    error: meta command expected an expression
    Gcode meta commands
    364
    • XYZ_123undefined
      XYZ_123
      I came across this thread reference: https://forum.duet3d.com/topic/26277/how-to-allow-user-to-reset-password/6?_=1640581081938
      Tried to use it to set fan frequency as per fan replaced.
      I'm writing following logic to set fan frequency from console.
      wff.g
      M950 F0 C"out7" Q{param.S}
      echo ><fanconfg.g> "M950 Q""" ^ param.S ^ """"
      and in console I try to run as follows:
      M98 P"wff.g" S3000
      When I run, the logic saves value, but I receive error" ".
      any suggestions, what is the syntax error ?
        dc42 administrators @XYZ_123
        @dp_23 said in error: meta command expected an expression:
        Your echo command is wrong. If I understand correctly what you are trying to do then it should be:
        echo >"fanconfg.g" "M950 Q" ^ param.S
        XYZ_123undefined 1 Reply Last reply Reply Quote 0
        • XYZ_123undefined
          XYZ_123 @dc42
          @dc42 it still I receive the error.
          • OwenDundefined
            OwenD
            This works on Duet 2 stand alone.
            echo >"fanconfg.g" "M950 Q" ^ {param.S}
              @dp_23 which firmware version are you using?
              • XYZ_123undefined
                XYZ_123 @OwenD
                @owend its not working ...still gives me same error
                • XYZ_123undefined
                  XYZ_123 @dc42
                  @dc42 firmware version : 3.3 beta 3
                    jay_s_uk @XYZ_123
                    @dp_23 update your firmware to at least 3.3 stable
