                      re_tourundefined 1 Reply Last reply Reply Quote 0
                      • re_tourundefined
                        re_tour @re_tour
                        So I started the print, and the filament started to go in the opposite direction. I haven't the slightest clue why.
                          Gixxerfast @re_tour
                          @re_tour Hi there, reverse the extruder motor
                          M569 P3 S0
                          • re_tourundefined
                            re_tour @Gixxerfast
                            @gixxerfast said in Ender 3 RRF v1.1 setting up BLtouch:
                            M569 P3 S0
                            Thank you so much. Do I have to reverse it every time I turn the printer on or was it just an initial setting mistake I didn't pay attention to? 😁
                              Gixxerfast @re_tour
                              @re_tour No, just change it once in config.g and it wasn't a mistake. Really hard to know how the wires are supposed to be, just as long as the pairs are correct it's good. Many has to adjust that AFAIK.
                              • re_tourundefined
                                re_tour @Gixxerfast
                                @gixxerfast Thank you very much!
                                • re_tourundefined
                                  re_tour @Gixxerfast
                                  @gixxerfast So I didn't input that change into the config.g yet, but wrote it into the console. Printed 2 things, the strange thing is that at the end of each print the mechanism pulls the filament all the way out. Why could that be?
                                    Gixxerfast @re_tour
                                    @re_tour You must have something wonky in your slicer. Check if there some custom end print gcode in Cura (it was Cura you were using, right?)
                                    re_tourundefined 2 Replies Last reply Reply Quote 0
                                    • re_tourundefined
                                      re_tour @Gixxerfast
                                      @gixxerfast Yes sir, let me check.
                                      • re_tourundefined
                                        re_tour @Gixxerfast
                                        @gixxerfast This is the last few lines of the first gcode:
                                        ;TIME_ELAPSED:2311.874865
                                        G1 F2700 E788.98313
                                        M140 S0
                                        M107
                                        G91 ;Relative positioning
                                        G1 E-2 F2700 ;Retract a bit
                                        G1 E-2 Z0.2 F2400 ;Retract and raise Z
                                        G1 X5 Y5 F3000 ;Wipe out
                                        G1 Z10 ;Raise Z more
                                        G90 ;Absolute positioning
                                        G1 X0 Y235 ;Present print
                                        M106 S0 ;Turn-off fan
                                        M104 S0 ;Turn-off hotend
                                        M140 S0 ;Turn-off bed
                                        M84 X Y E ;Disable all steppers but Z
                                        M82 ;absolute extrusion mode
                                        M104 S0
                                        ;End of Gcode
                                        and the end of the second gcode:
                                        ;TIME_ELAPSED:10192.122505
                                        G1 F2700 E523.83295
                                        M140 S0
                                        M107
                                        M104 S0
                                        ;End of Gcode
                                          Gixxerfast @re_tour
                                          G1 E-2 F2700 ;Retract a bit G1 E-2 Z0.2 F2400 ;Retract and raise Z
                                          I really don't have a clue. I'm just guessing but...
                                          Try to find where these are inserted
                                          And comment them out /remove them.
                                          See if it makes any difference.
                                          • re_tourundefined
                                            re_tour @Gixxerfast
                                            @gixxerfast You were right, G1 E-2 F2700 pulls the filament nearly all the way out. Thank you (once again) 😁
